Ported throttle Body - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-26-2014, 12:16 PM   #1
Creative
Creative's Avatar
Fan#: 108024
What I Drive: 2013 Ford Focus
Points 3,615, Level 37
Points: 3,615, Level: 37 Points: 3,615, Level: 37 Points: 3,615, Level: 37
Level Up 77% Completed
FF Reputation: 3 Creative Good Standing Member
Modern performance has finally released a ported throttle body for the focus st. The throttle body has been ported out to a 59mm from a 57mm.
Site link
http://www.modernperformance.com/pro.../Ford_Focus_ST
After doing some research I noticed that the regular focus and the st share the same throttle body. So I recently ordered one to test it out. The throttle body should be here Monday and next weekend I hope to do a big parts install weekend.
I will post update once the throttle body arrives.
Pictures
New larger throttle plate
Comparison photo:
The N/A focus does use a 57mm TB, same as the st.
Installed photo
After installing and letting the car idel and warm up I took it for a 1mile test run. I noticed I have much better throttle response, better high end pull, feel of torque seems to have not changed. The car overall performs much better. This is definitely a good buy but my only concern is that I will need a new tune. Even though it's not a drastic increase in throttle body size I feel that now the car might be getting to much air and I need to move to a custom tune instead of the injected tune to better monitor airflow and air to fuel ratio.
Overall the car felt pretty solid on power end. It really picks up the power curve at about 37-3800 rpms and pulls hard till redline. I have to set up some dyno time and then I have exact numbers.
Important side note: replace the throttle body gasket when you install new TB. I noticed mine was a bit limp and the rubber o-ring needed to be replaced.
Originally Posted by Dialed View Post
Let's be honest guys, car modding is not synonymous with warranty-covered cars.
As the old saying goes, you have to pay to play.
Creative is offline
Old 01-26-2014, 12:32 PM   #2
Eminaga
Eminaga's Avatar
Fan#: 123953
What I Drive: 2014 Focus SE (Performance Blue)
Points 1,192, Level 18
Points: 1,192, Level: 18 Points: 1,192, Level: 18 Points: 1,192, Level: 18
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 24%
FF Reputation: 1 Eminaga Good Standing Member
Site link
10 hp gain on the turbo focus means even less for us n/a guys. Just not sure if it is worth almost 300 bucks. By the way are u sure ours is 57mm? 2mm just dont seem like it will help much especialy if we have the one that turbo version is using. Will u dyno it also? Keep us updated
*Snorkel/Shroud Delete, ITG Filter, Full ST Exhaust, E-RMM, Steeda RSB, Vogtland Springs, 180* T-Stat, Custom SCT Tune by Tom @ Focus-Power*
Eminaga is offline
Old 01-26-2014, 05:23 PM   #3
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,271, Level 46
Points: 5,271, Level: 46 Points: 5,271, Level: 46 Points: 5,271, Level: 46
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 6 SlickWilly Good Standing Member
You will notice something, because more air is getting in for the same amount of throttle. Will you gain on the top end, maybe who knows. Basically will make your throttle more sensitive.
09 4F27E - K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - Nitrous Express Proton EFI - NX Launch Control & Progressive timer - NOS Window Switch
SlickWilly is online now
Old 01-27-2014, 11:42 AM   #4
bluehatch14
bluehatch14's Avatar
Fan#: 111245
What I Drive: 2012 blue se hatchback
Points 2,263, Level 28
Points: 2,263, Level: 28 Points: 2,263, Level: 28 Points: 2,263, Level: 28
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 bluehatch14 Good Standing Member
Subscribed to this. Curious to see how this pans out! Keep us updated!
bluehatch14 is offline
Old 01-27-2014, 01:57 PM   #5
Bcardwell101
Fan#: 120267
What I Drive: 2013 gray focus
FF Reputation: 1 Bcardwell101 Good Standing Member
Could you just port your own?
Bcardwell101 is offline
Old 01-27-2014, 02:33 PM   #6
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 550, Level 10
Points: 550, Level: 10 Points: 550, Level: 10 Points: 550, Level: 10
Level Up 50% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
In for results.
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 01-28-2014, 12:36 PM   #7
Roadworthy
Fan#: 109039
What I Drive: 2012 SGM MK3 Titanium
FF Reputation: 1 Roadworthy Good Standing Member
When I had my '04 Mazda6 2.3 i4, there was a user who was porting/polishing the throttle body. Some say it added a bit better response but not much else. $300 is excessive for n/a. A larger TB opening will help our cars but a tune would be a better investment if you didn't already have it. Otherwise a great DIY. Get one used off ebay or a wreckers and buy a honing tool. Should be fun.
2012 SGM Ti DCT Stock and loving it
OEM multispoke 17" with stock rubber summer-X-ice 3's on stuck rims = awesomesauce
Roadworthy is offline
Old 01-28-2014, 12:50 PM   #8
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,018, Level 96
Points: 26,018, Level: 96 Points: 26,018, Level: 96 Points: 26,018, Level: 96
Level Up 67% Completed
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
I wouldn't call it $300 considering it's $290 minus $80 for sending back your old unit.
Either way, more air is a good thing.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 01-28-2014, 03:18 PM   #9
bluehatch14
Fan#: 111245
Exactly my thought. If it really works with our n/a mk3 cars then i would be willing to pay the 210 dollars or so. For those guys who are running a tune it would help more possibly. Im very interested in this.
Old 01-28-2014, 04:51 PM   #10
ChalupaJones
ChalupaJones's Avatar
Fan#: 110818
What I Drive: 2012, Sonic Blue, Focus S
Points 3,563, Level 37
Points: 3,563, Level: 37 Points: 3,563, Level: 37 Points: 3,563, Level: 37
Level Up 43% Completed
Forum Activity 64%
Activity: 64% Activity: 64% Activity: 64%
FF Reputation: 2 ChalupaJones Good Standing Member
Subscribing for results.
2012 Focus S Sedan, Sonic Blue, E-RMM, K&N drop in filter, Snorkel Delete, Steeda blue shift knob and STS, blue HVAC knobs, Trunk Lid Liner
- more to come
Military crew, Blue Focus Crew, Chalupa Crew #1
ChalupaJones is online now
