master cylinder's internal check valve bad? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-17-2013, 09:02 PM   #1
bamakodaker
bamakodaker's Avatar
Fan#: 30132
What I Drive: 2005 Tweety Bird Yellow ZX3
FF Reputation: 1 bamakodaker Good Standing Member
2005 Focus ZX3
Hello,
My front right brake drags. Caliper, pads, lines, master cylinder replaced one year ago. Front right started dragging again.
Could it be this master cylinder's internal check valve is going bad?
Could vacuum leaks cause this?
Is there a brake or vacuum modulator that could cause the problem?
Much thanks for suggestions and help!
bamakodaker
bamakodaker is offline
Old 12-19-2013, 12:08 PM   #2
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
were the calipers new or remanufactured? Rebuilt parts are sometimes a roll of the dice, so it's not unthinkable that the piston is seized.
If it was a centralized problem (such as the master not fully releasing or faulty booster), then it would probably also be applying pressure to the other wheels, or at least to left-rear.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 12-20-2013, 06:27 PM   #3
bamakodaker
Fan#: 30132
Most likely these were reman parts.
bamakodaker
