looking for info on installing remote start/security system in 00-04 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-31-2013, 01:14 PM   #1
dahuss321
Fan#: 98208
What I Drive: 2004 silver sedan se
FF Reputation: 1 dahuss321 Good Standing Member
Lightbulb looking for info on installing remote start/security system in 00-04
Hello Focus Fanatics,
As a weekend project, i am going to install a "viper 5704v" remote start + security system in my 2004 focus on my own. The key bypass i am using is an "express-kit DB-ALL".
I have worked with countless electrical applications in my life so i do have a in-depth knowledge on how to install/work with these types of things. however this is my first remote start on a car that needs a key bypass. i have done A LOT of research and so far i am feeling pretty confident. i know that most would say to take it to a shop and have a pro do it but i would like to use this as a learning experience for myself, its not about the extra money it would cost.
While looking for info on doing this i came across many good videos and how-to guides but none on my car and as im sure many of you know all cars are different. as far as the wiring goes this is where in stuck, for both the db-all and the viper the best i can find is what each wire is (not where it goes) and for my car i can find where each wire is and the color and what not, but also nothing saying how to hook this up. it seems that a lot of this type of info is reserved for dealers and installers.
So the big question is.... I need some in depth info for both how to wire up both the express-kit db-all and the viper 5704v, specifically to my 2004 ford focus se
Any help would be appreciated, also i am new to this online community thing so if i left any info out please let me know. I hope to make a "how-to post" for all focus owners that are having the same issues after i get this all squared away.
Thanks,
Derek
Last edited by dahuss321; 12-31-2013 at 02:56 PM. Reason: unwanted/unhelpful replies
dahuss321 is offline
Old 12-31-2013, 01:45 PM   #2
gary the wolf
Fan#: 101265
What I Drive: 2003 white stationwagon
FF Reputation: 1 gary the wolf Good Standing Member
one mistake and "boom" there goes the airbag,,,pay the extra,,,,,
gary the wolf is offline
Old 12-31-2013, 08:04 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,872, Level 74
Points: 12,872, Level: 74 Points: 12,872, Level: 74 Points: 12,872, Level: 74
Level Up 6% Completed
Forum Activity 99%
Moved this one for you to an area that has similar threads.
If you search here some of the prev. answers may help while you wait for useful responses.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 12-31-2013, 08:58 PM   #4
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 2 ferret15 Good Standing Member
Not to be rude, but if you have say you have "in depth" knowledge It makes me thing you really don't. Don't be afraid to just say I don't know how, but I can splice wires together. *Edit: the viper kit looks easy enough, but that databus looks like you couldn't have found a more complicated bybass module. Either way the instructions are clear enough, just keep following the directions for ford pats with security and you should be fine, it even has a wire color code listed for whichever vehicle you want to use.
First make a 3 key for the transponder code. You NEED 2 or its back to dealership with ya to get a $150+ key made. otherwise buy a transponder key from the dealership or ebay and have it cut.
"to add a key....
1. Insert and existing (working) key into the ignition cylinder.
2. Turn the ignition cylinder ON (RUN) and back to OFF. Ignition should stay on for at least ONE SECOND.
3. Remove the existing key and, within TEN seconds, insert a second working key and turn it to ON (RUN) and the back OFF. Ignition must be in ON for at least ONE second, but no more than TEN seconds. Remove the key.
4. Insert the new key before TWENTY seconds have elapsed and turn it to ON (RUN). Leave it the ON position for at least ONE second and turn back to OFF.
5. The security light will light up for THREE seconds to indicate that the new key has been successfully programmed.
6. To program additional keys, repeat steps 1 through 5"
Now you need all the wire colors for an 04
]Here's the wiring info for a 2004...
Item Wire Color Polarity Wire Location
12 Volts red (30A) + ignition harness
Starter gray/black + ignition harness
Ignition green/yellow + ignition harness
Accessory yellow + ignition harness
Keysense red/black + ign harness or GEM, tan plug, pin 8
The GEM is above the passenger kick panel.
