Stealth CAI installed. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-19-2014, 08:36 PM   #1
daspazzZX3
OneOfUs
daspazzZX3's Avatar
Fan#: 133961
What I Drive: chcl gry 02 ZX3 - 5sp
Points 5,548, Level 47
Points: 5,548, Level: 47 Points: 5,548, Level: 47 Points: 5,548, Level: 47
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 2 daspazzZX3 Good Standing Member
Buy-Sell-Trade Rating: (18)
Well car was being really thirsty so I went to my buddies and installed a stealth CAI before upgrading my headlights from stock to HID Angel eyes.
Now I'm in need of some info on how I can tweak my car to reset the CEL for the MAF. I cleaned the MAF sensor while I was in there. But I'm thinking I might need to replace the MAF sensor for now.
I have noticed a bit better gas mileage and and it much peppier, but it still stalls at lights from time to time.
Any ideas?
Pics on 3rd page
"You are a person, No one can forget you, even if it's Good or Bad, you make waves!" #truth #truthinadvertizing...
R.I.P. Pat :-( HN #68 - Focus Takeover #008 - principal defensor para el diablo
daspazzZX3 is online now
Old 01-19-2014, 08:45 PM   #2
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 2 ferret15 Good Standing Member
http://www.focusfanatics.com/forum/showthread.php?t=195366
ferret15 is offline
Old 01-19-2014, 09:02 PM   #3
daspazzZX3
OneOfUs
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
Thumbs up
Originally Posted by ferret15 View Post
been there read that, but thanks for the pointer!!
anybody else?
I have a USB to OBDC II cable inbound from china..... /me tap rap taps fingers on table....
Old 01-19-2014, 09:17 PM   #4
ferret15
ferret15's Avatar
Fan#: 83494
IDK, shouldn't kill your car at idle. You've let it run for a bit and driven some miles for the computer to adjust I assume? Maybe your spark plugs are at the end of their life or maybe your IAC is dirty? You can't change the parameters without a proper tune if that is the problem. MAF sensors aren't exactly cheap, but if you car runs its probably working.
ferret15 is offline
Old 01-19-2014, 09:19 PM   #5
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Points: 6,225, Level: 51 Points: 6,225, Level: 51 Points: 6,225, Level: 51
Level Up 38% Completed
FF Reputation: 11 GreySkorpion Great Standing Member
To reset just about any CEL, unplug your battery for 30 minutes. My SRI has never caused a single issue on my car, its this style:
GreySkorpion is offline
Old 01-19-2014, 09:35 PM   #6
daspazzZX3
OneOfUs
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
it runs great on the road and on the freeway!!
I just replugged it a week ago with the only plugs I could find at Oriely's. Not my first choice. Ordered some AR103s from ebay. May swap in a set of those and then hard reset....
whadzah IAC?
Thanks ferret!! I will try resetting it again and then idle for 10 minutes.....
berry purdee sk0rpi0n!!
Old 01-19-2014, 11:11 PM   #7
GreySkorpion
Fan#: 94674
IAC, Idle Air Control, it's right below and slightly left of the throttle body, they get gunked up with carbon. Remove it and clean it with throttle body cleaner or equivalent. I gapped my AR103's to .055 and it ran great, at .060, not so great. Also, that is not my engine bay, mine is much cleaner than that.
Old 01-22-2014, 12:46 AM   #8
daspazzZX3
OneOfUs
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
thanks skorp! No joy on the reset. CEL came back on today. Got my ODBDII cable today, had practice so I couldn't putz with it yet. Will look at it tomorrow while waiting on ink.
Maybe i can hard reset it with the software that came with it.
Old 01-22-2014, 10:10 AM   #9
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,752, Level 59
Points: 7,752, Level: 59 Points: 7,752, Level: 59 Points: 7,752, Level: 59
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 19%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Did you use the stock MAF tube with your stealth CAI and are you sure the MAF sensor is facing the correct direction? You should not be getting any sort of CEL.
Did you have any CEL before doing the mod? I doubt the MAF sensor has gone bad, i also would not be going full wide open throttle or enjoying any of the new pep until you get this sorted out. If the MAF sensor is not facing the right direction or not hooked up right, that means un-metered, could cause some issues
rambleon84 is offline
Old 01-22-2014, 11:01 AM   #10
daspazzZX3
OneOfUs
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
Yep to stock MAF tube. The opening of the MAF is facing the filter on the end of the tube. Yep to CEL before mod. I cleaned the MAF and the MAF tube before reinstalling with MAF cleaner. I couldn't get the MAF sensor off of the wiring harness..... So its should be on that correctly.
I did not remove the silver cover from the MAF to clean it better, wonder if that could be the problem.
I will be pulling the code again here in a bit. More later.
Thanks for your input.
