Starting to become less and less impressed with the Focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-01-2014, 04:19 PM   #1
FX4life
FX4life's Avatar
Fan#: 99227
What I Drive: 2012 White Platinum Titanium
FF Reputation: 1 FX4life Good Standing Member
I'm starting to become increasingly disappointed in my 2012 Titanium w/10,000 kms (Yes, only 10,000. It was solely an RV tode and spent most of it's life behind an RV without the odo running before I started DD'ing the car). With this winter causing rutted side-streets especially in front of my house, my interior and front end are rattling like crazy. Seriously, this car sounds like a 15 year old Geo Metro inside. The interior rattles so much that I have a hard time hearing the various noises the front end makes. The passenger door panel makes this bad vibration rattle when I start it up in the morning (driver's side is starting to do it) the rear door panel makes the same noise when I drop the bass. I know it's only a $24k car, but even my 2010 Mitsubishi Lancer GTS w/94,000kms didn't rattle as much as this one does.
As far as the front end goes, we have an RV flat-tow baseplate and tow-bar prep kit installed but I know it's not causing the noises. Over speed bumps the struts creak, and over sharp ruts there's a really raunchy knocking/rattling from what sounds like the steering box or strut towers. It's really quite embarrassing actually. It sure doesn't feel like a solid car like the otherwise excellent interior quality suggests it to be. I've been to the dealer and they were unable to find the problems in the front end, and whatever they did with the passenger's side door panel didn't fix it. I'm hesitant to go back to the dealer again knowing they might waste my time.
Any suggestions or experiences?
2012 White Platinum Titanium Hatchback - Loaded - 35% tint, Bridgestone Blizzak WS70 winter tires
2013 Oxford White F-150 FX4 5.0 Supercrew - Loaded - Tint-to-match, Wheel-well liners, 3M Protection, Spray-in bedliner
FX4life is offline
Old 02-01-2014, 04:23 PM   #2
VOLDAR
VOLDAR's Avatar
Fan#: 90444
What I Drive: Volt 2014, White Diamond
FF Reputation: 3 VOLDAR Good Standing Member
Change your dealer. The rest it's all on you.
White Platinum Metallic Tri-Coat
303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package,
Parking Technology, Navigation, Winter Package
---replaced by---
Chevy Volt 2014, White Diamond, Luxury Package, S1, Navigation.
VOLDAR is offline
Old 02-01-2014, 04:35 PM   #3
wavsine
wavsine's Avatar
Fan#: 118470
What I Drive: 2013 Focus SE Oxford White Hatch 5m
Points 18,989, Level 87
Points: 18,989, Level: 87 Points: 18,989, Level: 87 Points: 18,989, Level: 87
Level Up 28% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 16 wavsine Great Standing Member
Let's take this one step at a time.
First, you need to go to a different dealer. If they say they can't find anything, they haven't even looked up the technical service bulletins on your car. Have these TSBs performed on your car to address your concerns:
TSB 13-5-11
CRUNCHING OR CREAKING-TYPE NOISE FROM
FRONT OF VEHICLE—LOW SPEED TURNS AND
BUMPS
TSB 13-12-9
CLUNK/RATTLE NOISE FROM FRONT END DURING
PARKING MANEUVERS AND/OR OVER ROUGH
SURFACES AT LOW SPEEDS BETWEEN 8-32 KM/H
5-20 MPH)
Use a Motorcraft FL-400S filter to increase filtration media and oil quantity. (Drop in for FL-910S)
Synthetic oil in GDI engines
www.focusfanatics.com/forum/showthread.php?t=324396
wavsine is online now
Old 02-01-2014, 05:06 PM   #4
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
Interior rattles are pretty tough to isolate in this car. I have a couple that come and go depending on the weather and I have not been able to isolate the source - neither has the dealer. I had one in the dashboard the dealer did finally isolate and fix.
As much as others seem to want to blame you, the fact is that in this day and age a manufacturer should be able to assemble a car that isn't a rattle box. My hondas didn't rattle, my jeep grand cherokee didn't rattle. My wife's buick doesn't rattle.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 02-01-2014, 07:22 PM   #5
lewisra
Fan#: 93289
What I Drive: 2012 Tuxedo Black SEL
Points 1,395, Level 20
Points: 1,395, Level: 20 Points: 1,395, Level: 20 Points: 1,395, Level: 20
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 3 lewisra Good Standing Member
Mine is rattle free.
lewisra is offline
Old 02-01-2014, 09:25 PM   #6
DustyAlex
Fan#: 107712
What I Drive: 2012 Sonic Blue SE
Points 740, Level 14
Points: 740, Level: 14 Points: 740, Level: 14 Points: 740, Level: 14
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 1 DustyAlex Good Standing Member
My pass door rattles, every now and again the driver's pillar (sounds like) And the dash (removed everything and still does it)
Labour rate is $60 an hour, if you already tried to fix it $80 an hour, and if you want to help me $100 an hour
DustyAlex is offline
Old 02-01-2014, 10:48 PM   #7
Kjanracing
Kjanracing's Avatar
Fan#: 135409
What I Drive: 2014 Ruby Red SE hatch with DCT
Points 503, Level 10
Points: 503, Level: 10 Points: 503, Level: 10 Points: 503, Level: 10
Level Up 6% Completed
FF Reputation: 2 Kjanracing Good Standing Member
My 2010 Honda Insight rattled more than any car I've ever owned. Rough ride, suspension creaks, NAV screen rattled, road noise...I love my quiet Focus.
Kjanracing is offline
Old 02-02-2014, 04:41 AM   #8
mechanizeddeath
mechanizeddeath's Avatar
Fan#: 135913
What I Drive: 2012 Ingot Silver Metallic SE
Points 1,641, Level 23
Points: 1,641, Level: 23 Points: 1,641, Level: 23 Points: 1,641, Level: 23
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 1 mechanizeddeath Good Standing Member
No rattles in mine, and it has 85k miles on it.
Actually, there might be rattles, but the car I came from rattled and squeaked so much, I could be driving a can of ball bearings down the road and would probably think it was quiet. So I'm probably not the best judge of it.
mechanizeddeath is offline
Old 02-02-2014, 06:32 AM   #9
2kwik4u
Fan#: 102523
What I Drive: '12-Sonic Blue-5dr/5spd/203A/Roof
FF Reputation: 1 2kwik4u Good Standing Member
Mine to rattles creaks and clunks. While annoying that my 18mo old car does this, it's the confidence sucking feeling that bothers me the most. I trust or 7yr old '06 A4 more than I trust this car. It really shouldn't be that way.
What's worse is this is my first Ford since '94 and I think they've lost me again. Living in a Ford town that's rather unfortunate.
2kwik4u is offline
Old 02-02-2014, 08:47 AM   #10
Ausv7
Ausv7's Avatar
Fan#: 84217
What I Drive: 2012 Black Focus, 1994 black F150
Points 2,641, Level 31
Points: 2,641, Level: 31 Points: 2,641, Level: 31 Points: 2,641, Level: 31
FF Reputation: 3 Ausv7 Good Standing Member
Honestly they should deal with these issues before shipping it. I am a benz tech and we never let a car leave with a noise unless the customer doesnt want to pay for the repair. Its your dealer thats the issue, change that to a much better one
Team Focalize
rebeldevil.com
Texas Focus Round Up Best Stance
Ausv7 is offline
