Is the factory battery that bad? - Page 3 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > DURATEC Ti-VCT Performance (2012-Current)
View Poll Results: Have you/someone replaced the battery in your 2012+ Ford Focus?
Yes, please see post #1 for further questions 5 13.16%
No. 33 86.84%
Voters: 38. You may not vote on this poll
Old 01-28-2014, 11:23 AM   #21
kevinxb
kevinxb's Avatar
Fan#: 96008
What I Drive: 2012 Blue Candy Ti Hatch
FF Reputation: 1 kevinxb Good Standing Member
Originally Posted by iminhell View Post
I've seen a couple posts now where the person has replaced the factory battery. That strikes me as very strange. Maybe things have changed but, I'm still accustomed to a factory battery lasting at least 6 years; definitely until after the factory warranty has expired.
I'm really curious to know how many people have replaced a factory battery already?
*Further questions*
Build date of the car?
How many miles on the car?
What symptoms lead to replacement?
Build date Nov 2011. I had the car for about 9 months and 7K miles when the battery died. No symptoms, car just would not start on a cold December night in 2012. Got a jump and made it home. Left it at the dealer and they replaced it with a Motorcraft Max unit. No issues since, even in this frigid Mid-Atlantic winter, knock on wood.
kevinxb is offline
Old 01-28-2014, 02:07 PM   #22
Yellowhorse
Fan#: 125273
What I Drive: 2014, Ruby Red, SE Hatchback
FF Reputation: 1 Yellowhorse Good Standing Member
2014 SE Hatchback. Late August 2013 build and purchased on September 24 2013. Only 2200 miles on it and no problems with the battery - yet. It's been 'really' cold (lows of 0 degrees or colder with highs of 10-15 degrees many days) this winter and I have noticed that if it sits for a few days and I go to start it, the engine turns over a little slower than usual but it does start right up. I've had many cars over the years and this seems to be normal. Batteries don't do well in the cold and these newer cars have so many parasitic connections (alarms/door locks, computer control modules for engine, powertrain, MySync/audio/NAV, safety/airbags, smart junction box, etc.) that are always on in some capacity will constantly pull power 24/7/365 from the battery when the car is not running. I'm thinking of putting a battery kill switch in it and eliminate the problem for when it sits for a week or so. I've done that in other cars with great success.
Yellowhorse is offline
Old 01-28-2014, 02:16 PM   #23
RedComet
RedComet's Avatar
Fan#: 99232
What I Drive: TB '14 Fiesta ST
FF Reputation: 7 RedComet Good Standing Member
You might not want to do that with this car, as an interrupt between the current draw from the ECU to the battery will likely reset it, and it will then have to 'relearn' your driving style with its adaptive programming. It's less of an issue with manual models, but I'd be very leery of doing that with a DCT.
Kay - HN#79
'14 Fiesta ST Tux. Blk. 6MT, COBB Stg. 1
Gone: '12 Hatch SE Sport MTX75
V - Power* Junkie
RedComet is offline
Old 01-28-2014, 03:58 PM   #24
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 49 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
^You turn you computer (the one you post from) off for a week, disconnect all power to it.
You come back and the date/time is still correct and all your setting are still there.
The automotive ECU/PCM is no different.
This business of disconnecting the battery resetting things is a partial untruth. For a good many things there's a mental aspect that changes and not a running condition. And since virtually no one has hard data that removing power changes anything, it's opinion that shouldn't be trusted.
Basically (very) what 'resetting the computer' does is it clears the learned data from when a problem is sensed.
So let's say the MAF is not reading correct (the computer thinks), from the time that data is sensed to when the computer is reset will be cleared. Which means that if the MAF has not been repaired, the same data will be learned.
If there is no problem sensed, no data is lost. That would include driving habits. If there are no fault codes, nothing is lost.
iminhell is online now
Old 01-28-2014, 07:39 PM   #25
Yellowhorse
Fan#: 125273
Actually, there is no CMOS type 'backup battery' in our cars for any of the computer modules. NAND memory (same as in a flash/thumb USB drive or a Solid State Drive (SSD)) is used in the car's computers for hard coding and nothing is lost there during a power outage. SDRAM is used for the 'adaptive learning' process (soft coding) and that data is lost when there is no power - just like a desktop PC. This is what happens when many of us disconnect the battery to try to 'solve' an unknown problem. Ghost in the machine? Sometimes that works and sometimes it doesn't. Not a big deal at all. When you load a fresh tune all the 'adaptive learned' information is lost and it starts all over from scratch. Every time a tune is loaded the process repeats itself. Again, not a big deal. A fresh start is usually a good thing.
My biggest issue with disconnecting the battery? I think maybe I might get pissed off at having to reset the clock all the time. :)
Old 01-28-2014, 08:16 PM   #26
DustyAlex
Fan#: 107712
What I Drive: 2012 Sonic Blue SE
FF Reputation: 1 DustyAlex Good Standing Member
No issues here, sits overnight for a good 13hrs no start in -25/-30 weather and starts no problem
Labour rate is $60 an hour, if you already tried to fix it $80 an hour, and if you want to help me $100 an hour
DustyAlex is offline
Old 01-29-2014, 03:36 AM   #27
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
FF Reputation: 1 Seminoles Good Standing Member
Back in the 80's maybe but today is different. Unplug your mass air flow sensor CEL comes on cars runs bad sets code. Now plug it back in with out resetting computer light off no codes stored. Found this out while changing to a CAI.
Seminoles is offline
Old 01-29-2014, 09:29 AM   #28
Yellowhorse
Fan#: 125273
These days, CEL's are 'soft coded' (generated from a detected fault by the 'hard coding') and not only self correct when the issue is resolved but also temporarily disappear (most of them) when the power from the battery is removed. The CEL's can come from many things. Sensors that have a bad connection, disconnected on purpose or sensors that have simply gone bad. Most have become 'plug and play' just like a PC. With the PC running, unplug your mouse and a little window pops up telling you something is wrong. Plug the mouse back in and all is well. All without restarting the PC. Automotive computers are getting better with each generation.
Old 02-12-2014, 12:52 PM   #29
warneej
BodyKits=PantiesDrop
warneej's Avatar
Fan#: 20372
What I Drive: 04 ZX3 D23E-10SES Sedan-12 Ti Hatch
FF Reputation: 200 warneej Excellent Standing Memberwarneej Excellent Standing Memberwarneej Excellent Standing Member
Buy-Sell-Trade Rating: (12)
2012 Titanium, purchased May 2011. Had to replace it approximately 1 year after purchase due to excessive corrosion from the positive terminal eating into the positive harness. Don't remember mileage. All parts replaced under warranty and no concerns since.
Disciple of the "Push harder, suck less" school of autocross.
173.4whp
gump
crew #6
warneej is online now
Old 02-14-2014, 01:02 PM   #30
Randilio
Randilio's Avatar
Fan#: 117707
What I Drive: 2013 Focus SE; Tuxedo black; Tinted
FF Reputation: 1 Randilio Good Standing Member
new battery
My factory Battery was replaced by dealer at about 4k - there were bad cells.
First few symptom were:
- car told me it was shutting down after I turned off the key it would not play the radio
- slow to start in the morning
An over night on the charger didn't help
2013 SE 5 speed
no mods yet -
2013 SE Hatch; Tux Blk; Darth V8er.
Randilio is offline
