Ported throttle Body - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-06-2014, 03:20 AM   #71
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
FF Reputation: 49 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
I'm not going to give you the answer. Use Google. Learn something new. I promise it won't hurt and will be very useful.
iminhell is offline
Old 03-06-2014, 01:59 PM   #72
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 339, Level 6
Points: 339, Level: 6 Points: 339, Level: 6 Points: 339, Level: 6
Level Up 78% Completed
Forum Activity 6%
FF Reputation: 1 GhostTribute Good Standing Member
Originally Posted by iminhell View Post
You have a circle with a diameter of 3" and one with a diameter of 4".
What is the total air pressure exerted on each?
The total air pressure exerted on a 3" dia. circle and a 4" dia. circle would be the same given they are at the same atmospheric pressure. Where you are asking about air pressure on an area at least. Now, if we are talking about hydrostatic pressures and the increase or drop in pressure between two different diameters of pipe (cylinder), that is a different calculation all together.....
GhostTribute is offline
Old 03-06-2014, 06:22 PM   #73
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 19%
I probably worded it wrong. Though I don't believe I did.
Think about air pressure more, you might be onto something ...
iminhell is offline
Old 03-06-2014, 06:28 PM   #74
MakatoMotors
MakatoMotors's Avatar
Fan#: 109381
What I Drive: 2012 Oxford White SE
Points 316, Level 6
Points: 316, Level: 6 Points: 316, Level: 6 Points: 316, Level: 6
Level Up 32% Completed
FF Reputation: 2 MakatoMotors Good Standing Member
If you not not going to give help or opinions, why are you even posting?
'12 Focus Hatch SE
Magnaflow Exhuast, AEM CAI, Eibach Prokits Springs, RokBlokz Mudflaps, RS style hood, RS Spoiler, 18" MSW 25 Wheels
MakatoMotors is offline
Old 03-06-2014, 07:04 PM   #75
Gennylight13
Fan#: 119502
What I Drive: 2013 rally red focus hatch se
Points 42, Level 1
Points: 42, Level: 1 Points: 42, Level: 1 Points: 42, Level: 1
Level Up 84% Completed
FF Reputation: 1 Gennylight13 Good Standing Member
throttle body
Originally Posted by Bcardwell101 View Post
my tb will be in a 4:30 today ohio time im going to try to install today and give my thoughts tonight or tomorrow. i dont even know any place i could dyno at in ohio im sure there are some in columbus i could get to but ill try to have all numbers of everything as soon as i can so everyone can see whats going on with my end of things. trying to help as much as i can should have things posted in a week or as fast as i can get a dyno with list of all my mods.
how much was the throttle body and do you have an intake to go with the throttle body?
Gennylight13 is offline
Old 03-06-2014, 07:04 PM   #76
goingtoscotland
goingtoscotland's Avatar
Fan#: 132001
What I Drive: '14 Tuxedo Black HB, 05 Kawi ZX-10R
Points 1,954, Level 26
Points: 1,954, Level: 26 Points: 1,954, Level: 26 Points: 1,954, Level: 26
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 6 goingtoscotland Good Standing Member
More pressure=less volume, people.
Though my point doesn't change. When the volume the tb is capable of providing already exceeds the amount of air needed you're not going to gain anything.
goingtoscotland is offline
Old 03-06-2014, 07:08 PM   #77
goingtoscotland
Fan#: 132001
Unfortunately unless you have a baseline at almost identical conditions with the stock TB having your car dyno'd with the new TB will be pointless with respect to gains(or losses for that matter)
Old 03-06-2014, 07:27 PM   #78
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 19%
I was trying to teach you something rather than feeding you. I've never found feeding to work well or stick.
You're missing variables and therefore incorrect.
________________________________________________________
Air Pressure.
We refer to it in terms of Pounds per Square Inch. That is how much force is exerted on a surface. One square inch of surface has ~14.7 Pounds of (downward) force on it.
If you apply that to my question,
a 3" diameter has,
Pi*R^2 area, 3.14*1.5^2 = 7.065 square inches, 7.065*14.7 = 103.8555 pounds of force
a 4" diameter has,
Pi*R^2 area, 3.14*2^2 = 12.56 square inches, 12.56*14.7 = 184.632 pounds of force
Understand how an increase in diameter translates into more flow?
iminhell is offline
Old 03-06-2014, 07:53 PM   #79
goingtoscotland
Fan#: 132001
And you have a complete misunderstanding of fluid dynamics and how they come into play in a restriction
That's static air pressure(at sea level), and has nothing to do with velocity or volume. Not sure where you're even going with that? If you take a throttle body and reduce the size you will lower pressure IN the restriction, increase velocity in the restriction, and decrease the maximum amount of air that restriction is capable of flowing in whatever measurement you decide to use. Should you increase the size of the restriction you will DECREASE PRESSURE in the restriction AND DECREASE VELOCITY, and INCREASE VOLUME. Smaller opening=higher velocities. Higher velocities=lower volume.
So yes. a larger opening will increase volume, but pressure isn't involved in the way you think it is.
A larger TB on an FI car will net you good gains because it produces WAY more suction than an NA motor.
edit: reworded. Content the same
Old 03-06-2014, 08:11 PM   #80
Jburks
Jburks's Avatar
Fan#: 145009
What I Drive: 2014 Ford Focus Hatchback SE RR DCT
Points 4,935, Level 44
Points: 4,935, Level: 44 Points: 4,935, Level: 44 Points: 4,935, Level: 44
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 1 Jburks Good Standing Member
just post dyno numbers and end all of this argueing!!
2014 Focus SE DCT RR. "Fiona"
Mods- Green Drop in-Snorkel Delete-plastidip-RokBlokz
Instagram- _jburks_
Build thread-http://www.focusfanatics.com/forum/showthread.php?t=382642
Jburks is offline
