Ported throttle Body - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-05-2014, 12:34 AM   #61
goingtoscotland
goingtoscotland's Avatar
Fan#: 132001
What I Drive: '14 Tuxedo Black HB, 05 Kawi ZX-10R
Points 1,954, Level 26
Points: 1,954, Level: 26 Points: 1,954, Level: 26 Points: 1,954, Level: 26
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 6 goingtoscotland Good Standing Member
Most likely no gain to be had for the n/a guys. If the 57mmtb can handle 250hp on the ST it's more than enough for the n/a Focus
goingtoscotland is offline
Old 03-05-2014, 04:47 PM   #62
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 550, Level 10
Points: 550, Level: 10 Points: 550, Level: 10 Points: 550, Level: 10
Level Up 50% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
Your logic is flawed.
The ST and the n/a Focus share the exact same air box. If the airbox can handle enough air to support 252hp, then replacing it on the 160hp n/a Focus would yield very little if any gains (using your logic), right? Yet we've seen dyno results showing as much as 20hp gains from replacing the airbox with a well designed intake on the n/a Focus.
My point is this; just because the 57mm tb can handle enough air to support 252hp on the ST doesn't necessarily mean that the n/a Focus wont see any power benefit from the 59mm tb. We will have to wait on the dyno results to be sure.
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 03-05-2014, 04:58 PM   #63
Eminaga
Eminaga's Avatar
Fan#: 123953
What I Drive: 2014 Focus SE (Performance Blue)
Points 1,192, Level 18
Points: 1,192, Level: 18 Points: 1,192, Level: 18 Points: 1,192, Level: 18
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 24%
FF Reputation: 1 Eminaga Good Standing Member
well someone needs to already get a car dynoed with the TB :D
*Snorkel/Shroud Delete, ITG Filter, Full ST Exhaust, E-RMM, Steeda RSB, Vogtland Springs, 180* T-Stat, Custom SCT Tune by Tom @ Focus-Power*
Eminaga is offline
Old 03-05-2014, 05:16 PM   #64
Jburks
Jburks's Avatar
Fan#: 145009
What I Drive: 2014 Hatchback SE RR DCT "Fiona"
Points 6,036, Level 50
Points: 6,036, Level: 50 Points: 6,036, Level: 50 Points: 6,036, Level: 50
Level Up 44% Completed
Forum Activity 79%
Activity: 79% Activity: 79% Activity: 79%
FF Reputation: 2 Jburks Good Standing Member
^^^^^ agreed get er' done!
Green Filters drop in-Snorkel Delete-Steeda RSB-Fswerks RMM insert-Focus Power Tune.
Build thread-http://www.focusfanatics.com/forum/showthread.php?t=382642
Jburks is offline
Old 03-05-2014, 06:39 PM   #65
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,285, Level 46
Points: 5,285, Level: 46 Points: 5,285, Level: 46 Points: 5,285, Level: 46
Level Up 68% Completed
Forum Activity 14%
FF Reputation: 6 SlickWilly Good Standing Member
Funny that you make fun of someone else's logic of comparing it to a turboed car, when you compare the air box's without understanding a turbo.
09 4F27E - K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - Nitrous Express Proton EFI - NX Launch Control & Progressive timer - NOS Window Switch
SlickWilly is offline
Old 03-05-2014, 07:04 PM   #66
Deesiel678
Deesiel678's Avatar
Fan#: 105147
Funny that you assume that I don't know how a turbo works. Where in my post did I indicate that? And where did I 'make fun'? I was pointing out the flaw in thinking by using a well documented example.
Slap yourself for failing to comprehend.
Old 03-05-2014, 08:40 PM   #67
goingtoscotland
Fan#: 132001
You're not seeing results from the box itself so much as you're seeing results because you're not only removing some restriction which allows more air to flow through the box(a freer flowing aftermarket air filter vs stock), but also from a more dense intake charge thanks to lower temperatures. This is why dyn085's dyno results on a K&N drop in with the stock airbox show an 8+hp gain. A 2 mm larger hole going into the intake isn't going to help when the previous hole was capable of flowing way more than enough in the first place.
Say you have a 200mm throttle body for the 2.0 Ti-VCT. That's well in excess of what is required. Going to a 210mm throttle body will not give you any gains when 200mm was already more than enough. I sincerely doubt the OE TB is a bottleneck in the system.
Old 03-06-2014, 02:26 AM   #68
MakatoMotors
MakatoMotors's Avatar
Fan#: 109381
What I Drive: 2012 Oxford White SE
Points 320, Level 6
Points: 320, Level: 6 Points: 320, Level: 6 Points: 320, Level: 6
Level Up 40% Completed
FF Reputation: 2 MakatoMotors Good Standing Member
but with a better intake, couldn't the tb become a part of the bottleneck? I think that a slight increase in the tb, would still be beneficial, but yet again, i don't know if 2mm would make much of a difference even if the stock has some restriction.
'12 Focus Hatch SE
Magnaflow Exhuast, AEM CAI, Eibach Prokits Springs, RokBlokz Mudflaps, RS style hood, RS Spoiler, 18" MSW 25 Wheels
MakatoMotors is offline
Old 03-06-2014, 02:47 AM   #69
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
You kids are funny.
Lets look at Physics.
You have a circle with a diameter of 3" and one with a diameter of 4".
What is the total air pressure exerted on each?
When you can answer that, you will understand how an engine breathes.
iminhell is offline
Old 03-06-2014, 02:49 AM   #70
MakatoMotors
Fan#: 109381
Points 320, Level 6
6"!!! lol. I'm not a mechanical engineer lol. what is your opinion on the subject :)
'12 Focus Hatch SE
