Quick HID Question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 12-04-2013, 05:52 PM   #1
shb5007
Fan#: 58683
What I Drive: 04 SVT Focus
Points 2,944, Level 33
Points: 2,944, Level: 33 Points: 2,944, Level: 33 Points: 2,944, Level: 33
Level Up 30% Completed
FF Reputation: 1 shb5007 Good Standing Member
Quick HID Question
I did a search and I found some good info, but I am looking for a few quick answers.
OEM HID headlamps in a 2004 SVT Focus.
(R) side headlight low beam no longer functioning. Both high beams work and both fog lights work.
1.) How do I know if it is just a bulb? Do the ballasts go bad?
2.) If I need a bulb I was thinking about ordering these based on what I have been reading. Are these okay? http://www.theretrofitsource.com/pro...roducts_id=148
I will be taking both headlights out on Friday. Should I just go ahead and order the bulbs now? What are the chances it is a bulb? Are there any other things I can try / test a while?
shb5007 is offline
Old 12-04-2013, 06:09 PM   #2
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 7,819, Level 59
Points: 7,819, Level: 59 Points: 7,819, Level: 59 Points: 7,819, Level: 59
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 13%
FF Reputation: 9 ViperThreat Good Standing Member
1. The bulbs should be interchangable, try swapping them to see if that fixes the problem. Yes, ballasts can go bad.
2. Phillips Bulbs are quite good. I'm not sure if the bulbs you linked are the correct socket though.
Moderator For: Socal Fanatics | SVT Focus | Mk1 Focus | Audio & Electronics | General Chat
"Ford Focus ST - the official car of message-board circle-jerks"
-Regular Car Reviews
ViperThreat is offline
Old 12-04-2013, 06:59 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,915, Level 87
Points: 18,915, Level: 87 Points: 18,915, Level: 87 Points: 18,915, Level: 87
Level Up 13% Completed
Forum Activity 10%
Buy-Sell-Trade Rating: (4)
The bulbs should never go bad. They can, but it's rare. The salts will be black or dark brown if it's bad.
The ballast is the most likely cause of nonoperational lights.
If you open it up (T6 Torx) you'll probably find either evidence of water damage or water. That's what killed mine.
I ended up buying the kit from TRS (bulbs and ballasts) and swapping both my stock ones out. Does require you to modify the housings, but not real difficult.
iminhell is offline
Old 12-04-2013, 07:21 PM   #4
shb5007
Fan#: 58683
If the ballast is indeed bad, what are the options?
- Used OEM? Price?
- New OEM? Price?
- TRS kit? Price?
Any others?
shb5007 is offline
Old 12-04-2013, 07:59 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 10%
New OEM - $600 (or close to)
New aftermarket - $400 (or close)
TRS - $160 --> https://www.theretrofitsource.com/product_info.php?products_id=242
You can find used here sometimes or on Ebay. I didn't go that route because I didn't trust used parts.
iminhell is offline
Old 12-05-2013, 07:17 PM   #6
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,316, Level 35
Points: 3,316, Level: 35 Points: 3,316, Level: 35 Points: 3,316, Level: 35
Level Up 78% Completed
Forum Activity 2%
FF Reputation: 3 paulg127 Good Standing Member
I had a bulb go but, interestingly, it turned a pink hue before it went. It is know as 'pink eye for HID' so you know when you need a new one.
They are 'supposed' to last the life of the car, but you know how that goes.
I got mine on ebay, not the cheapest, or most expensive, I believe it was about $60 and a color rating of about 6000k which is a brighter white than the ~4300k stock. Looks great. 3 years so far no issues.
paulg127 is offline
Old 12-06-2013, 06:43 PM   #7
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,159, Level 74
Points: 13,159, Level: 74 Points: 13,159, Level: 74 Points: 13,159, Level: 74
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "SVT Focus".
zetecDon is online now
Old 12-06-2013, 09:56 PM   #8
shb5007
Fan#: 58683
Just to update everyone.
1.) Removed both headlights tonight and found one bulb had basically exploded (is that normal when HID bulbs go bad?), switched over the "good" bulb and the light lit up just fine. It appears both ballasts and igniters are still good to go. I got lucky.
2.) Ordered 2 new Phillips bulbs from TRS.
I kept out the bottom headlight bulb for easier removal in the future.
shb5007 is offline
Old 12-07-2013, 07:03 PM   #9
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,353, Level 20
Points: 1,353, Level: 20 Points: 1,353, Level: 20 Points: 1,353, Level: 20
Level Up 53% Completed
Forum Activity 12%
FF Reputation: 1 popwarhomie Good Standing Member
Those phillips bulbs are great
2010 Focus coupe 5 speed
Projector retrofit/LED tails/ Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/HDC3 18"s walled/ Juicebox G31/ DC power 270XP Alt/
94 Lightning
A lot of mods.
popwarhomie is offline
Old 12-08-2013, 05:30 AM   #10
Fierceintent
Fierceintent's Avatar
Fan#: 117556
What I Drive: 04 infra red Svt, 03 2.3 red sedan
Points 506, Level 10
Points: 506, Level: 10 Points: 506, Level: 10 Points: 506, Level: 10
Level Up 12% Completed
Forum Activity 2%
FF Reputation: 1 Fierceintent Good Standing Member
Was going to mention If the low beam wasn't working but the Highbeam was then It's not a ballast.
Fierceintent is offline