Power Lock black/red - driver kick or GEM, gry plug, pin 15
Power Unlock black/yellow - driver kick or GEM, gry plug, pin 21
Parking Lights orange/yellow + switch or GEM, tan plug, pin 14
Headlight green/red or green/blue + headlight switch
Reverse Light green/black + driver kick, harness to rear
Left Front Door Trigger see notes - GEM
The LF door is black/yellow in the tan plug, pin 22. The RF door is black/blue in the tan plug, pin 21. The LR door is black/orange in the green plug, pin 15. The RR door is black/green in the gray plug, pin 18. Use all four wires and diode isolate each. The GEM is above the passenger kick panel.
Dome Supervision black/blue - dr A pillar or GEM, gry plug, pin 3
Trunk/Hatch Pin black/blue or black/yellow - light in trunk/cargo area
Hood Pin black/yellow - pin switch or GEM, blu plug, pin 21
Trunk/Hatch Release black/yellow to white - switch or GEM, brn plug, pin 16
Factory Alarm Arm black/blue - driver kick or GEM, gry plug, pin 16
Factory Alarm Disarm black/white - driver kick or GEM, gry plug, pin 14
Disarm No Unlock see factory alarm disarm
Tachometer black/stripe ac any fuel injectorThe injector harness comes out the back rear side of the engine.
Speed Sense white/green ac radio harness
Brake Wiregreen/red to green/yellow + switch or GEM, tan plug, pin 9
Parking Brake black/red - parking brake switch
Horn Trigger black/blue or black/green - switch or GEM, brown plug, pin 14
Your kits should have some basic instruction like attach red wire to 12v + , so all you have left its to splice in your kit.
I feel like this is exaggerated but then again I could see somebody doing this.
ferret15 is offline
Old 12-31-2013, 11:09 PM   #5
fiveofocus
fiveofocus's Avatar
Fan#: 60237
What I Drive: 2013 Ford Focus SFE
Points 1,188, Level 18
Points: 1,188, Level: 18 Points: 1,188, Level: 18 Points: 1,188, Level: 18
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 fiveofocus Good Standing Member
Buy-Sell-Trade Rating: (4)
ugh good luck with the DB All!!! I hate them... I still use a blank new key and a 556UW about $20 total cost and never has an issue. Just installed a Viper 4203 starter on my 13 Focus with no issues!!
fiveofocus is offline
Old 01-01-2014, 03:02 PM   #6
dahuss321
Fan#: 98208
thanks guys...lots of help so far.
any info on the db all unit and how to wire it to my 04?
also I am confused as to how exactly to wire the remote start wires from the viper
these are the wires that i need to hook up
thanks,
derek
Old 01-01-2014, 03:10 PM   #7
dahuss321
Fan#: 98208
would this be the way to go? and would this one work with my car??
Old 01-01-2014, 06:41 PM   #8
fiveofocus
fiveofocus's Avatar
Fan#: 60237
Its the cheapest reliable way IMO as long as u already have 2 keys for your vehicle.
Old 01-03-2014, 03:41 PM   #9
dahuss321
Fan#: 98208
heavy gauge wires
still looking for some info on how to wire harness 3 from the viper system ...thanks any advice?
Old 01-18-2014, 08:42 PM   #10
supratt
Fan#: 136081
What I Drive: 2008 Ford Focus, 1992 Toyota Supra
FF Reputation: 1 supratt Good Standing Member
H3/1 Pink connects to ignition green/yellow
H3/2 Red/white connects to ignition red wire or to the car battery with a 30 amp fuse
H3/6 Red/white connects to ignition red wire or to the car battery with a 30 amp fuse
h3/3 Orange connects to ignition Yellow wire
H3/4 Violet connects to starter wire gray / black after the kill ignition relay the wire that is going to the starter not the key
H4/5 Green wire starter wire gray/back this is going the other way same wire to the key side
this is all you need don't use the rest of the wires for now
supratt is offline
