Help with 60' times? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 02-14-2014, 01:52 PM   #11
UltegraSTI
UltegraSTI's Avatar
Fan#: 466
What I Drive: 2001 Yellow Honey
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 1 UltegraSTI Good Standing Member
Spring rubbers in the rear coils, lower engine mount, max psi in rear tires, standard psi in fronts, spares n jack out, light on gas, good wash n wax, all excess stuff out of car, remove driver's floormat, no burnout box, seat as forward and she can go, backseat folded down and tucked, ac traction control fans radio etc off, fresh fluids/service, clean shifts, alignment check, filter checks, best fuel u can get.
I have more but if you do all these things and go back you will make that 14 second pass. Cruel truth about street tires is that they're very finicky, inconsistent, and not what you need as there is no secret to time and again making decent 60' passes you have to go with some stickier because you will gain a lot and then you can double that time game on the other end. simply how it works. R
2001 EggYolk Yellow Focus
14.90 @90.24mph
Best Trap: 91.75mph
2014 Cloud 9 White Focus ST
UltegraSTI is offline
Old 02-16-2014, 01:05 PM   #12
Whodatxevg
Whodatxevg's Avatar
Fan#: 109173
What I Drive: 2014 Tuxedo Black Focus ST1
Points 1,742, Level 24
Points: 1,742, Level: 24 Points: 1,742, Level: 24 Points: 1,742, Level: 24
Level Up 43% Completed
FF Reputation: 4 Whodatxevg Good Standing Member
https://www.youtube.com/watch?v=EjOk...e_gdata_player
Here's a video I took Friday, back tires were at max pressure and spare tire, jack were removed. Everyone was running slow that night, best time was a 15.2 which happened to be the one video I have. Did notice my 60's were on average about .05 better, so I'll keep that in mind.
If I'm doing good, great; if not I'm listening.
'13 Oxford White sedan 5 speed. (SOLD)
15.00x @94.3
"Spirit of John Force" driver mod
Whodatxevg is offline
Old 02-17-2014, 12:59 PM   #13
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
Points 4,550, Level 42
Points: 4,550, Level: 42 Points: 4,550, Level: 42 Points: 4,550, Level: 42
Level Up 50% Completed
Forum Activity 3%
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
Sounded like the engine bogged down from 1:22- 1:24, quicker release while giving more throttle during release.
NJSVTGUY is offline
Old 02-23-2014, 08:10 AM   #14
UltegraSTI
UltegraSTI's Avatar
Fan#: 466
You are going around the water right?
Can we see the slip?
Does the new car have a different final drive? I see you stay in 3rd thru the traps. We couldn't do that in the old car unless we wanted to trap out at 82-85mph (based on tire size).
What rpm are you shifting?
What is the 60' time now? Was never really a fan of blipping the throttle and then feeding clutch trying to catch and slip it out. Some folks don't like it, but i am a neutral dropper. Clutch had 165k, 3 seasons of dragging, and still functional when the zetec got retired during this swap project. Your shifts are too slow (short shifter?) and too much clutch between gears. I hope you are not flat shifting b/c if so than the application is not right listening to the engine in the video.
92mph-Yes that can drop a touch if you drop your 60'. But yours didnt drop alot but you lost 1.5mph or so. Might be time for a dyno to see where she is happy but i think u are already close. Also prolly time (as much as you are doing this) to purchase a cheap portable weather station (or an app for ur phone that does same). it can really tell you a lot about track conditions before you get a whiff of the burnout box. The station could very well have told you that it was just not as good a night to get a hot time. Two words- Density Altitude. You start rocking that shite, you will baffle your friends and the honda punx knowing when to run and when to not on top of knowing about what your car will run before you do it. Check this out for some easy to digest info.
http://justdragracing.com/drag-racin...r-stations-101
Keep up the good work.
R
14.90 @90.24mph
Best Trap: 91.75mph
Old 02-23-2014, 08:20 AM   #15
Whodatxevg
Whodatxevg's Avatar
Fan#: 109173
This was the car's best
Shifting at 7100-7200 RPM
Going through the traps around 7000 RPM
Not flat shifting, the clutch just isn't happy with me on 1-2 WOT shifts (I'll probably need a better one).
Also not shifting as fast as possible because at the end of the day it is still a daily driver.
After a few times of experimenting with rear tire pressure I can get a few 2.1 60's.
I have noticed weather makes a huge difference at the track.
15.00x @94.3
Old 02-23-2014, 08:35 AM   #16
UltegraSTI
UltegraSTI's Avatar
Fan#: 466
i meant lets see the 15.2 slip.
Your 1-2 is prolly fugly b/c u you are using so much clutch. Shift faster with less clutch. What happens if you get it wrong? You miss a gear and abort the run. Come back and try again.
R
14.90 @90.24mph
Best Trap: 91.75mph
Old 02-23-2014, 08:39 AM   #17
Whodatxevg
Whodatxevg's Avatar
Fan#: 109173
It looks like I might have misplaced it, I'll see if I have it on video somewhere.
15.00x @94.3
Old 02-23-2014, 08:44 AM   #18
Whodatxevg
Whodatxevg's Avatar
Fan#: 109173
2.203 - 60'
6.434 - 330'
9.864 - 1/8
71.36 - 1/8 mph
12.807 - 1000'
15.25 - 1/4
92.25 - mph
15.00x @94.3
Old 02-23-2014, 10:41 AM   #19
UltegraSTI
UltegraSTI's Avatar
Fan#: 466
yeh prolly not as good weather out and your 60' is on average with your other runs but it was all given away from 60-330. weather, grip, and 1-2 shift.
R
14.90 @90.24mph
Best Trap: 91.75mph
Old 02-26-2014, 11:06 AM   #20
Whodatxevg
Whodatxevg's Avatar
Fan#: 109173
It seems the next thing the car needs is a better clutch then, all the runs at the track have taken their toll.
15.00x @94.3
