I Want my FOCUS back! - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Focus Tuning Chat
Old 02-06-2014, 02:57 PM   #1
brianintc
Fan#: 85972
What I Drive: 2004 Tan ZTW
FF Reputation: 1 brianintc Good Standing Member
I made the mistake of NOT using a memory saver when swapping in a fresh battery and lost 10 YEARS of learning on the PCM. Now my idle is messed up and my gas milage SUCKS! I have taken it in to TWO really good shops and they continue to tell me that my throttle body and/or IACV are bad. replaced both and .... NO F---ing difference. At this point I want to take control of the computer settings and tune it back to something closer to what I had before. I'm more concerned about MPG (already have a Stealth CAI) than performance. What is my best approach? New parts or FSWERKS ???
Any suggestions (even those correcting my approach or thinking) are welcome!!
brianintc is offline
Old 02-06-2014, 03:46 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,030, Level 100
Points: 51,030, Level: 100 Points: 51,030, Level: 100 Points: 51,030, Level: 100
Level Up 0% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
Buy-Sell-Trade Rating: (28)
What is it doing , why do the shops feel that you have IACV or TB issues
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 02-06-2014, 04:23 PM   #3
Phestezio
Phestezio's Avatar
Fan#: 97562
What I Drive: 2007 Oxford White ZX3
Points 1,268, Level 19
Points: 1,268, Level: 19 Points: 1,268, Level: 19 Points: 1,268, Level: 19
Level Up 68% Completed
Forum Activity 7%
FF Reputation: 4 Phestezio Good Standing Member
I'm with tom it would be nice to know what exactly its doing and why they think your having TB/IACV issues. Do you already have a flash tuner? If you don't you will have to get one if you want to tune it. but tom can probably help you or at least tell you whats going on. I would still recommend getting a tuner and a custom tune from tom if thats in the budget haha. It will run much better in the end with a custom tune from tom.
Phestezio is offline
Old 02-06-2014, 07:43 PM   #4
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,049, Level 33
Points: 3,049, Level: 33 Points: 3,049, Level: 33 Points: 3,049, Level: 33
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 11 hEaT Great Standing Member
What mods on the car? ALL you did was replace the battery and it's now idling off/bad mileage?
Verify you have good voltage at the battery, MAF wires look good, and you didn't break any vacuum lines.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 02-07-2014, 12:23 AM   #5
Gadabout
Gadabout's Avatar
Fan#: 114774
What I Drive: 2006 Vermillion Red ZX4 SE
Points 1,000, Level 16
Points: 1,000, Level: 16 Points: 1,000, Level: 16 Points: 1,000, Level: 16
Level Up 50% Completed
Forum Activity 2%
FF Reputation: 4 Gadabout Good Standing Member
Is replacing the battery really this big of a concern?? Im planning to upgrade mine later this year o_o
“Things work out best for those who make the best of the way things work out.” - J Wooden
Team Duratec #42
Gadabout is offline
Old 02-07-2014, 12:45 AM   #6
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 2 ferret15 Good Standing Member
not 10years
ferret15 is offline
Old 02-07-2014, 08:49 AM   #7
hEaT
Fan#: 20699
Not, not at all. The battery needs to be unhooked for at least 20min in order for the KAM to reset. If you hook up the new battery and your gauges don't sweep at key on, you've lost nothing.
If you want to reset idle, let the car fast idle for 5min or so after a good drive and it will be back to normal.
The OP has some other issue going on with the idle and bad gas mileage.
ZETEC Crew #49
hEaT is offline
Old 02-07-2014, 10:33 AM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 37%
Actually the KAM can set in less then 5 min it just depends on a lot of things
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 02-07-2014, 11:35 AM   #9
brianintc
Fan#: 85972
the base idle is up and does not want to "settle" once you put it in gear or press the gas then let off. also at start up (cold) it takes FOREVER for the idle to drop. it was never a problem before the battery replacement.
Old 02-07-2014, 11:36 AM   #10
brianintc
Fan#: 85972
they think the TB cuz ... and I quote "even a slight problem with the TB will cause problems". I don't think it's a valid diagnosis.
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
