Ford Focus: Suspension & Brakes - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 02-17-2005, 04:40 AM   #1
hotfocus
Fan#: 12
What I Drive: OLD: '00 Black ZX3, New: Pontiac G6
FF Reputation: 1 hotfocus Good Standing Member
Springs
• B&G Autobahn Springs - Lowers car 2.25 inches. $179.00
• B&G Sport Springs - Lowers front 1.6 and rear 1.4 inches. $179.00
• Eibach Pro-Kit Springs - Lowers front 1.4 and rear 1.5 inches. $219.00
• Eibach Sportline Springs - Lowers front 2 and rear 2.2 inches. $219.00
• Ford SVT Focus Suspension Kit - Lowers car .5 inches. $259.00
• H&R Springs - Lowers front 1.4 and rear 1.3 inches. $199.00
• Kazera StreetSport Springs - Lowers front 1.6 and rear 1.5 inches. $134.00
• Progress Technology Sport Springs - Lowers car 1.8 inches. $164.95
• Sprint Springs - Lowers car 2 inches. $160.00
• Steeda Sport Springs - Lowers car 1.5 inches. $219.95
• Suspension Tech Springs - Lowers car 1.3 inches. $179.00
• Tanabe Grip Feeling SUSTEC GF210 Springs - Lowers front 1.24 and rear 1.5 inches. $159.00
• Tein H-Tech Springs - Lowers front 2.4 and rear 2.9 inches. $230.00
• Tein S-Tech Springs - Lowers front 2.3 and rear 2 inches. $179.00
Spring & Damper Kits
• Eibach Pro-System - Kit contains springs and struts. Lowers front 1.4 and rear 1.5 inches. $489.00
• Eibach Pro-System Plus - Kit contains springs, struts, and anti-roll bar. Lowers front 1.4 and rear 1.5 inches. $740.00
• Eibach Sport-System Plus - Kit contains springs, struts, and anti-roll bar. Lowers front 2 and rear 2.2 inches. $587.00
• H&R Cup Suspension Kit - Lowers front 2.6 and rear 2.5 inches. $622.00
Coilovers
• Buddy Club Racing Spec Damper - 15 way adjustable suspension. $1,489.00
• Bilstein PSS9 Suspension Kit - 9 way adjustable suspension. $1199.00
• B&G Coil-Over Kit - Lowers car 1.2 to 3 inches. $949.00
• Eibach Pro-Street Coil-Over Kit - Front adjust from 1.2-3 inches, Rear .8-2.5 inches. $1095.00
• H&R Coil-Over Suspension Kit - Front adjust from 1.25-2.5 inches, Rear .75-2 inches. $944.00
• Koni Sport Suspension Kit - Adjust from 1.25-1.75 inches. $729.00
• Tein Coil-Over Suspension Kit - Front adjust from 1.25-2.5 inches, Rear .75-2 inches. $1282.50
Camber Kits
• Progress Technology Camber Correction Kit - Front Camber Plate - Max +2.5 Deg., Rear Shims - Max +1.5 Deg. $186.95
Sway Bars
• Eibach Sway Bar Kit - Front bar is 22mm, rear bar is 25mm. $249.00
• Steeda Focus Sway Bar Set - Front bar is 22mm. $259.95
• Steeda Competition Rear Sway Bar - Rear bar is 28.6mm. $99.95
• Suspension Tech Sway Bar - Rear Bar, it is 7/8 inch. $139.00
Strut Brace/Tower Bars
• Focus Central Strut Tower Brace $69.95
• FocusSport Upper-Front Stress Bars $89.95-$99.95
• FocusSport Rear Stress Bar $49.95-$68.95
• Ford Racing Strut Tower Brace $132.00
Anti-Roll Kit
• Eibach Anti-Roll Kit - Bar diameter 22mmF 25mmR. $252.00
• Ford Racing Anti-Roll Bar Kit - Bar diameter 22mmF 25mmR. $325.00
• H&R Anti-Roll Bar - Front bar diameter is 24mm. Bar is adjustable. Rear bar diameter is 24mm. (Font) $180.00 (Rear) $172.00
• Progress Technology Rear Anti-Roll Bar - Rear bar diameter is 22mm. $149.95
Dampers/Struts
• Koni Sport shocks - Externally adjustable. (Front) $161.20 (Rear) $146.00
• KYB GR-2 shocks - Non-adjustable gas shocks. (Front) $51.00 (Rear) $22.00
• KYB AGX Adjustable - Externally adjustable. (Front) $117.00 (Rear) $66.00
• Eibach Pro-Dampers - Non-adjustable gas shocks. (Set of 4) $329.00
Brake Pads & Shoes
• Akebono ProACT Ceramic Pads (Front) $69.00 (Rear) $59.00
• EBC Greenstuff Brake Pads $39.00
• EBC Redstuff Brake Pads $39.00
• Hawk HPS Street Brake Pads (Front) $68.00 (Rear) $54.00
• Satisfied Pro Perform OEM Pads (Front) $39.00 (Rear) $30.00
• Satisfied GranSport 5 Pads $63.00
• Satisfied GranSport 6 Pads $53.00
• Satisfied Pro Ceramic Pads (Front) $66.00
• Satisfied Pro Tech Shoes $27.00
Brake Rotors
• Brembo Replacement Rotor (Each) $49.00
• Brembo Sport Drilled Rotors $187.00
• Brembo Sport Slotted Rotors $187.00
• EBC Sport Grooved Rotors $99.00
• Focus Central Front Brake Kit $159.00
• PowerSlot Power Slot Rotor (Each) $77.00
• PowerSlot ProStop II Rotor (Each) $80.00
• PowerSlot Cryo-Treated Rotor (Each) $108.00
*If you see anything that needs to be added PM me.
Keywords: svt suspension, zx3 suspension, zx4 suspension, zx5 suspension, zts suspension, zxw suspension, ford focus springs, ford focus suspension, ford focus rotors, ford focus brakes, ford focus breaks, ford focus lowering springs, ford focus dampers, ford focus shocks
hotfocus is offline
    Quick reply to this message
Closed Thread
Similar Threads
Big plans for tiny Focus remusrm Ford Focus & General Car Chat 50 08-19-2009 02:51 PM
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Australia gets the new Focus next month Kneel Ford Focus & General Car Chat 27 11-26-2007 09:17 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
