2 problems... Lights and idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-10-2014, 02:34 AM   #1
Mgrwc14
Fan#: 141065
What I Drive: 2004 silver SE PZEV
FF Reputation: 1 Mgrwc14 Good Standing Member
1. The lights kind of flicker (all lights: dash, headlights, roof light) when idling. But when I give it gas it is fine. Idk what it is...
2. I don't have a rpm gauge but I can kind of feel an up and down idle... Not too bad but I know it's there and it's annoying and there's some vibration when at idle too..
Mgrwc14 is offline
Old 02-10-2014, 07:23 AM   #2
FordZX32000
Fan#: 33469
What I Drive: 2000 black ZX3
Points 982, Level 16
Points: 982, Level: 16 Points: 982, Level: 16 Points: 982, Level: 16
Level Up 82% Completed
FF Reputation: 1 FordZX32000 Good Standing Member
Possibilities...
Issue#1 Could be the alternator getting ready to crap out or a ground wire that is not properly grounded.
Issue#2 Could be the passenger side motor mount. Doe's it vibrate more at start up and then less when the engine has warmed up ? If so that's a good sign of a bad mount.
FordZX32000 is offline
Old 02-11-2014, 12:30 AM   #3
Mgrwc14
Fan#: 141065
Issue 2 is fixed. Was the passenger motor mount! Feels like new!
The first issue is this there. Do you know where the main ground is? I know most cars have it on the fire wall... Is it on there? Please let me know..
Mgrwc14 is offline
Old 02-11-2014, 02:24 AM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,353, Level 75
Points: 13,353, Level: 75 Points: 13,353, Level: 75 Points: 13,353, Level: 75
Level Up 26% Completed
Forum Activity 99%
No single "Main Ground".
Closest is the ground from battery to engine block, but the small ones to the body from the battery are also important.
Connections from battery to wiring harness are worth checking as well, have caused problems for some.
Battery terminals themselves are a regular source of many issues.
For your issue, battery and alternator testing could help after you check the major grounds. (free at many parts stores)
You could check voltage at idle yourself for a start, shouldn't drop low at idle.
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
