zetec CAD drawing (work in progress) ... - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-13-2014, 11:00 AM   #11
Bowesmobile
Fan#: 111678
What I Drive: 2000, Cloud 9 ZTS
Points 139, Level 2
Points: 139, Level: 2 Points: 139, Level: 2 Points: 139, Level: 2
Level Up 78% Completed
FF Reputation: 1 Bowesmobile Good Standing Member
This is quite the task you've undertaken. I'm a mehanical engineer and have designed on Inventor, AutoCAD, Solid Edge, Unigraphics and Catia V5. So if you get stuck I can probably help you. Also, when you're done with your models would you mind forwarding them to me as IGES or STEP files? I would love to tinker around with them on Solid Edge. Let me know if you need any help. I can probably help you model some items in my spare time if you like. Let me know.
Bowesmobile is offline
Old 01-15-2014, 06:49 PM   #12
beatmaniac1
beatmaniac1's Avatar
Fan#: 90996
What I Drive: 2003 red svtf
Points 416, Level 8
Points: 416, Level: 8 Points: 416, Level: 8 Points: 416, Level: 8
Level Up 32% Completed
FF Reputation: 2 beatmaniac1 Good Standing Member
Buy-Sell-Trade Rating: (4)
Woahhh !! That is patience/perseverance !!! I'm halfway through my degree in mechanical engineering so I could probably help if a problem arise ( I work mainly with Solid Edge and SolidWork ).
beatmaniac1 is offline
Old 01-27-2014, 08:45 PM   #13
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
How do I "constrain" the assembly to keep the pistons as they should be?
I've tried a "directed angle" constraint, piston top vs crank main bearing axis, 90*. No go.
And a few others 90* to the crank centerline. Nothing seems to work as desired.
The wheel is grounded. So when I grab a counterweight I can rotate the assy. FWIW.
iminhell is offline
Old 01-27-2014, 09:14 PM   #14
Bowesmobile
Fan#: 111678
Points 139, Level 2
Originally Posted by iminhell View Post
http://i34.photobucket.com/albums/d120/iminhell/inventor/pistonsallover_zpsaeba5077.png
You can align the bottom or top surface of the piston (assuming its a flat surface somwhere). To the X, Y or Z planes depending on your orientation. Remember to turn off the distance and make it a "floating" distance. This will keep the surfaces parallel. Also if you designed everything on the same center-line it would be good to mate/align the centerlines of the pistons to whatever plane is the centerline of your assembly. Let me know if this helps.
Old 01-28-2014, 03:13 PM   #15
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 19%
It helped, but wasn't possible the way I took your descriptions.
I ended up drawing a temporary half bore to hold everything straight.
Aligned the piston tops and centerlines.
Aligned my 1/2 bore to my wheel.
Did a tangent on the piston the bore is around.
Works.
I tried to figure out how to animate it and show you/everyone, but that process I haven't mastered yet. Doesn't help that my internet isn't very reliable right now.
I did find out Showcase is too big to run well on my laptop. LOTS of processor required for it, holy cow.
iminhell is offline
Old 01-29-2014, 08:52 AM   #16
Bowesmobile
Fan#: 111678
Points 139, Level 2
Works.
Thats right you're using Inventor. Sorry had a lapse of the program you're on. Well good to know it gave you a good direction! You're models look good so far. just keep updating your progress. Seems like to are trying to be a little flashy with showing a moving model, lol. Dont worry about that. I'm impressed you've trudged on this far. I haven't done motion on Inventor. But Solid Edge is pretty easy to do and export as a movie file. Can't remember the extension off hand. Keep up the good work and you can add motion after you're done.
Old 01-29-2014, 09:55 AM   #17
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,393, Level 61
Points: 8,393, Level: 61 Points: 8,393, Level: 61 Points: 8,393, Level: 61
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 30%
Inventor just requires a lot of computational power to do the movie. This was 12 years ago but we used it on a program to make a 30 second clip of a robot we had physically built move around and perform "actions". I am sure the tool for 3D movie and manipulation has greatly improved since then.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 02-01-2014, 02:59 AM   #18
Gav-O-SVT
I Like Red
Gav-O-SVT's Avatar
Fan#: 113561
What I Drive: '02 Infra-Red SVT
Points 3,055, Level 34
Points: 3,055, Level: 34 Points: 3,055, Level: 34 Points: 3,055, Level: 34
Level Up 4% Completed
Forum Activity 99%
FF Reputation: 6 Gav-O-SVT Good Standing Member
Damn, awsome work so far!
Gav-O-SVT is offline
Old 02-13-2014, 01:10 AM   #19
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 19%
There is the top view of the exhaust ports as they are right now. I don't like how they turned out though.
The short side radius is too long/tall, they don't merge quite right (at about the right point though) and I need to figure out how to flatten the bottom at the exit.
Used the "Sweep" option to build them. Kind of a PITA. You have to use 3 planes to get the shape that I have now.
I'm thinking to get it just the way I want I'm going to have to use at least 5. Real tedious. But you can make some really intricate shapes.
iminhell is offline
