Intelligent Access "Key Battery Low Replace Soon" message - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-05-2014, 05:20 PM   #11
AndoverHorseMom
Fan#: 139833
What I Drive: 2012 Gray Focus Titanium
FF Reputation: 1 AndoverHorseMom Good Standing Member
There isn't a way to reset it from the system status menu. I have already tried that!
AndoverHorseMom is offline
Old 02-05-2014, 08:26 PM   #12
aaron.b
aaron.b's Avatar
Fan#: 98162
What I Drive: 2012 focus ti
Points 1,085, Level 17
Points: 1,085, Level: 17 Points: 1,085, Level: 17 Points: 1,085, Level: 17
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 1 aaron.b Good Standing Member
I'm telling you get a new battery. I've known a number of people to buy these without a full charge or defective. Expiration/shelf life doesn't always mean it's a good battery.
aaron.b is online now
Old 02-05-2014, 11:43 PM   #13
Kabigon
Fan#: 88299
Points 4,382, Level 42
Points: 4,382, Level: 42 Points: 4,382, Level: 42 Points: 4,382, Level: 42
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 10%
FF Reputation: 11 Kabigon Great Standing Member
Originally Posted by AndoverHorseMom View Post
Kabigon--How long did it take for the message to eventually disappear on your car? Looks like you have the same make/model as my Focus. So far, it's been four days and the message is still displaying each time I start the car. The batteries that were installed were fresh 10-year expiration date batteries, so I'm not concerned that they were past their shelf life. Both FOBs give me the same message. Disconnecting the battery seems like a slipshod way to accomplish something, in my opinion.
I believe it took about 1 week.
At first, I was scratching my head but I decided to give it some time and see what happens.
I imagine that there may be a way to reset it (other than disconnecting the battery) but I didn't bother to research it.
I am Kabigon and I approve this message.
Kabigon is online now
Old 02-05-2014, 11:46 PM   #14
Kabigon
Fan#: 88299
Forum Activity 10%
Originally Posted by suss6052 View Post
When does the error go away then if it doesn't turn off with a new battery? That's been the advice given by others who've had the same issue after changing the battery with no change in status.
Please read my previous reply.
I really don't like resetting all of the modules (especially the PCM) unless there is a compelling reason to do so.
Another alternative would be to pull the fuse for the module that needs resetting (i.e. MFT/Sync reset).
Old 02-05-2014, 11:53 PM   #15
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,042, Level 66
Points: 10,042, Level: 66 Points: 10,042, Level: 66 Points: 10,042, Level: 66
Level Up 98% Completed
Forum Activity 24%
Pulling fuses didn't seem to work on my car for resetting the MFT, it would remove power from the affected sub-system and possibly cause it to reboot, however apart from one time when it seemed to forget the drive it was still not reset and went right back to the previous track after the crash. The fix then was to take a different USB drive when the original one that worked fine in the car with the basic sync system failed to index and caused MFT to go into a seizure/ reboot loop every time it was used.
Just copy and pasted the files onto a clean drive and it worked, some how the original one went bad even though the drive was fine.
I don't really like the idea of pulling the battery either, but that was something that works, and speeds up the process at the expense of potentially losing some of the keep alive memory for other systems you'd prefer not to reset.
suss6052 is online now
Old 02-06-2014, 12:20 PM   #16
FordIVTteam
Official Ford Rep
FordIVTteam's Avatar
Fan#: 87765
What I Drive: Ford Focus
Points 2,192, Level 28
Points: 2,192, Level: 28 Points: 2,192, Level: 28 Points: 2,192, Level: 28
Level Up 28% Completed
Forum Activity 2%
FF Reputation: 3 FordIVTteam Good Standing Member
Hey, everyone!
I just want to jump in real quick with a few things. I do not recommend a battery pull (on your vehicle) unless it is advised or done by your dealer. Also SYNC/MFT is not tied in to Intelligent Access Key (IAK), so a fuse pull for SYNC is not needed. For questions or issues with IAK, please shoot a private message over to Todd. Here's the link to his profile:
http://www.focusfanatics.com/forum/member.php?u=79824
Hope you're all having a great week!
Rebecca
FORD IN-VEHICLE TECHNOLOGY TEAM
p: 800.392.FORD (Prompts 1 then 3)
f: facebook.com/FordFocus facebook.com/Ford
FordIVTteam is offline
Old 02-06-2014, 02:06 PM   #17
Kabigon
Fan#: 88299
Forum Activity 10%
Resetting MFT/Sync was simply used as an example of resetting a module.
It was not stated or implied that Sync and the IAK are somehow tied together.
Old 02-06-2014, 10:13 PM   #18
2013TitaniumHatch
Fan#: 113545
What I Drive: 2013 Silver Titanium Hatch
FF Reputation: 1 2013TitaniumHatch Good Standing Member
http://www.cmaxownersclub.co.uk/foru...message-11427/
post#4
I had the same problem occur on my 2011 C-Max Titanium last weekend, and after replacing the batteries in the key remote, the error message remained.
I took my car into my local Ford dealer and they ended up having to carry out a BCM software update. This cleared the alarm issue.
post#12
If your key fob battery needs changing there is no need to go to the dealer to reset the message on the trip computer.you just use the arrow keys on the steering wheel and navigate to the information menu -->system status and press the ok button to reset.
2013 Focus Titanium Hatch * Ingot Silver * Handling Package
2013TitaniumHatch is offline
Old 02-07-2014, 08:22 AM   #19
FordIVTteam
Official Ford Rep
Fan#: 87765
Forum Activity 2%
I was just clarifying for the people that didn't know that, Kabigon.
Rebecca
Old 02-07-2014, 10:20 AM   #20
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,341, Level 41
Points: 4,341, Level: 41 Points: 4,341, Level: 41 Points: 4,341, Level: 41
Level Up 96% Completed
Forum Activity 6%
FF Reputation: 9 darkangelism Good Standing Member
Same thing happened to me, about a week as well.
2012 Ti Hatch
Sonic Crew #04
Steeda SRI/Newmission | Steeda RSB | SMC Replica ST Wing | SMC Aluminum Oil cap | Injected Tune | 2.5" custom exhaust
darkangelism is offline
