Difference between these front LCA - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-11-2013, 10:58 AM   #1
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,995, Level 40
Points: 3,995, Level: 40 Points: 3,995, Level: 40 Points: 3,995, Level: 40
Level Up 23% Completed
FF Reputation: 14 mac.mogul Great Standing Member
These are part numbers for lower right control arms on 09-11 US Focus
Motorcraft MCSOE98 (Special suspension W/Standard Suspension)
Motorcraft MCSOE119 (Performance Suspension)
I'm assuming the "performance suspension" refers to the SES/Coupe trim, but what is the ACTUAL difference between the two parts?
I am looking to buy the Raybestos LCA replacements, but if there is something about the "performance" parts that are different, I want to make sure I'm not downgrading to a less-capable part, or worse; buying a part that doesn't fit...
I can't find any documentation actually specifying what the differences are between these two parts. Anyone have a clue as to what separates them?
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 12-11-2013, 11:18 AM   #2
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,303, Level 46
Points: 5,303, Level: 46 Points: 5,303, Level: 46 Points: 5,303, Level: 46
Level Up 77% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 6 SlickWilly Good Standing Member
I forget exactly where but I remember reading for call's the S/SE suspension standard, SEL suspension special, and SES Performance.
The difference being the size of the sway bars and spring stiffness.
09 4F27E - K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - Nitrous Express Proton EFI - NX Launch Control & Progressive timer - NOS Window Switch
SlickWilly is offline
Old 12-11-2013, 11:25 AM   #3
mac.mogul
mac.mogul's Avatar
Fan#: 90409
That doesn't answer my question about the two different control arms...?
Old 12-11-2013, 11:51 PM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,762, Level 76
Points: 13,762, Level: 76 Points: 13,762, Level: 76 Points: 13,762, Level: 76
Level Up 28% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
I really don't think there is a difference. Yea, I'd say the same as you= the '10-'11 SES/coupe is the so called performance part. They do use slightly steeper gears thou, auto versions that is.
felixthecat is offline
Old 12-12-2013, 10:05 AM   #5
mac.mogul
mac.mogul's Avatar
Fan#: 90409
If there's no difference, why the separate part numbers?
Old 12-12-2013, 10:23 AM   #6
SlickWilly
SlickWilly's Avatar
Fan#: 116476
Forum Activity 15%
You can't call anyone from the site/Motorcraft and ask?
Old 12-12-2013, 11:42 AM   #7
mac.mogul
mac.mogul's Avatar
Fan#: 90409
I did more research and the most I could find is that the bushings are different on the performance suspension, but the arms themselves are physically the same.
There are different part numbers for the bushings on the performance suspension, although it does not appear that you can buy the bushings on their own as they are included with the control arms. Motorcraft lists a $40 price difference between the two different arms.
I really wish I could find out exactly what makes the performance bushings different. They appear to be the same rubber as everything else.
Old 12-12-2013, 09:06 PM   #8
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Looking at the bushings, you can't tell the difference in the hardness of the bushings. They look the same.
Old 12-12-2013, 09:27 PM   #9
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Whats wrong w/ your control arms? Why the replacement?
Old 12-13-2013, 10:01 AM   #10
mac.mogul
mac.mogul's Avatar
Fan#: 90409
Yes I know, they LOOK the same. Typically, if there is a performance difference in bushings, they will appear different either in color or texture of the material.
They are squeaky. Rather than buying new bushings I'd rather just buy a full LCA assembly with a new ball joint, but I don't want to buy a replacement with softer rubber... AFAIK, the aftermarket bushing kits are only for 00-04 and there are not aftermarket bushings for the 05-11 front LCA.
Its looking more like I will just have to put up with the squeak or try to lubricate the bushings I've got.
