Jumping in 2nd? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-29-2014, 05:01 AM   #11
foreverford
Fan#: 116979
What I Drive: Focus st170
Points 1,537, Level 22
Points: 1,537, Level: 22 Points: 1,537, Level: 22 Points: 1,537, Level: 22
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 1 foreverford Good Standing Member
does this happen when the gas gets down to a certain level?? fill her up to the max, and see if it does it, when your tank is low, the fuel pump is under more pressure to preform at low gas levels, witch would show up a failing pump
foreverford is offline
Old 04-29-2014, 05:24 AM   #12
Fierceintent
Fierceintent's Avatar
Fan#: 117556
What I Drive: 04 infra red Svt, 03 2.3 red sedan
Points 506, Level 10
Points: 506, Level: 10 Points: 506, Level: 10 Points: 506, Level: 10
Level Up 12% Completed
Forum Activity 2%
FF Reputation: 1 Fierceintent Good Standing Member
Yeah my car surges in 2nd gear aswell around 2k-3k. once its out of 3k it doesn't surge. I mean it lightly surges when I have my foot off the gas. Idk its weird. Doing that for along time, got a p1518 code today. Will let ya know if that had anything to do with it. I was going to opt to opening it up to fix but it makes that weird grind sounds sometimes when start. So i'm sure the plastic pully is toast. got part from tasca on order for 200 bucks.
Fierceintent is offline
Old 04-29-2014, 06:38 AM   #13
StephenElsbree1986
StephenElsbree1986's Avatar
Fan#: 104271
What I Drive: CD Silver 2003 SVT
Points 1,167, Level 18
Points: 1,167, Level: 18 Points: 1,167, Level: 18 Points: 1,167, Level: 18
Level Up 67% Completed
Forum Activity 3%
FF Reputation: 1 StephenElsbree1986 Good Standing Member
Oh, if you're running stock tune surging is normal.
StephenElsbree1986 is offline
Old 04-29-2014, 11:02 AM   #14
Tommyk
Fan#: 148570
What I Drive: 2003, Silver SVT
Points 78, Level 1
Points: 78, Level: 1 Points: 78, Level: 1 Points: 78, Level: 1
Level Up 56% Completed
FF Reputation: 1 Tommyk Good Standing Member
This may sound like left field but I had a similar feeling that turned out to be the motor mounts.
Tommyk is online now
Old 04-29-2014, 11:31 AM   #15
Wild Child
Fan#: 119206
What I Drive: 2003 Silver ZX5 SVT
Points 75, Level 1
Points: 75, Level: 1 Points: 75, Level: 1 Points: 75, Level: 1
Level Up 50% Completed
FF Reputation: 1 Wild Child Good Standing Member
I would think that the surge caused by the poor tune would be amplified by bad motor mounts, just as stepping on and off of the accelerator would.
Wild Child is offline
Old 04-29-2014, 06:38 PM   #16
Fierceintent
Fan#: 117556
Forum Activity 2%
My focus is from 2004 so I thought they fixed the stock tune issue? Just curious.
Old 04-29-2014, 09:29 PM   #17
foreverford
Fan#: 116979
can you explain this a bit more, because this sounds very strange to me, ????
this sounds more like a fueling problem to me, an engine mount sounds far fetched,
not saying your wrong, just a bit far out for me
Old 04-30-2014, 12:43 AM   #18
b.pearson
b.pearson's Avatar
Fan#: 130617
What I Drive: 2003 Infrared SVT ZX5
FF Reputation: 2 b.pearson Good Standing Member
I'm currently running a stock tune, and my mods are in my signature. It does it at any fuel level, could the tune (Or lack of) be the issue?
2003 SVT ZX5- EAP rims, FSWerks Race cat-back exhaust, FSWerks SRI, Spectre cone filter & breather filter, FSWerks front splitter, SAP rear diffuser, upgraded throttle body (Size and brand unsure), HID headlights, more to come!
b.pearson is offline
Old 04-30-2014, 09:01 AM   #19
Wild Child
Fan#: 119206
Points 75, Level 1
If you drive a car with bad mounts, every time you step on the throttle or let off or the clutch, the engine rolls. The stock tune surging is like light accelerator feathering. If you have bad mounts, I suspect the surge could roll the motor back and forth making a small issue seem much worse.
I don't dispute that this is likely a fueling issue is some way shape or form, however, if it seems worse than what most of us are experiencing, it could be because the worn mounts are amplifying the engines reaction to the surge.
Just my thoughts on Tommyk's experience with mounts being the cause of his similar issue.
Old 04-30-2014, 09:09 AM   #20
StephenElsbree1986
Fan#: 104271
Forum Activity 3%
Wild is correct this may happen. To B Pearson, yes the stock tune is horrible. You need a tune for it just being stock, if you have any mods that effect internet combustion engines like you do. You car doesn't have the corrected information to run optimal.
