AEM wideband reading bounce - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-22-2014, 12:03 AM   #1
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
Not sure if it's a problem or not as car runs normally and performs as usual; my AEM wideband reading bounces around a bit too much for my liking (sweeps/oscillates from 13 to 16 very rapidly at part throttle cruise) although readings at full throttle and idle are generally steady and within spec.
Is this an indication that the wideband sensor in the exhaust is going belly up or of some other possible problem with the AEM unit (or engine)? Curious as to any one else's experience and possible cause and fix. Thanks.
Car's a turbocharged Zetec, no oil consumption, wideband is about 3 year's old.
BC_ZX3 is offline
Old 01-22-2014, 12:16 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Mine does the same thing and is fine, oddly enough about the same amount of yours (3+yrs).
What I'm assuming is happening is the computer adjusting the air/fuel ratio to keep it within the targeted mark. Being that the computer uses a narrow band O2 to do this, this is why it bounces back and forth. It's just going back and forth since it can't read a actual reading.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-22-2014, 09:33 AM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,548, Level 100
Points: 52,548, Level: 100 Points: 52,548, Level: 100 Points: 52,548, Level: 100
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
Its ment to go back and forth and the more you ease in or ease out of the throttle the more it changes , to hit the target of 14.7 it has to see it want past 14.7 to correct it and bring it back when it goes to low it sees it and brings it back up and so on
Its called Short Turm Fuel Trim 1 STFT1 and you can see this in your datalog watching the STFT1 , it should look like a castle top and should target 1.000 but never hit it
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 01-22-2014, 09:44 AM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Thanks for the responses.
I kinda knew it was supposed to oscillate a bit; it just seems to be more extreme lately. (Then again I'm doing more cold start, short trips.) I'll have to do a datalog as you suggest for peace of mind.
Just out of curiosity while we're on the subject, any idea what the life span of the AEM exhaust sensor really is? I see they sell them separately from the gauge kit. I assume it would be close to the same as a "regular" O2 sensor.
BC_ZX3 is offline
Old 01-22-2014, 11:21 AM   #5
codices
codices's Avatar
Fan#: 118513
What I Drive: 2007 CD-Silver ZX3
FF Reputation: 1 codices Good Standing Member
Widebands do not last as long as narrowband o2 sensors. I believe they last about 15k miles.
codices is offline
Old 01-22-2014, 02:16 PM   #6
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,257, Level 35
Points: 3,257, Level: 35 Points: 3,257, Level: 35 Points: 3,257, Level: 35
Level Up 38% Completed
Forum Activity 18%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
really? thats kinda shity
qweesy is offline
Old 01-22-2014, 02:16 PM   #7
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,915, Level 87
Points: 18,915, Level: 87 Points: 18,915, Level: 87 Points: 18,915, Level: 87
Level Up 13% Completed
Forum Activity 10%
Buy-Sell-Trade Rating: (4)
They last quite a while. No shorter than any other sensor.
People replace then too often for the simple fact of safety and piece of mind. Unless you're logging response times and comparing them to older logs, you can't definitively say a sensor is going bad.
The downfall of having the sensor there doing nothing isn't as good as if it's running the car. Then you can do at will tests to see if it's slowing up.
In a nutshell, you compare PW to the WBO2 readings. They should match, peaks and valleys. 99% of the time they won't because the person didn't correct the 'offset'. And in those cases so long as the shaped of the graphs match, the sensor is fine.
Also, depending on how fast the gauge is reading, or able to datalog, the delta may not be real. You could be seeing individual exhaust pulses (rich) and dead time (lean). but I really doubt the gauge response is that fast.
But the tighter you are to 1, the better the tune. For instance, part throttle steady cruise I vary +/- 0.03 Lambda or 15.15 - 14.25. Lots of time into my tune though.
iminhell is offline
