What aftermarket amp do you recommend? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-24-2014, 02:35 AM   #1
thewizkid95
Fan#: 128930
What I Drive: 2007 Aqua Blue ZX4
FF Reputation: 1 thewizkid95 Good Standing Member
Question What aftermarket amp do you recommend?
I have a 2007 Ford Focus and I'm looking to install an aftermarket amp, but I'm not sure which. What would you guys recommend? I was thinking an SSL F4.400, but I'd rather have expert audiophiles help me decide. Here is what I require:
Must have 4 channels.
I'm using the factory speakers so nothing crazy powerful
It must be as cheap as possible. I just want the basic features and nothing I else
I will be using the factory speakers, so I should be able to connect the amp to a metra speaker harness with speaker cable
It must have two pairs of RCA-in ports for the 4 channels
thewizkid95 is offline
Old 01-24-2014, 02:38 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 135,654, Level 100
Points: 135,654, Level: 100 Points: 135,654, Level: 100 Points: 135,654, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (11)
Moved to the Car Audio area
Why do you want to power the stock speakers with an amp?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 01-24-2014, 02:46 AM   #3
thewizkid95
Fan#: 128930
I want to install a Nexus 7 in my car, and that's gonna need an amplifier. I really wanna make this project as budget-friendly as possible so I don't want to buy aftermarket speakers (or anything else) unless it's 110% necessary.
Old 01-24-2014, 02:47 AM   #4
Tundrafoci
Fan#: 96605
What I Drive: 2003 light tundra ZTS
Points 703, Level 14
Points: 703, Level: 14 Points: 703, Level: 14 Points: 703, Level: 14
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 3%
FF Reputation: 5 Tundrafoci Good Standing Member
Buy-Sell-Trade Rating: (8)
If you haven't put in an after market head unit I would do that instead of an amp if you already have one then.....
Tundrafoci is offline
Old 01-24-2014, 04:27 AM   #5
Gav-O-SVT
I Like Red
Gav-O-SVT's Avatar
Fan#: 113561
What I Drive: '02 Infra-Red SVT
Points 2,731, Level 31
Points: 2,731, Level: 31 Points: 2,731, Level: 31 Points: 2,731, Level: 31
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 80%
Activity: 80% Activity: 80% Activity: 80%
FF Reputation: 6 Gav-O-SVT Good Standing Member
Stock amp is fine for your stock speakers, a new aftermarked HU will be a Huge upgrade. Then get a mono block amp to power the SW.... Kenwood has some of the best "bang for your buck" amps/subs out there... Modestly priced and good name brand quality.
Gav-O-SVT is offline
Old 01-24-2014, 09:10 AM   #6
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 2 ferret15 Good Standing Member
This really isn't a budget-friendly build.
How is it going to fit in the dash?
Pre-amp set up? What is the plan, you can't just hook the nexus 7 into the amp, You need to send the audio to a pre-amp or line driver. Some simply stick an aftermarket deck in the glove box, this would work. You can use a bluetooth, if by chance you have sync in your car you might be able to use this. Otherwise a bluetooth module would be required, (something from isimple might work for you). Last option is a DAC, (digitial audio converter), this pulls audio signal from the usb converts it to something you can use. The Bluetooth/DAC usually leave you with only 2 channels to use (left/right) so you will still need to get more out of it, A line driver (something similar to audiocontol matrix) would allow you to split up to 6 channels, and adjust the voltage to the amp.
ferret15 is offline
Old 01-24-2014, 09:42 AM   #7
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,594, Level 58
Points: 7,594, Level: 58 Points: 7,594, Level: 58 Points: 7,594, Level: 58
Level Up 22% Completed
Forum Activity 11%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
The nexus 7 fits the dash alright, i just got one and test fit it in a spare bezel i have. The length is tight, would need to shave a bit from the left and right. The height is plenty, you would need to fill the extra space.
I didnt buy the nexus for my car but i have thought about doing something down the road, so i am paying attention to these threads. I was leaning towards the usb DAC route for digit out and then to an amp but still not sure after that what would be all needed for a proper sounding setup.
would look nice if you could fiberglass or resin it in then sand, prime, paint ect...
(remember this isnt sitting flush, really tight fit left/right would need to remove some material from the bezel but plenty of up/down space to play with)
rambleon84 is online now
Old 01-24-2014, 10:26 AM   #8
ferret15
ferret15's Avatar
Fan#: 83494
yeah, I'm slowly workign on a similar set up. This is actually getting re done, because I didn't like how the tablet sits.
Depending on the DAC, barebones you might be able to just split and plug in. However, that means your tablet is powering the 3+volt signal. It would be much better to use a line driver to give you 4-6 channels of good signal and you can even get some that have an eq built in and volume knob. Which for this kind of project makes life easy.
ferret15 is offline
Old 01-24-2014, 11:50 AM   #9
thewizkid95
Fan#: 128930
I was planning on using a USB DAC. I would split the DAC's RCA out ports and connect them to the amp. Maybe a ground loop isolator too if static occurs.
What year Focus are you planning to install this in? My tablet doesn't fit as nicely as yours in my factory panel. I need to get my hands on a Scosche dash kit and see how I'd get it to sit nicely.
I have pretty much the same set up and I have everything planned out, I'm just looking for an amp now. What amp were you thinking of going with? Also, I have an amazon wish list made if you would like to take a look at that.
I was thinking of using this DAC. I've read that other people don't have problems with it.
I thought the stock amp was inside of the factory head unit? Does the 2007 focus have a separate amp? I don't really like the idea of using an aftermarket head unit. Seems kinda hacky to me. (Not that this whole project is lol)
Old 01-24-2014, 12:31 PM   #10
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,336, Level 51
Points: 6,336, Level: 51 Points: 6,336, Level: 51 Points: 6,336, Level: 51
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (23)
This depends on what your actual budget is.
New or used?
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
