pzev to non pzev convertion - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 01-15-2014, 02:43 PM   #21
dooor
Fan#: 51395
What I Drive: 2007 se stick
Points 926, Level 16
Points: 926, Level: 16 Points: 926, Level: 16 Points: 926, Level: 16
Level Up 26% Completed
FF Reputation: 1 dooor Good Standing Member
After 60,000+ miles, depending on how dirty/dusty your air is, the "lifetime" air filter will reduce fuel mileage. A cone shaped washable air filter, two silicone hose 90 degree elbows, a few other pieces, and a little ingenuity will locate the filter up against the bottom of the headlight assembly. That greatly reduces the chance of getting water in the intake, restores the fuel economy, and adds power. good luck
dooor is offline
Old 01-16-2014, 05:39 AM   #22
fawzie13R
Fan#: 71759
What I Drive: '09 LT Blue Focus SEL Sedan
FF Reputation: 1 fawzie13R Good Standing Member
How hard was it to remove the air tube from behind the the fender? Did you have to take the fender off? What you did was what I was going to do, how long did it take you to remove the lower portion of the air box and air tube from the finder? I was going to put the CIA from Cfm that has the AEM air bypass valve and prefilter to handle the issue of water.
fawzie13R is offline
Old 01-16-2014, 10:35 AM   #23
dooor
Fan#: 51395
Remove the plastic fender well to get the air filter assembly off. Getting the factory over tightened screws out of the plastic anchors took longer that the rest of the job. There is one hard to see and reach bolt on the air cleaner mount. Good luck
dooor is offline
Old 01-16-2014, 04:57 PM   #24
fawzie13R
Fan#: 71759
Did you use hand tools or air tools? So just have to take the plastic fender we'll out and it reveals the air box assembly? Cool beans
Old 01-16-2014, 05:55 PM   #25
2005focuszx3
Fan#: 128530
What I Drive: 2005 Black Focus ZX3 SES
Points 1,201, Level 19
Points: 1,201, Level: 19 Points: 1,201, Level: 19 Points: 1,201, Level: 19
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
FF Reputation: 1 2005focuszx3 Good Standing Member
When I did this, I only used hand tools. If I remember correctly, there are some bolts that are hard to get to, so some long extensions are useful. Also, you'll need a torx bit socket to get the fenderwell and airdam apart from the bumper in one corner. Don't remember what size though.
2005focuszx3 is offline
Old 01-16-2014, 06:46 PM   #26
dooor
Fan#: 51395
What 2005FocusZX3 posted-yup.
dooor is offline
Old 02-03-2014, 05:28 PM   #27
sykozis
Fan#: 137929
What I Drive: 2005 Ford Focus
FF Reputation: 1 sykozis Good Standing Member
What I did was remove the filter box, then grab the tube that runs inside the fender and rip it out. Just grab it and pull down and towards the bumper. The plastic rips free rather easily. I originally used a "universal" Spectre kit to replace it all, but ended up putting a K&N CAI on back in the summer.
I believe the torqs screw in the wheel well is a T30. The other screws are 7mm if I remember correctly.
sykozis is offline
Old 02-20-2014, 04:58 PM   #28
focusmachnone
focusmachnone's Avatar
Fan#: 92770
What I Drive: 2004 TS Silver 2.3 Duratec
Points 819, Level 15
Points: 819, Level: 15 Points: 819, Level: 15 Points: 819, Level: 15
Level Up 19% Completed
FF Reputation: 1 focusmachnone Good Standing Member
2004 Pzev
Has anyone done this to a 2004? My exhaust mani is leaking and has a hole. Was thinking about a header but not sure what else I need to do to the motor to make one work. Just block it off? And do I need to get an Xcal and tune the car from stock. Ect Ect. Anybody done this and can help?
focusmachnone is offline
Old 07-11-2014, 11:53 AM   #29
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,255, Level 19
Points: 1,255, Level: 19 Points: 1,255, Level: 19 Points: 1,255, Level: 19
Level Up 55% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
I installed a spectre cone filter from advance auto to remove the non serviceable factory air box. Literally all you do is remove all the factory junk minus the maf tube, slip the cone over the stock maf tube (a little water or lube spray helps), tigthen a hose clamp around it, and drink beer.
Sounds better, little better throttle repsonse (when it wants to respond), and better mpg all around (city, highway, AC on, etc) when I'm not trying to make it sound better lol
Sedan Revolution Two Three Zero
FRPP, "Stealth" CAI, Debadged, wider tires, louder stereo, turbo mainfold in the wrong place...
Gettysburg150 is offline
