How to reach 40MPG - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 02-06-2014, 04:32 AM   #1
jwindbigler
Fan#: 139441
What I Drive: 2007 Maroon Focus
FF Reputation: 1 jwindbigler Good Standing Member
How to reach 40MPG
Im a newb to focus tech. Ive heard several people saying that they get 40mpg, and I would like to reach that number. I average right about 30MPG. 32mpg if its all freeway. 26-28 if its mostly city.
Im no stranger to wrenching. Just to this platform. Ive heard getting it tuned will help, and I can only assume that its either by a shop, or by a handheld. So I would like to know which path is better.
Ive already got a STEEDA CAI system on her. I dont really want to put a loud exhaust on her, but something that flows a little better and still is quiet under 3000RPM would be nice. Recommendations, Videos?
Im curious to know if theres anything else that can be done to help with MPG. Thanks for the guidance guys.
jwindbigler is offline
Old 02-06-2014, 01:52 PM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,909, Level 59
Points: 7,909, Level: 59 Points: 7,909, Level: 59 Points: 7,909, Level: 59
Level Up 80% Completed
Forum Activity 38%
Activity: 38% Activity: 38% Activity: 38%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
If you want 40mpg, try driving 400 miles on flat ground at like 45mph... i dont see it happening other wise What speed are you averaging when you get 32mpg highway? Lowering that 5mph should be good for an extra mpg or two
The best quiet exhaust is FSWerks stealth, pretty tame at cruising speeds but sounds much better when you step on the gas. Its from the flexpipe back and is a solid unit, lots of us have it.
Help mpg by lowering weight, those are free mods. Some have gone to the extreme of removing everything insdie of the car short of the driver's seat. Best mpg gains will be with chaning the way you drive though...
edit, i deleted your other thread. please refrain from starting multiple threads asking essentially the same question.
rambleon84 is offline
Old 02-06-2014, 04:18 PM   #3
jwindbigler
Fan#: 139441
Thanks for the input
Old 02-06-2014, 05:04 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,458, Level 75
Points: 13,458, Level: 75 Points: 13,458, Level: 75 Points: 13,458, Level: 75
Level Up 52% Completed
Forum Activity 99%
http://www.focusfanatics.com/forum/showthread.php?t=368410
This thread was recently posted, it shows how important throttle position is to mileage as well as differences from the most efficient tune.
I got 38-39 on one long trip at steady 67, your mileage matches "normal" use (mine & others I've seen reported).
Anything that lets it roll easier so you need less throttle helps, removing extra weight & 5 psi over std. in the tires are the easiest steps. Conserving momentum as you drive is the other large improvement that's free.
Free breathing intake & exhaust, combined with a tune that helps MPG will give a gain, but it's not a magic bullet for high MPG.
Narrow Wheels & low rolling resistance tires would be the single biggest improvement, not a popular option since you lose braking/steering performance as a trade off.
If there was an easy way to get high MPG without any trade offs we'd all be doing it, takes real dedication to the cause to make an appreciable change as long as it's working right to begin with.
Luck
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-06-2014, 07:39 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,831, Level 76
Points: 13,831, Level: 76 Points: 13,831, Level: 76 Points: 13,831, Level: 76
Level Up 46% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Yo add to that^^^^ Lower your car & use lighter parts= lca's, brake rotors, calipers, exhaust manifold vs a header. There are a few parts that do make a weight reduction difference. I should have weight all the oem parts vs the aftermarket parts i added. I replace my Baer solid rotors w/ 2 piece ones & lost 2lbs per side. I can get over 400 miles on a tank on the hi-way.
felixthecat is online now
Old 02-07-2014, 12:16 AM   #6
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,347, Level 46
Points: 5,347, Level: 46 Points: 5,347, Level: 46 Points: 5,347, Level: 46
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 6 SlickWilly Good Standing Member
2009 Ford Focus, Lunchbox delete, slightly lowered, a little over a quarter tank in just normal cruising around. I generally don't drive hard at all, I say under 3K pretty much all the time and coast a lot when I can. I took this on the way to work today because of the 2008-2011 thread when we were talking about gas mileage.
09 4F27E - K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - Nitrous Express Proton EFI - NX Launch Control & Progressive timer - NOS Window Switch
SlickWilly is online now
Old 02-07-2014, 09:23 AM   #7
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 38%
http://imagizer.imageshack.us/v2/xq90/35/cux1.jpg
The '09 focus also is rated slighted better for mpg's over an '07 (33 vs 35 highway for the 5sp 2.0l) So you have a better starting vehicle
The problem with better mpg's and spending money to do so (if mpg is your sole goal) is the mpg savings at the pump will take the life of the car to offset the cost of new parts (often times you wont offset the costs.) It's a double edged sword at times...the best is to spend money on mods you like and enjoy for other reasons that may also increase mpg. Otherwise you'll spend more than you will gain back in mpg. The best things to do to see an improvement with out spending money is to ensure you have no extra weight in the car and pay attention to how you are driving (google tips on hyper-miling)
Old 02-07-2014, 09:36 AM   #8
SlickWilly
SlickWilly's Avatar
Fan#: 116476
Forum Activity 17%
My car is an auto. If my car is rated "35" which I don't believe it is for an auto, and I am getting 42 it clearly demonstrates that driving style has a great effect on MPG's. People generally ask how to get more but want to continue driving aggressively. You almost have to put yourself in the right mind set: I have no where to rush to, rushing will only cause mistakes and keep yourself calm behind the wheel. I don't rip turns fast, I don't worry about being first off the light, I sit back and enjoy cruising in my car. I also have no tickets because of this.
OP I know your a Camaro fan so let me tell you this. In my 94 Z28 I drove down from Western North Carolina to central Florida with my car completely packed full, I stopped a few times for gas (Wandering gas gauges in Chevy make me cringe, barely press the brakes and your tank reads E) and averaged over 25 MPG!
Old 02-07-2014, 09:54 AM   #9
FoFoTi
FoFoTi's Avatar
Fan#: 119990
What I Drive: 2014 hatch
Points 574, Level 11
Points: 574, Level: 11 Points: 574, Level: 11 Points: 574, Level: 11
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 FoFoTi Good Standing Member
Also stay on top of tire PSI (need to invest in a gauge)
2014 Titanium hatch, DCT, handling package, blue candy
FoFoTi is offline
Old 02-07-2014, 09:58 AM   #10
SlickWilly
SlickWilly's Avatar
Fan#: 116476
Forum Activity 17%
Yes this! My light is on because of my wheels don't have my sensors in them. I used to leave the sensors in my glove box and the light would stay off, but I like having room in my car plus I felt like I would loose them.
