Real quick noob question...engine RPM drop slow by design? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 02-21-2014, 04:00 PM   #1
pfsantos
Fan#: 125113
What I Drive: 2009 Silver SES
Points 703, Level 14
Points: 703, Level: 14 Points: 703, Level: 14 Points: 703, Level: 14
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
FF Reputation: 1 pfsantos Good Standing Member
I know there are a few good reasons (ok, I'm lying, I only know of one - to reduce backfiring) to cause the engine to drop RPM's a little slowly near idle.
I've noticed when shifting to neutral coming to a stop that the RPM's drop a little slow down to idle. So you're in gear, see the light up a head change to yellow, then foot in clutch, foot off gas, shift to neutral. The RPM's drop relatively fast down to around 2,000, then somewhat slowly. Is this by design? Do your focuses do this too? Just want to make sure the car doesn't have a problem.
Other quick question. Mine's a 2009...is this throttle fly-by-wire? Didn't notice a throttle cable.
Thanks all.
pfsantos is online now
Old 02-21-2014, 05:16 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,785, Level 73
Points: 12,785, Level: 73 Points: 12,785, Level: 73 Points: 12,785, Level: 73
Level Up 84% Completed
Forum Activity 99%
Yup & Yup
You figured it out right, "rev hang" is normal - emissions related & fly by wire throttle on your type.
If you take your foot off in gear, you'll notice it rollin' along without slowing much for a bit, then it closes the throttle more & starts slowing more normally.
Hate that wait on mine, I'd like a "tune" just to reduce that.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-21-2014, 08:01 PM   #3
pfsantos
Fan#: 125113
Doesn't help for engine braking lol forgot to mention. Thanks!
Paulo - '09 SES Silver
Old 07-11-2014, 11:49 AM   #4
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,255, Level 19
Points: 1,255, Level: 19 Points: 1,255, Level: 19 Points: 1,255, Level: 19
Level Up 55% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
Can this be tuned out? I'm about to get a tuner to try and fix that and the whole can't go anywhere from a stop on occasion during WOT, scary when you're trying to pull out from a stop on a bad curve and cant go anywhere
Sedan Revolution Two Three Zero
FRPP, "Stealth" CAI, Debadged, wider tires, louder stereo, turbo mainfold in the wrong place...
Gettysburg150 is offline
Old 07-11-2014, 02:54 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,954, Level 74
Points: 12,954, Level: 74 Points: 12,954, Level: 74 Points: 12,954, Level: 74
Level Up 26% Completed
Forum Activity 99%
Originally Posted by sailor View Post
Yup & Yup
Great next mod, Roger!!!!
felixthecat is offline
Old 07-11-2014, 02:59 PM   #6
pfsantos
Fan#: 125113
Rev hang, as sailor called it, are rpm's not coming down right away. No idea if it can be tuned out. But the later part in ur post is different. The revs should come up right away. Sounds like ur engine is delaying its response to u applying throttle. Very bad like u said. Without going off topic too far, i recommend u get it checked out.
Old 07-11-2014, 03:05 PM   #7
Gettysburg150
Fan#: 97408
Yea I know two different things, and yes I've experienced them both for a long time.
Engine runs fine and is sound, no faults, no knocks, no misfires, doesnt even burn or leak a drop of oil (I'm a tech, take pretty good care of it).
I've pretty much come down to it has to be tuning, sorry for the hijack OP
edit:
If it was a constant thing I'd probably take it over to Ford, but I had it in under the warranty period and it always had no faults on their scanner nor could they ever duplicate it. It's very rare, but the conditions are AC compressor clutch engaged, 1000-1200 rpm, starting from a stop (seems more noticeable on a slight grade), and rapid throttle application to 100%. The results are car takes at least a second to respond, its almost like the throttle valve stays shut or something, could be fuel or spark related as well, never stalls, just super bad hesitation
Old 07-11-2014, 03:06 PM   #8
pfsantos
Fan#: 125113
To those talking about tuning, are there shops who can reprogram specific things like this? And on our cars, can it be flashed into the computer, or do u need a piggyback or hardware added or changed?
Old 07-11-2014, 03:07 PM   #9
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,959, Level 40
Points: 3,959, Level: 40 Points: 3,959, Level: 40 Points: 3,959, Level: 40
Level Up 5% Completed
Forum Activity 9%
FF Reputation: 14 mac.mogul Great Standing Member
I found that adding ground wire to the throttle body helps to quell this behavior a bit.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is online now
Old 07-11-2014, 03:08 PM   #10
pfsantos
Fan#: 125113
Getty, i see. Ya that's a piss off, especially if the car gives no clues nor complains with codes.
