My MPG lowered. Want help to fix - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-14-2014, 07:17 PM   #41
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,312, Level 75
Points: 13,312, Level: 75 Points: 13,312, Level: 75 Points: 13,312, Level: 75
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 99%
00CSVT's offered some good data, matches expected gains from a CAI.
The FSWerks race exhaust is quite loud, would work well as a reminder to feather the throttle to avoid excessive noise. There's a current discussion on race vs. stealth exhausts in the MkIII section if you don't want to search back thru the Duratec section for opinions.
LONG thread on spark plugs can be found in the duratec performance section. The Autolite 103/104 plugs (different heat ranges) were proven to provide a slight improvement in H.P. on a Dyno, but that was only when fresh. IIRC you'd have to change them as often as your oil for a performance advantage, not much longer than that they would be worn out. No info there on MPG improvement IIRC.
Looking into those plugs & trying them would be a worthwhile experiment. Stocks can last the 100,000 service interval but pulling them to never-seize the threads is a good idea by half that, left too long they can seize in the head.
There's one more thing to research & try out at least. The autolite's could use regular checks to see how they're working, save the originals as back ups.
Cheers
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 02-14-2014, 07:27 PM   #42
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,271, Level 46
Points: 5,271, Level: 46 Points: 5,271, Level: 46 Points: 5,271, Level: 46
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 6 SlickWilly Good Standing Member
Originally Posted by jwindbigler View Post
...and so the fighting begins. Slick, even though that Ive only been on here for like 2 whole weeks now, this is the second argument ive seen you responsible for. Why so much animosity? Why be argumentative?
Both arguments were sparked by crice about the same exact thing you should note. Sorry for trying to save you hundreds in wasted mods, waste a grand on your car, not my worries just trying to help. In fact I offered more help in both threads and out of us two am the only one to help you, help you save thousands. Good call.
09 4F27E - K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - Nitrous Express Proton EFI - NX Launch Control & Progressive timer - NOS Window Switch
SlickWilly is offline
Old 02-14-2014, 07:31 PM   #43
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Here's the duratec spark plug sticky for your information:
http://www.focusfanatics.com/forum/s...ht=Spark+Plugs
That's one worthwhile experiment you can try, and your plugs are due to come out to never-seize the threads so they don't freeze into the head from corrosion anyways. Save the old ones for backup/comparison.
"Rubber Side Down"
sailor is offline
Old 02-14-2014, 11:13 PM   #44
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
I believe he is talking about a different instance that had nothing to do with me man. I have seen you get in to it with many people on here... even as soon as you started becoming more active on the forum. You kind of remind everyone of Mac. And I'm not just saying that because of our recent disagreements. I'm over the argument here and I apologize to the OP and other members of the thread that it has affected. I choose to agree to disagree. No hard feelings at all.
Galatians 6:14
crice8 is offline
Old 02-15-2014, 08:19 AM   #45
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
I thought this was a thread about fuel economy?
1) CAIs help. If that hasn't been covered. Clean your MAF regularly for at least 2 months if you're using an oil infused filter in your CAI. Oil will throw off your MAF reading in a bad way making you run rich until the O2 sensor catches up on the back end.
2) Exhaust might help, but too much exhaust will drop your fuel economy. Cat-backs are ok, but ORPs and removing a cat can be too much for a stocker.
3) Regular maintenance is most important- change those fuel filters every 20-30k unless you have an 08+.
4) AR103 or 104 plugs are best, and the only mod you can make to ignition that does anything worthwhile. These cars have the best type of ignition there is. The bummer is that you need to check those frequently to clean off deposits and replace when needed. Lazy people would simply replace at 25k. I knew an old guy who used to just clean and re-gap until there wasn't anything to left to gap. The heat range is important, you don't want to run the colder plugs in winter unless you block off your radiator. You'll just waste fuel.
5) Definitely block off part of your radiator in the winter. The 05 came from the factory with a 160F thermostat (mine did), but Ford changed that to a more normal 194F in 06. I wouldn't suggest changing the thermostat because it's so expensive. You can watch your temp using the electronic odometer trick, but I highly recommend blocking off as much of the radiator as you can when temps are below 50F. You 06+ people should double check your temps with the electronic odometer. This has given me a 3 mpg boost as compared to running without the radiator blocked and with winter blend fuel.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 02-15-2014, 09:42 AM   #46
crice8
crice8's Avatar
Fan#: 84830
All terrific info! I have seen the radiator blocking method on ecomodder.com turn out great for many people. I live in Texas so it's not really worth it for me to try (:
I highly suggest going to ar103 or 104 plugs as well. All 4 will cost you less than $10. $10 every 10k miles is a small price to pay for the benefits you would keep up. It's actually much cheaper than changing your oil (:
Galatians 6:14
crice8 is offline
Old 02-15-2014, 11:52 AM   #47
jwindbigler
Fan#: 139441
What I Drive: 2007 Maroon Focus
FF Reputation: 1 jwindbigler Good Standing Member
How does one block off a section of the radiator? Just put a piece of cardboard in front of the radiator?
I have a 2007 focus. JSYK
jwindbigler is offline
Old 02-15-2014, 03:36 PM   #48
crice8
crice8's Avatar
Fan#: 84830
Check out ecomodder.com it will explain how in great detail. There are also many more suggestions on how to increase mpgs.
Galatians 6:14
crice8 is offline
Old 02-15-2014, 08:21 PM   #49
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
IIRC Whynot just covers the cardboard with Duct Tape to keep it from falling apart...
"Rubber Side Down"
sailor is offline
Old 02-16-2014, 06:22 PM   #50
jwindbigler
Fan#: 139441
Ill be sure to check them out. Thank you
