What size is the front swaybar on an 05 ZX4 SE - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 01-20-2014, 12:36 PM   #1
focusrenton
Fan#: 117393
What I Drive: 2005 Light Tundra ZX4
FF Reputation: 1 focusrenton Good Standing Member
I have been looking at the Steeda competition swaybar however it says it's recommended to use a 22mm front sway bar, but I am wondering if I could get away with running just the rear and if it would give a bad ride after the upgrade.
The link to the swaybar is http://www.steedafocus.com/parts/200...-rear-swaybar/
Thanks
focusrenton is offline
Old 01-21-2014, 08:43 AM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,749, Level 58
Points: 7,749, Level: 58 Points: 7,749, Level: 58 Points: 7,749, Level: 58
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 19%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
You would either have an 18 or 20mm front bar...no first gen focus came with a 22mm front bar.
That is a really beefy rear bar, what are your goals for the car and what is your current suspension setup?
rambleon84 is online now
Old 01-21-2014, 09:39 AM   #3
focusrenton
Fan#: 117393
I have no other suspension modifications done, I was considering the sway bar or the strut tower bar offered from FSWERKS but my suspension, steering, and brakes professor told me that the sway bar would give me real benefits, and that the strut bar would be mostly cosmetic. I just want the car to take corners better and be a little stiffer.
Old 01-22-2014, 06:37 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,799, Level 73
Points: 12,799, Level: 73 Points: 12,799, Level: 73 Points: 12,799, Level: 73
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 99%
Look Here:
http://www.focusfanatics.com/forum/f...play.php?f=159
For more ideas & info..
Your professor is spot on in his recommendation of a rear bar vs. front tower brace.
As rambleon mentioned, your starting point (and goals) helps determine what would work best, from adding a bar to replacing an existing one with a larger bar. Extremes are best left for the track, swapping ends on a snowy day because of a huge rear bar wouldn't be fun.
Research & questions will help get you a decent setup without having to experiment yourself.
Cheers!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 01-23-2014, 08:54 AM   #5
focusrenton
Fan#: 117393
Thanks sailor, I'm new to modifying suspensions and have been struggling for weeks with what I should do.
