2006 Focus ZX5 Manual trans - OD/Off light and engine light on - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-15-2014, 12:33 PM   #1
tjeens
Fan#: 141249
What I Drive: 2006 blue ZX5 SES
FF Reputation: 1 tjeens Good Standing Member
I have a manual transmission and recently (during cold temps of around -10 to -20 C) I started seeing the OD/Off light come on (which I thought was weird for a manual tranny. On warmer days (-2 to +10 degrees Celcius) the OD/Off light didn't come on. However, after 3 days, now I start seeing the engine light come on as well as the Od/Off light. The car drives fine (no slippage, no high revs - it drives as it should). The lights even stay lit after the key is out of the car. Just paranoid that the lights are a sign of something serious about to go wrong. Any ideas? Both lights are dimmly lit as opposed to the rest of the lights on the dash - not sure if that is a clue or not. Most postings on the web all revolve around automatic transmissions and the button by the gear shift lever which mine of course doesn't have. Thanks in advance.
tjeens is offline
Old 02-15-2014, 04:57 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,308, Level 75
Points: 13,308, Level: 75 Points: 13,308, Level: 75 Points: 13,308, Level: 75
Level Up 15% Completed
Forum Activity 99%
http://www.focusfanatics.com/forum/s...ge+cluster+fix
Check this thread out, it may apply to your problem.
My past issues like this were "solved" when I switched to a different cluster with a tach. (upgrade I wanted anyways). This newer info. is worth checking out, haven't tried it on the old cluster yet as I just noticed this recently.
Luck
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
