airbag and ABS light keep flashing - Focus Fanatics
Old 01-27-2005, 05:39 PM   #1
morse
Fan#: 18283
What I Drive: 2004 Green LX
FF Reputation: 1 morse Good Standing Member
Angry airbag and ABS light keep flashing
I have 2004 Focus LR fitted with twin airbags. The car had some rear and light front end damaged when I bought it. The airbags were not deployed in the accident. When I first started the engine before any repairs were done to it, everything was working fine except ABS light was on (due to broken cable link on R/Rear wheel) during repairs I had to disconnect the battery. Now when I turn ignition the airbag and ABS lights keep flashing all the time! Do I need to reset the ECU/computer? Any ideas what’s going on?
morse is offline
Old 01-28-2005, 09:54 PM   #2
mconrada
mconrada's Avatar
Fan#: 1652
What I Drive: 91 mx5
FF Reputation: 1 mconrada Good Standing Member
If the ABS light is comming on then it means that your ABS is disabled. That could happen for couple reasons... a bad sensor, a blocked sensor (dirt in the way), a broken sensor, etc. As for the "air bag light" is it the SRS light? You could try resetting the ECU but if it is a problem then the lights will continue to flash... Its worth a shot.
mconrada is offline
Old 01-29-2005, 01:39 AM   #3
rednblackSVT
rednblackSVT's Avatar
Fan#: 17375
What I Drive: 2002 Infra-red SVT
FF Reputation: 1 rednblackSVT Good Standing Member
With the ABS light on... as long as the fluid level is correct, the car should automatically reset that as it goes through a drive cycle or to. In the situation with the Air Bags... you can always have the dealer run a scan... the seatbelt can even cause problems with the SRS light,... things like the seat-belt pretensioner and things like that could possibly be messed up. if the exclamation point light comes on.. go to a dealer immediately. you can also put the car in diagnostic mode... search for that on here.
I lit it on fire... twice.
Steeda Style Short ram intake. F-C ORP, Energy Suspension Poly-Urethane Bushings, TEIN s-Tech lowering springs,VF Engineering Mount, Carbon Fiber Hood, Cut Antenna, Blacked out turn signals and side markers, cute little halo projectors...almost forgot... JRSC
rednblackSVT is offline
Old 01-29-2005, 11:44 AM   #4
zslaton
zslaton's Avatar
Fan#: 11347
What I Drive: 2002 Yellow Power Premium ZX5
FF Reputation: 1 zslaton Good Standing Member
take the car in for servicing. Both of these lights flashing means something is VERY wrong or you have several connectors that are bad/disconnected. Either way, let a trained proffesional diagnose it.
... still plays with cars ...
zslaton is offline
