Steering Knuckle Compatiabilty and ABS - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-12-2013, 08:17 PM   #1
JP1323
Fan#: 111226
What I Drive: 2003 Vermillion Red ZX3
FF Reputation: 1 JP1323 Good Standing Member
So a while back I had to replace my front wheel bearings, I ended up breaking one of my steering knuckles on the press. I was able to find a non abs knuckle which im still using but noticed my state inspection is in a couple months and my brake light is on due to the abs. Im asking about compatibility between newer model 2005+ knuckles and fitment on an earlier 00-04 cause the newer knuckles seem easier to find and just out of curiosity. Also, how can I not delete but disable the abs, does this have to be done through a dealership? Im assuming ecu reprogram??
JP1323 is offline
Old 12-12-2013, 09:43 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,788, Level 76
Points: 13,788, Level: 76 Points: 13,788, Level: 76 Points: 13,788, Level: 76
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Look for a pr of '05 only spindle's. Of course you need the abs ones. I believe the "S" models are the only non abs ones. You'll need to get a pr of '05-'11 ball joints or the lower arms. Then you can use the bigger '05-'11 brakes= 10.9'' over your stock 10''er's. Or the best option is the svt kit. Its a direct bolt on, including the brake hoses. Its a worth while upgrade as your braking is massivly going to be improved. One more thing is your struts will work w/ the '05 spindle's.
felixthecat is online now
Old 12-12-2013, 10:25 PM   #3
JP1323
Fan#: 111226
Cool thanks man! I was thinking about the svt kit but i kinda like my 15's lol. I wanted the rally brake kit to convert my rear drums but found out it was discontinued..
JP1323 is offline
Old 12-13-2013, 10:54 AM   #4
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Use the st= '05-'07 or the advance trac rear setup= 10''.
Old 12-13-2013, 07:09 PM   #5
JP1323
Fan#: 111226
Is the rear disc brake assembly for the 05-07 easy to come by? I would rather get everything in one shot like the kit rather than hunt down various parts. Is there any company you know of that just sells a rear disc conv kit? Would i need a master cylinder as well? I apologize for my newbness lol
JP1323 is offline
Old 12-14-2013, 10:20 AM   #6
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
You'd have to hit up a wrecking yard. Use the one you have= master cylinder.
