Battery relocation behind fender!!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2014, 09:50 AM   #1
1988ttop
Fan#: 120313
What I Drive: 2002, focus zx3, dark grey
Points 66, Level 1
Points: 66, Level: 1 Points: 66, Level: 1 Points: 66, Level: 1
Level Up 32% Completed
FF Reputation: 1 1988ttop Good Standing Member
Exclamation Battery relocation behind fender!!!!
Just like everyone else I will start by saying that I have search everywhere for an answer but have failed to find one. I been looking for options to relocate my battery, the most common place is the trunk but seems to be too much work as far as running the wire. Not to mention that if you have a Massive rear strut tower bar and you relocate the battery back there you won’t have any space left. I read somewhere about a member having his battery relocated behind the front fender and that really got my attention but I can’t find any info on that setup. Is it custom? Is it something that some company used to make and just like most of the other interesting parts they stop making them?
Any information will be highly appreciated.
BTW: I am aware of the “what if’s” regarding the battery location in case of a collision. Thanks…
1988ttop is offline
Old 01-17-2014, 11:11 AM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,727, Level 58
Points: 7,727, Level: 58 Points: 7,727, Level: 58 Points: 7,727, Level: 58
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 24%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Where at in the fender, guessing a smaller battery too?
rambleon84 is offline
Old 01-17-2014, 12:41 PM   #3
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
Chances are that member has a Braile battery which is much smaller and lighter than the stock battery. It also will not handle could temperatures well. I believe that member was norcalfocus that you are referring to by the way.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 01-17-2014, 01:07 PM   #4
1988ttop
Fan#: 120313
Points 66, Level 1
cant remmeber the name, but he has a silver SVT with ghost flames air brushed on the front, also a really nice vortech super charger.
1988ttop is offline
Old 01-17-2014, 01:09 PM   #5
1988ttop
Fan#: 120313
Points 66, Level 1
I guess it would be around the area where the filter would be on a AEM CAI. so it might be behind the bumper on the left, under the headlight?
1988ttop is offline
Old 01-17-2014, 01:52 PM   #6
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 24%
so basically you want to hide the battery, get the area around the engine cleared of some clutter?
Old 01-17-2014, 06:10 PM   #7
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,709, Level 76
Points: 13,709, Level: 76 Points: 13,709, Level: 76 Points: 13,709, Level: 76
Level Up 15% Completed
Forum Activity 11%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
Chrysler used to put the battery's in the fenders of late 1990's and early 2000's cars. With putting a Lead Acid battery in that kind of high moisture environment I would routinely see the battery tray corroded away to almost nothing. and in an extreme case a battery was hanging by just the cables in the fender location. Now this IS in the rust belt, but having seen that multiple times given the location I would never willingly put a battery in the fender.
Put it in the back it would be less work than fabing up something to make it work in the fender.
SkyPilot is online now
Old 01-17-2014, 06:57 PM   #8
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 2 ferret15 Good Standing Member
You can do it. Use a dry cell. Odyssey is going to be a better choice as they have smaller batteries available, but if you find you have room you can use a yellow optima too. You could get away with mounting a few metal straps across the battery to keep it in place, although I would spend more time with some more thought out mounts. Given your in a winter state, I would suggest making your own box to seal the battery from the elements. Guys tend to cut bend and weld a thin piece of Stainless steel for custom fit boxes.
I will warn that given most of use DD cars using a regular battery the acid will leak like normal and probably eat a things that were never supposed to see acid.
This is an acura, but since I can't find a picture of a focus that has this you get the idea of where to look for space.
edit: this is what the honda guys seem to be using for their. the odyssey 680 mini dry cell which will start our cars too, specs say 520CA for 5 secs and only 170CCA, that means I honestly don't know what to expect for the winter.
example of the battery in more of a box.
example of the battery in tray
ferret15 is offline
