Contour hubs on 13" brake kit??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-12-2013, 07:57 PM   #1
silverknight
Fan#: 119736
What I Drive: 1993 Taurus SHO
FF Reputation: 1 silverknight Good Standing Member
Unhappy Contour hubs on 13" brake kit???
On the 04 ZX3 I had purchased, it has a 13" cobra brake kit, with what I assume would have to be the svt spindles. What is odd, is it appears to have a Ford Contour bearing and hub assembly.
I work at a parts store and compared the focus hub repair kit vs the contour hub repair kit, and the focus one is smaller. The contour kit is what is on the car somehow.
The problem is, the previous owner replaced the axle with a new unit, and its the correct size for the focus, which is too small on the splines for the contour setup.
Does anyone know if a contour axle may have been used? Did Ford have any other hub design from 00-08? All my part numbers are showing the same.
Could a contour spindle have been used for the cobra brake upgrade?
Thanks
1993 Taurus SHO 3.2L ATX - summer car
2004 Focus ZX3 2.3L ATX - track toy project
2004 Taurus SE - slow daily driver
2013 Focus Titanium - wife's car
silverknight is offline
Old 12-13-2013, 01:08 PM   #2
silverknight
Fan#: 119736
Well, I found a instruction sheet online for the Focus RS conversion kit and it seems new axles were part of the kit. However, none of the numbers from the kit interchange in any system including Ford. Tried calling the Ford Racing tech line, but they don't deal with that kit anymore based on age.
So I ordered a contour axle that looks close and will compare measurements to the stock focus replacement unit.
Old 12-13-2013, 05:34 PM   #3
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
If you do indeed have the RS knuckles, you are very fortunate. Those stronger hubs and bearings are great to have.
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 12-13-2013, 05:58 PM   #4
silverknight
Fan#: 119736
Well, it just seems they use the ford contour setup instead. The problem now is finding a correct axle to work with them. I don't think the RS kit was ever offered for the automatic setup.
Old 12-15-2013, 07:49 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,785, Level 76
Points: 13,785, Level: 76 Points: 13,785, Level: 76 Points: 13,785, Level: 76
Level Up 34% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Thanks
I'd say no, measure the length between the mounting ears of the spindle. The svt & '05+ spindles will take the cobra or any bbk. So that means you have svt or '05+ spindles. Check the axles vs hubs nows for compatabltie.
felixthecat is offline
Old 12-17-2013, 01:47 PM   #6
silverknight
Fan#: 119736
Measured, junkyard hunted, and went through a few vendors worth of part number searches.
My car has the RS knuckle and struts. Strut shaft size is larger than normal Focus, and the hub on the RS did match the Contour. Now the problem is still finding the correct axle.
I was trying to mate a Contour and Focus axle together, but the internals are different, so that wont work. I will be trying an axle rebuilder in a few weeks to see if they can do something for me.
Old 12-17-2013, 02:23 PM   #7
teamDFL
teamDFL's Avatar
Fan#: 92060
If you get stuck, call Marty at Raxles. He is very good, but offers a premium service and his prices are fair for what he does, but certainly not a bargain.
Would you mind doing me a favor? I am curious as to what the size of the pinch bolt clamp is. If you could measure where the strut goes into the clamp, I'd appreciate it.
teamDFL is offline
Old 12-17-2013, 03:20 PM   #8
silverknight
Fan#: 119736
i will get that spec tomorrow. done with the cold today. was at the junkyard for 3 hours trying to remove parts and re-engineer them.
