What is this part & where does it go? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-02-2014, 05:13 PM   #1
Rufino
Fan#: 132417
What I Drive: 2002white
FF Reputation: 1 Rufino Good Standing Member
It is a 2002 focus 2.0 L split port. I had to replace the thermostat housing. To do so I had to remove the distributor cap. Putting all back together this piece was left. Now judging by the wire that attaches to it. It mounts to one of the dust mounting bolts. However when I did that it sparks on the dist cap. The ford part number says it is capasitor assy. So where does it go?
Rufino is offline
Old 01-02-2014, 05:40 PM   #2
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,249, Level 46
Points: 5,249, Level: 46 Points: 5,249, Level: 46 Points: 5,249, Level: 46
Level Up 50% Completed
FF Reputation: 68 TerryB Excellent Standing Member
http://www.focusfanatics.com/forum/showthread.php?t=208353
http://www.focusfanatics.com/forum/s....php?p=3598577
TerryB is offline
Old 01-03-2014, 11:56 AM   #3
mmurphy
Fan#: 125417
What I Drive: 2001 blue se
FF Reputation: 3 mmurphy Good Standing Member
My 01 SPI has that bolted to the very top bolt on the coil pack. You should notice a mounting bracket that sticks out behind coil pack.
mmurphy is offline
Old 01-15-2014, 06:04 PM   #4
rnewscates
Fan#: 97162
What I Drive: 2000 Focus SPI, 1978 Lotus Esprit
FF Reputation: 1 rnewscates Good Standing Member
This mounts with an upper coil pack bolt, a single wire with grey connector plugs into it, the wire comes off the harness that goes over the injector rail to the IMRC, coil, and coolant temp sensor. It reduces RFI from the ignition. Bob Scates, 2000 SPI
rnewscates is offline
