Ported throttle Body - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-01-2014, 06:29 PM   #21
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,914, Level 76
Points: 13,914, Level: 76 Points: 13,914, Level: 76 Points: 13,914, Level: 76
Level Up 66% Completed
Forum Activity 3%
FF Reputation: 12 NickCornell Great Standing Member
Do you have a baseline Dyno? Or what's the plan? I'm pretty curious, but fear that no restriction is being caused by the TB
#SonicsMK3Crew
Follow #projectstreetdevil on IG @BBNickC
BUILD THREAD: http://www.focusfanatics.com/forum/showthread.php?t=323533
NickCornell is offline
Old 02-01-2014, 07:36 PM   #22
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 551, Level 11
Points: 551, Level: 11 Points: 551, Level: 11 Points: 551, Level: 11
Level Up 2% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
Originally Posted by Creative View Post
... Even though it's not a drastic increase in throttle body size I feel that now the car might be getting to much air and I need to move to a custom tune instead of the injected tune to better monitor airflow and air to fuel ratio...
Probably not necessary. The ECU will adjust fuel trim as necessary to meet the target air fuel ratio, even at WOT.
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 02-01-2014, 09:14 PM   #23
Kjanracing
Kjanracing's Avatar
Fan#: 135409
What I Drive: 2014 Ruby Red SE hatch with DCT
Points 503, Level 10
Points: 503, Level: 10 Points: 503, Level: 10 Points: 503, Level: 10
Level Up 6% Completed
FF Reputation: 2 Kjanracing Good Standing Member
My point being that if the OEM throttle meets the demand of the engine, installing a larger one won't do a thing. If you want " better throttle response", that could be done with programming...as in command more throttle opening/pedal travel. I seriously doubt the stock throttle is a limiter, at least on the normally aspirated engine.
Kjanracing is offline
Old 02-01-2014, 11:10 PM   #24
Eminaga
Eminaga's Avatar
Fan#: 123953
What I Drive: 2014 Focus SE (Performance Blue)
Points 1,192, Level 18
Points: 1,192, Level: 18 Points: 1,192, Level: 18 Points: 1,192, Level: 18
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 24%
FF Reputation: 1 Eminaga Good Standing Member
Red face
I am thinking the same thing. If it was a limiter on our engines then it would gain a lot more then 10 hp on st.
*Snorkel/Shroud Delete, ITG Filter, Full ST Exhaust, E-RMM, Steeda RSB, Vogtland Springs, 180* T-Stat, Custom SCT Tune by Tom @ Focus-Power*
Eminaga is offline
Old 02-05-2014, 08:44 AM   #25
mustang0
mustang0's Avatar
Fan#: 96079
What I Drive: 2012 Blue Candy SE HB Sport Package
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 1 mustang0 Good Standing Member
Modern performance has finally released a ported throttle body for the focus st. The throttle body has been ported out to a 59mm from a 57mm.
Site link
http://www.modernperformance.com/pro.../Ford_Focus_ST
After doing some research I noticed that the regular focus and the st share the same throttle body. So I recently ordered one to test it out. The throttle body should be here Monday and next weekend I hope to do a big parts install weekend.
I will post update once the throttle body arrives.
Pictures
New larger throttle plate
Comparison photo:
The N/A focus does use a 57mm TB, same as the st.
Installed photo
After installing and letting the car idel and warm up I took it for a 1mile test run. I noticed I have much better throttle response, better high end pull, feel of torque seems to have not changed. The car overall performs much better. This is definitely a good buy but my only concern is that I will need a new tune. Even though it's not a drastic increase in throttle body size I feel that now the car might be getting to much air and I need to move to a custom tune instead of the injected tune to better monitor airflow and air to fuel ratio.
Overall the car felt pretty solid on power end. It really picks up the power curve at about 37-3800 rpms and pulls hard till redline. I have to set up some dyno time and then I have exact numbers.
Important side note: replace the throttle body gasket when you install new TB. I noticed mine was a bit limp and the rubber o-ring needed to be replaced.
Nice mod. If you have a smart phone you can get the Torque app, then you can watch real time or data log your air fuel ratios to find out how safe your tune is.
65 Racestang 96 Mustang 2012 Focus SE HB Sport Pac 5 speed man. NewMission Cold Air, lunchbox Delete,Custom 3" Magnaflow exhaust, Steeda Rear Sway Bar, Steeda STS,Axis wheels, Blox shift knob,Focus elecrtic RMM, Injected 93 Tune V1 176HP 152Torque
mustang0 is offline
Old 02-05-2014, 11:16 AM   #26
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,360, Level 42
Points: 4,360, Level: 42 Points: 4,360, Level: 42 Points: 4,360, Level: 42
Level Up 5% Completed
Forum Activity 4%
FF Reputation: 9 darkangelism Good Standing Member
From what Aric has said, the injected tune should handle more air fine unless it was a huge change.
2012 Ti Hatch
Sonic Crew #04
Steeda SRI/Newmission | Steeda RSB | SMC Replica ST Wing | SMC Aluminum Oil cap | Injected Tune | 2.5" custom exhaust
darkangelism is online now
Old 02-05-2014, 04:44 PM   #27
Bcardwell101
Fan#: 120267
What I Drive: 2013 gray focus
FF Reputation: 1 Bcardwell101 Good Standing Member
just ordered one for my 13 se. we shall see what happens ill post a update on my thoughts.
Bcardwell101 is offline
Old 02-05-2014, 10:39 PM   #28
NickCornell
Fan#: 97233
Forum Activity 3%
Awesome guys. Seriously thank you for being the pilots here. Without guys like you there would be no aftermarket!
#SonicsMK3Crew
Old 02-06-2014, 09:00 PM   #29
dbsimms63
Fan#: 110359
What I Drive: 2013 Performance Blue Titanium 5dr
Points 1,820, Level 25
Points: 1,820, Level: 25 Points: 1,820, Level: 25 Points: 1,820, Level: 25
Level Up 20% Completed
Forum Activity 5%
FF Reputation: 2 dbsimms63 Good Standing Member
interesting to see how this goes
dbsimms63 is offline
Old 02-06-2014, 10:10 PM   #30
Creative
Creative's Avatar
Fan#: 108024
What I Drive: 2013 Ford Focus
Points 3,615, Level 37
Points: 3,615, Level: 37 Points: 3,615, Level: 37 Points: 3,615, Level: 37
Level Up 77% Completed
FF Reputation: 3 Creative Good Standing Member
Supposed to go on dyno this weekend but that might change pending the incoming snow storm
Originally Posted by Dialed View Post
Let's be honest guys, car modding is not synonymous with warranty-covered cars.
As the old saying goes, you have to pay to play.
Creative is offline
