Salvage engine questions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-09-2014, 09:42 PM   #1
Bonesacked
Bonesacked's Avatar
Fan#: 113745
What I Drive: 2000 Silver ZX3
Points 965, Level 16
Points: 965, Level: 16 Points: 965, Level: 16 Points: 965, Level: 16
Level Up 65% Completed
FF Reputation: 1 Bonesacked Good Standing Member
I'm going to need to buy either a salvage or rebuilt Zetec engine for my ZX3, due to the one that's in it being totally screwed up and not worth fixing. Has anyone here bought an engine from a salvage yard before? Are there any differences in any parts of the Zetec through the model years? I don't want to buy one off an '03, for example, then go to put it in only to find out all of the wiring harnesses have been changed.
How do they sell it, is it on the ground or running and in the car? I'm not buying any engine unless I can do a compression test on it, and that would be kind of hard if it's laying on the ground. If I hand cranked it with a ratchet, that should still give a valid compression reading, right? Won't having an (iron) engine laying around outside cause all of the coolant passages to completely rust out?
Really my main concerns here are compression and rust. I don't want to buy an engine that's the same or in worse state than the one that's already in the car.
Protip: NEVER buy a used car without doing a compression test on it. Ask me how I know. What a piece of shit!
Bonesacked is offline
Old 02-10-2014, 08:23 AM   #2
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,855, Level 25
Points: 1,855, Level: 25 Points: 1,855, Level: 25 Points: 1,855, Level: 25
Level Up 55% Completed
Forum Activity 3%
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
Obviously it should be much easier to install a motor of the same model year. Several years ago I had to replace the motor in my '05 ST, and was fortunate enough to find one only 300 miles away. It was in a big yard, still in the car, and sold to me with a 90 day warranty. I got a photo copy of the title certificate from the donor vehicle, for proof of origin of the "non-matching" motor's serial number. Because it was the same model year, installation was "plug and play". There should be many '00 Zetec motors around, although condition will be an issue, it will take some time to hunt one down. You might even find one in the classified section here, or on FJ. Good luck.
mainest is offline
Old 02-10-2014, 05:16 PM   #3
forddorf
Fan#: 31248
What I Drive: 2001 malibu blue zx3 / turbo-2004
Points 919, Level 16
Points: 919, Level: 16 Points: 919, Level: 16 Points: 919, Level: 16
Level Up 19% Completed
FF Reputation: 3 forddorf Good Standing Member
Their is not enough difference to worry about. If its a newer year you may need to swap injector harness (one has a square plug and one a rectangular plug going to the ecu depending on the year). Also make sure it has the proper cps before you install it ( the manual trans. takes different sensor then an auto trans.) The newer year cruise cable has a different end on it then the 2000 and 200l years (you can swap your throttle body over or change the cable to the new style)
forddorf is offline
Old 02-10-2014, 07:59 PM   #4
Bonesacked
Bonesacked's Avatar
Fan#: 113745
Crankshaft position sensor? I can just swap that off my engine to the new one, right? Are there any other mechanical differences between manual and auto trans engines?
Posted via FF Mobile
Old 02-13-2014, 01:28 AM   #5
Bonesacked
Bonesacked's Avatar
Fan#: 113745
NEVERMIND!
Protip: Make sure that your compression gauge is accurate, and that whoever is using it takes their damn time to make sure they select the proper adapter for the spark plug hole so it actually threads in and seals properly . I thought I had to do an engine swap! I did the test again today, except this time it was me who used the gauge. I got 149 PSI across the board, and leak down was 5-7% @ 100 PSI. Both tests were done on a cold engine. I think it's safe to say I don't need to do an engine swap!
Well, that was awkward. Carry on gents.
Old 02-13-2014, 01:39 AM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,791, Level 73
Points: 12,791, Level: 73 Points: 12,791, Level: 73 Points: 12,791, Level: 73
Level Up 86% Completed
Forum Activity 99%
Like the numbers, what's the status of plug pieces dropped in the cyl.?
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-13-2014, 01:44 AM   #7
Bonesacked
Bonesacked's Avatar
Fan#: 113745
Eh? Nothing was dropped into the cylinders .
Old 02-13-2014, 01:52 AM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
OOPS!
I was thinking of someone else looking at a junkyard engine.
(kicking my butt)
"Rubber Side Down"
Old 02-13-2014, 06:30 AM   #9
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 576, Level 11
Points: 576, Level: 11 Points: 576, Level: 11 Points: 576, Level: 11
Level Up 52% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
Now I can not say for 100% certainty on a Focus but when I have dealt with engine swaps on Contours the year of the engine itself didn't really matter. This is mainly for the Duratec but should also apply to the Zetec ... we always used the harness and fuel injectors/rail off the car the swap was being performed on, this included the assessories and sensors. The engine is mechanical and doesn't care what electronics, etc run it.
Now with what I know about the Zetec having VCT versus not having it, the year of the engine would make a difference.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is online now
