Who makes high flow (stock replacement) cats for our cars and what classifies it as high flow? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-14-2014, 03:19 PM   #1
qdeezie
Fan#: 129106
What I Drive: 2003 Black Focus ZX3
Points 587, Level 11
Points: 587, Level: 11 Points: 587, Level: 11 Points: 587, Level: 11
Level Up 74% Completed
Forum Activity 3%
FF Reputation: 3 qdeezie Good Standing Member
So, I have given up on trying to replace the crankshaft sensor on my car without removing the cat, so I'll be pulling the cat off this weekend and reinstalling it with anti-seize compound on the threads of every bolt, the O2 sensor fittings and the EGR fitting so that I will be able to easily remove it again in a couple of years whenever the cat goes bad.
With this being said, I have seen people mention high flow cats for our cars.
My question here is who makes them?
I assume the regular stock replacement Magnaflow is a high flow. That assumption is just off of reputation alone. I have done nothing to confirm this.
How would I know if a cat is high flow or a regular aftermarket (stock) replacement? Would one telltale sign be mandrel bends vs compression bends?
Are all stock replacement converters for our cars classified as high flow because the stock ones at the time the car was built were just that restrictive?
I'm comparing apples and oranges here, but on my 1990 F150, pretty much anything flows better than the stock unit, so my definition there is anything other than stock. Is that the case here?
Are there any high flow cats that turn the CEL on due to it and the downstream O2 sensor not seeing eye to eye?
I don't plan on buying a new cat soon because my car runs well, but I'd just like some clarification around exactly what is considered a high flow cat for our cars.
2003 ZX3 | 5 Speed | Black on Black
qdeezie is offline
Old 02-14-2014, 03:41 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
It is surely a misleading term and under-explained.
Basically 'high flow' is a higher cell count than stock. It should also be larger inlet and outlet, but that isn't the case for direct stock replacement.
Lets say the factory catalytic converter is a 180 cell count. A high flow version should be something like a 220 cell count.
So the holes through the media (cell), there are more of them.
Now you see the catch 22 here I'd bet. Well is the cat physically larger? No. the holes are smaller and the wall thickness is reduced.
That also means the cat is more susceptible to heat and impact. If the cat gets too hot (and I'm talking a couple thousand degrees F) it can break apart. If it's hit hard it can also break apart.
IMO, if you keep the cat and want better flow, you shouldn't skimp and avoid ebay at all costs. Don't expect to get one cheap. But revel in that it will be quality and work as intended.
iminhell is offline
Old 02-14-2014, 03:48 PM   #3
goingFocus
Fan#: 75386
What I Drive: 2005 CD silver ZX3 SES
Points 144, Level 2
Points: 144, Level: 2 Points: 144, Level: 2 Points: 144, Level: 2
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 goingFocus Good Standing Member
[QUOTE=iminhell;5477249]It is surely a misleading term and under-explained.
Mayee it's just me, but I believe that is a 42 cell count differential!
goingFocus is offline
Old 02-14-2014, 04:13 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,767, Level 73
Points: 12,767, Level: 73 Points: 12,767, Level: 73 Points: 12,767, Level: 73
Level Up 80% Completed
Forum Activity 99%
(I think the cell count was more for illustration than "specification".)
High Flow, like "High Performance" can be in the eye of the advertiser using the words, so if you want something that works well iminhell's suggestion of name brands makes sense. Cheapo's could be anything....
At a glance, CFM offers the magnaflow "high flow" unit for the Zetec the OP is inquiring about. That should function like stock & flow a bit better.
Looking a bit further, they offer both "Race" & "stock replacement" types for the SVT. So if an SVT header is installed on the Zetec, there are a couple choices of type. Choosing between those would be more of a debate since the race version is less likely to "pass" as a stock replacement and would differ quite a bit more in function.
Cheers
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 02-16-2014, 08:34 PM   #5
b.pearson
b.pearson's Avatar
Fan#: 130617
What I Drive: 2003 Infrared SVT ZX5
FF Reputation: 2 b.pearson Good Standing Member
I doubt the FSWerks part necessarily counts as a cat but it goes where the stock cat was. On their site I think they say it's a muffler, and that's essentially what it looks like, it's a straight through pipe with a can around it. But if you want a high flow cat replacement I don't think you could get much higher flow than that lol
2003 SVT ZX5- EAP rims, FSWerks Race cat-back exhaust, FSWerks SRI, Spectre cone filter & breather filter, FSWerks front splitter, SAP rear diffuser, upgraded throttle body (Size and brand unsure), HID headlights, more to come!
b.pearson is offline
Old 02-16-2014, 09:00 PM   #6
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,637, Level 94
Points: 23,637, Level: 94 Points: 23,637, Level: 94 Points: 23,637, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
factory cats since like the 90's have had the capability of about 150% flow... meaning everything is "high flow".
sorry I don't recall the exact details... been awhile.
mikebontoft is offline
Old 02-16-2014, 09:25 PM   #7
wv rider
wv rider's Avatar
Fan#: 125497
What I Drive: 2010 grey s
Points 1,141, Level 18
Points: 1,141, Level: 18 Points: 1,141, Level: 18 Points: 1,141, Level: 18
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 1 wv rider Good Standing Member
It is actually the reverse of what iminhell said. Advertised high flow cats are typically 100 or 200 cpi cats. OEM would be 400 or more. The more cells the more restriction.
The Focus formerly known as Gandalfthegreyfocus
wv rider is offline
Old 02-16-2014, 10:23 PM   #8
homelessmonkey
homelessmonkey's Avatar
Fan#: 98498
What I Drive: 2003 black zx3
Points 787, Level 14
Points: 787, Level: 14 Points: 787, Level: 14 Points: 787, Level: 14
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
FF Reputation: 2 homelessmonkey Good Standing Member
I got mine made all stainless with a stainless vibrant 200 cell high flow cat. For Svt headers. The guy who built it for me also made an elbow for the second o2 sensor so it wouldn't be in the main stream of the exhaust and it wouldn't throw a code.
If you still have the stock zx3 header even if you get a high flow cat you wouldn't see much of a difference in power maybe a couple HP's. But I've seen a couple around i know magnaflow has one. But if i was you I'd get an Svt header and then a high flow cat for more noticeable gains.
homelessmonkey is offline
Old 02-16-2014, 10:25 PM   #9
homelessmonkey
Fan#: 98498
