Great Big Exhaust Thread of Everything-Take Two - Page 23 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-19-2014, 01:57 AM   #221
Eminaga
Eminaga's Avatar
Fan#: 123953
What I Drive: 2014 Focus SE (Performance Blue)
Points 1,192, Level 18
Points: 1,192, Level: 18 Points: 1,192, Level: 18 Points: 1,192, Level: 18
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 24%
FF Reputation: 1 Eminaga Good Standing Member
Originally Posted by Toasty View Post
I have some questions about this, how do I raise the hangar up so it pulls the exhaust up? The hangar seems like its pretty fixed in its position and I'm unsure of how to really raise it up. Anyone have any pics of this?
What i did was buy new rubber things that go on the hanger that are shorter which raised my exhaust up by about 1"
*Snorkel/Shroud Delete, ITG Filter, Full ST Exhaust, E-RMM, Steeda RSB, Vogtland Springs, 180* T-Stat, Custom SCT Tune by Tom @ Focus-Power*
Eminaga is offline
Old 07-20-2014, 09:08 PM   #222
Toasty
Toasty's Avatar
Fan#: 135042
What I Drive: 2012 Candy Blue MK3
Points 364, Level 7
Points: 364, Level: 7 Points: 364, Level: 7 Points: 364, Level: 7
Level Up 28% Completed
FF Reputation: 1 Toasty Good Standing Member
This is probably the way I'm gonna go because I think I used a exhaust assembly paste to put the exhaust together...although I can't remember if I did use it or not. Either way it's gonna be a pain to unbolt it.
Did raising it the 1" bring it up enough to sit flush?
Toasty is offline
Old 07-22-2014, 07:21 PM   #223
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,894, Level 76
Points: 13,894, Level: 76 Points: 13,894, Level: 76 Points: 13,894, Level: 76
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
Forum Activity 5%
FF Reputation: 12 NickCornell Great Standing Member
It can't be flush, it will always sit under the bumper and just hang down there
#SonicsMK3Crew
Follow #projectstreetdevil on IG @BBNickC
BUILD THREAD: http://www.focusfanatics.com/forum/showthread.php?t=323533
NickCornell is offline
Old 07-23-2014, 03:40 PM   #224
Toasty
Toasty's Avatar
Fan#: 135042
Points 364, Level 7
I didn't mean flush exactly just meant snug with sufficient room lol. I guess what I am trying to say is, if the plastic is in the way how do I cut out the right sized hole without just eye balling it? I thought I would raise up the exhaust to see where on the plastic it hit and then measure the exhaust tips and cut just that much out, then more if I needed. My worry is I'll cut out the plastic and then the exhaust won't sit nicely because I cut the wrong place or I cut too much.
Toasty is offline
Old 07-24-2014, 10:03 AM   #225
NickCornell
Fan#: 97233
Forum Activity 5%
You can trace the exit of the tip placing the bottom flush with the bottom
#SonicsMK3Crew
Old 08-24-2014, 09:40 PM   #226
gmor08
Fan#: 181377
What I Drive: 2012 silver focus titanium
FF Reputation: 1 gmor08 Good Standing Member
Anyone know if you need the exhaust paste for the FSWerks exhaust? I'm about to order a kit and I don't think I need it. Anyone install one with and without that can give me some insite?
gmor08 is offline
Old 08-25-2014, 12:38 PM   #227
NickCornell
Fan#: 97233
Forum Activity 5%
I used some. Not the fswerks stuff though. Basically you want something that Is either so expandable and hard that It will never Crack and fall apart, or you want something expandable that remains flexible
#SonicsMK3Crew
Old 09-03-2014, 12:43 PM   #228
Mountainguy
Fan#: 187441
What I Drive: 2013 Tux Black HB 5 spd MT
Points 72, Level 1
Points: 72, Level: 1 Points: 72, Level: 1 Points: 72, Level: 1
Level Up 44% Completed
FF Reputation: 2 Mountainguy Good Standing Member
Anyone Cross-drill out their Muffler?
I had a Corvette a few years ago and found through a forum a way of drilling out the stock mufflers. I did that and it worked really well for moderately louder sound without droning or crackling. The method was to drill a one inch diameter hole in the muffler can over the area where the outlet pipe runs through. Then using that hole as an access port, drill a smaller (3/4 I think) hole clear through both sides of the outlet pipe inside the can. Then a metal snap in cap was installed with high tem silicone in the hole in the can to seal it.
Has anyone tried a similar thing with the Focus? Or does anyone know of a cutaway diagram/photo of the stock muffler (lunchbox)?
Mountainguy is offline
Old 09-03-2014, 03:08 PM   #229
Eminaga
Eminaga's Avatar
Fan#: 123953
Forum Activity 24%
sorry forgot about this thread. Yes bringing it up made it look way better.
Eminaga is offline
Old 09-04-2014, 03:48 AM   #230
MG_MK3
MG_MK3's Avatar
Fan#: 114522
What I Drive: 2013 Blue Candy Focus Hatchback SE
Points 500, Level 9
Points: 500, Level: 9 Points: 500, Level: 9 Points: 500, Level: 9
Level Up 50% Completed
Forum Activity 4%
FF Reputation: 0 MG_MK3 Newbie
I did install mine without and ran it like that for a year.. Lets just say it sounded awesome because all the leaks made a pretty sweet backfire/pop noise...
I just redid it (with paste) around april and have had no leaks, noise went down, and I went from 30 mpg to 33. Get the paste, do it right once. Or have it welded. I was told you didnt need the paste and it was just to suck some extra $'s out of you.
Exhaust works sucks, i hate doing it and I ended up pissing with this set up alot more than I ever wanted too.
2013 "Blue Candy" Focus Hatchback SE/DCT
AEM CAI | Steeda RMM | ST wing | TTR UMM
2.5 inch straight pipe | 3SDM 0.05 18"x8.5J | KSport Kontrol Pro's
Instagram @miKeyGilmore #MK3SLöCUS
MG_MK3 is offline
