'06 gfx Foglight troubles - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-28-2014, 06:28 PM   #1
Mobius
Mobius's Avatar
Fan#: 138393
What I Drive: 2006 Focus zx4 gfx, 2002 Focus SVT
Points 39, Level 1
Points: 39, Level: 1 Points: 39, Level: 1 Points: 39, Level: 1
Level Up 78% Completed
FF Reputation: 1 Mobius Good Standing Member
Hi there, i was hoping someone had some advice as too what my problem could possibly be;
i recently bought my focus and decided to switch out the standard foglight bulbs for yellow Hella H1's and everything went smoothly until i tested them and the driver side light decided not too turn on, ive been trying to figure out whats going on for over an hour now and i havent got a clue what the issue is. the bulb, connector and wiring are all fine, i tested them before hand and they are working as of the moment i am writing this, but once I place them in the housing, nothing.... passenger side took all of three minutes to replace and works perfectly. so im at a loss, has anyone had this issue??
also i did look through all the walk through's and searched the forums before posting so if ive missed this topic previously i apologize.
Mobius is offline
Old 01-29-2014, 02:55 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,449, Level 75
Points: 13,449, Level: 75 Points: 13,449, Level: 75 Points: 13,449, Level: 75
Level Up 50% Completed
Forum Activity 99%
Best guess I've got is that something's getting "tweaked" when you put them in the housing, poor contact at connector is my guess. Wiring's a possibility too, but try wiggling at the connector the same way they are when installed first.
Look close for corroded/broken contacts in the connector, if it's not too bad just plugging the bulb in a few times will clean a bit.
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 01-29-2014, 05:16 PM   #3
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,322, Level 98
Points: 28,322, Level: 98 Points: 28,322, Level: 98 Points: 28,322, Level: 98
Level Up 98% Completed
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
does it do the same thing when you reinstall the old bulb?
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 02-03-2014, 11:28 AM   #4
Mobius
Mobius's Avatar
Fan#: 138393
Points 39, Level 1
apparently it was just a poor seal around the housing causing it to get knocked out, i knew it was going to be something dumb, luckily my mechanic doesnt charge me anything to put the car on the lift so it was relatively easy to fix.
Mobius is offline
