Need pistons and help, anyone have a set? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-01-2014, 04:40 PM   #1
MRCTex
Fan#: 132185
What I Drive: 2004 Focus 2.0 SPI
FF Reputation: 1 MRCTex Good Standing Member
Just dropped the pan and found piston 3 skirt was completely destroyed in pieces laying in pan, cylinder wall looks ok though figure a new set of pistons should be the solution but any input would be appreciated. And does anyone know a good place for reasonable parts.
MRCTex is offline
Old 01-02-2014, 05:46 AM   #2
poppop
poppop's Avatar
Fan#: 59702
What I Drive: 2001,Red,LX
Points 278, Level 5
Points: 278, Level: 5 Points: 278, Level: 5 Points: 278, Level: 5
Level Up 56% Completed
Forum Activity 2%
FF Reputation: 2 poppop Good Standing Member
http://www.ebay.com/itm/Ford-Focus-2...rings-Pistons-
Used this set a few times with no problems.
Drop a seat?
poppop is offline
Old 01-15-2014, 06:20 PM   #3
rnewscates
Fan#: 97162
What I Drive: 2000 Focus SPI, 1978 Lotus Esprit
FF Reputation: 1 rnewscates Good Standing Member
I too have used a set of new std size pistons and rings from eBay, working great, 180 psi compression. Lightly hone your cylinders with a drill and oiled hone, clean bore thoroughly and use plenty of oil to install new pistons. While you have the pan off and especially if you put the engine on a stand (you have to take the head off anyway so you might as well pull it!) you should put new main and big end rod bearings in as well, although my engine had 115 K miles on it - the bearings looked virtually like new, a testament to how good the Ford block is! And of course new front and rear seals. All these things are not that expensive, and your engine will be like new, good for another 100 - 150 K miles! Bob Scates 2000 SPI sedan
rnewscates is offline
Old 04-09-2014, 05:15 AM   #4
03spi
Fan#: 93800
What I Drive: 2003 blue lx
Points 39, Level 1
Points: 39, Level: 1 Points: 39, Level: 1 Points: 39, Level: 1
Level Up 78% Completed
FF Reputation: 1 03spi Good Standing Member
Still looking send me a PM
03spi is offline
