2008 Ford Focus Se Stick shift Revs help - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 02-19-2014, 03:19 AM   #1
fordfocus2008se
Fan#: 143009
What I Drive: 2008, silver, Se stick shift sedan
FF Reputation: 1 fordfocus2008se Good Standing Member
So i have been asking around and no one seems to know the answer to my question, so i decided to ask the pros here.
I have a 2008 ford focus se stick shift, with stock engine. I just want to know how many revolutions can i do before i switch gears without hurting the engine? Right now i change at 2k or 2.3k. Pretty much i want to know how high i can go in each gear before changing?
fordfocus2008se is offline
Old 02-19-2014, 06:56 AM   #2
childs00
Fan#: 59378
What I Drive: 2008 Red Focus Sedan SE
FF Reputation: 1 childs00 Good Standing Member
Well I have an automatic and if I am on it, it will go up to around 7 grand before shifting
childs00 is offline
Old 02-19-2014, 07:12 AM   #3
#1fordfan
Fan#: 83143
What I Drive: 2005 white se zx4
FF Reputation: 3 #1fordfan Good Standing Member
damn,if you are shifting at 2,000,that's almost lugging the engine(shifting to soon). Not sure about 2008,but my 2005 has a rev limiter somewhere over 6,000 rpms. I usually shift between 2500-3500 unless I am pulling into traffic or coming off an exit ramp. I do occasionally hammer it in every gear except fifth just to make sure everything is working as it should.
#1fordfan is offline
Old 02-19-2014, 09:22 AM   #4
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
FF Reputation: 5 SlickWilly Good Standing Member
If driving on public roads 2-3K would be suitable times to shift, if you are at the track you can wind her up to 6800 RPM's.
AEM Intake - F2 Header - 2.5" exhaust - C-F-M Pulleys - Holley Nitrous Wet Shot - FRPP Springs
SlickWilly is offline
Old 02-19-2014, 10:16 AM   #5
fordfocus2008se
Fan#: 143009
My red lining starts at around 6400, ive been told that because its a 4 cyl i should take it easy and not go over 4k, but ive hear some people once in a while go up to the start of the red line just to make sure the car is good? Also, how high can first gear go?
Old 02-19-2014, 11:54 AM   #6
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
FF Reputation: 13 mac.mogul Great Standing Member
If you shift too high you'll wear out the clutch faster. Shift below 2k and you'll start to lug the engine.
2k is fine. That's when the shift light comes on anyway. Shifting around 2k will be really smooth if you're easy on the gas pedal. So if you're concerned about fuel economy and smooth shifting, lower is better.
I usually shift around 3k because if I need to accelerate quickly for any reason I'll only need to downshift once to be in the powerband.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is online now
Old 02-19-2014, 12:16 PM   #7
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 67 sailor Excellent Standing Member
Good answers already, low to mid rpm range for everyday use depending on how much accel. is needed & run it hard on occasion to give it some exercise.
Shift before redline & you're OK, engine doesn't know what gear it's in.
Doesn't even hurt to run it to the limiter once just so you know where it is & what happens when you hit it, it's something you don't want to make a habit of doing but knowing about it can help.
Downshifting too far is what to avoid, if you're going fast in one gear & shift down to a lower one the engine will over rev when you let out the clutch. There's no protection against mechanically forcing it to rev. too fast. It's easy to figure out what will work, just pay attention to the difference in RPM between gears. For example, if you shift up at 3,000 and the next gear starts at 2,000 there's a 1,000 rpm difference between the gears. So if you're at 5,000 and the red line is 6,000 you're right at the edge for a downshift, any faster and you'd go over red line with a down shift. That gives you a rough idea, you want to avoid pushing the limits in that situation.
"Rubber Side Down"
S.R. #275
sailor is offline
Old 02-19-2014, 01:32 PM   #8
fordfocus2008se
Fan#: 143009
Thank you guys for your fast responses. This was very helpful!
Old 02-19-2014, 09:02 PM   #9
fauxfofo
Fan#: 138457
What I Drive: 2010 silver coupe mt
FF Reputation: 1 fauxfofo Good Standing Member
Be careful when you do your redline (up) shifting, I've noticed my engine spin past the Rev limiter a few times when i disengage the clutch.
Supposedly, the hard limit for a stock duratec is 7200 (rev limiter at 650p for my 09 manual) as any higher the valves float. Someone else should probably confirm that before you believe it because i haven't messed with the valve train on mine so I'm not an expert.
fauxfofo is offline
Old 07-11-2014, 10:57 AM   #10
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
FF Reputation: 2 Gettysburg150 Good Standing Member
I still kick redline on occassion. Stock engine. Hair over 120k on the odo. Fully synthetic 5w30 oil since first oil change. Oil changes @ every 5k
Sedan Revolution Two Three Zero
FRPP, "Stealth" CAI, Debadged, wider tires, louder stereo, turbo mainfold in the wrong place...
Gettysburg150 is offline
