Miles on Zetec - Page 88 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-11-2014, 09:19 PM   #871
n2mas
Fan#: 175929
What I Drive: 2001 Silver ZX3
FF Reputation: 1 n2mas Good Standing Member
'01 ZX3 with 260 K-plus miles
My father taught me the three things you don't loan out are your Wife, Your Focus, and your Computer!
n2mas is offline
Old 07-11-2014, 09:38 PM   #872
n2mas
Fan#: 175929
timing belt broke on me on the 134-170 interchange (traveleling 70ish MPH) .....thermostat housing cracked on me going from palmdale CA. to Hesperia CA on pearblossom highway (google it).... radiator inlet broke on me on 605 Freeway clylinder head temperature sensor went out on me on the 170 Freeway forcing my Focus into failsafe mode.
Fail safe mode: the computer shuts down two cylinders and uses both cylinders as heat pumps to prevent the block from cracking....thus allowing you to limp home....I drove at reduced speed for about 10 miles until I arrived home.
n2mas is offline
Old 07-14-2014, 08:56 AM   #873
eckertd
Fan#: 117288
What I Drive: 2001 Silver SE
FF Reputation: 1 eckertd Good Standing Member
I figured there were those with more miles than mine, I only have 11 miles each way to work.
I don't want to jinx things, but it's been a damn reliable car. A few issues here and there, but thankfully nothing major.
- Fuel pump (the recall issue) at about 20K
- Broken rear coil spring (recall/TSB) ~50K
- Alternator went at ~80K
- First brake/clutch job ~154K
- Throttle cable snapped ~175K
- Upper radiator hose ~180K
- Muffler hanger rusted through ~200K (welded a new one on, muffler is fine)
- Passenger side rear wheel bearing ~210K
- Low speed resistor/plug for the cooling fan burned out twice in the last 15K. I believe it's related to low refrigerant and the compressor continually cycling. It's OK for now, having just topped it off. Will wait and see...
There are a couple of irritating things I need to address. There's a rattle coming from the undercarriage somewhere - I think it's another busted/rusted exhaust hanger, just haven't had time to get under there and look. Driver side window struggles to roll up once it hits the halfway point. Sometimes it dead-stops in the middle and I need to coax it up manually. Probably (over) due for shocks/struts, should likely do motor mounts, and I know I'm on borrowed time with the timing belt...
Oh yeah...I also busted 2 of those plastic/composite shifter bases.
eckertd is offline
Old 07-14-2014, 09:49 AM   #874
MineTwine45
Zetec is Best 'Tec
MineTwine45's Avatar
Fan#: 138537
What I Drive: 2003 Silver Frost ZX5
Points 23,205, Level 93
Points: 23,205, Level: 93 Points: 23,205, Level: 93 Points: 23,205, Level: 93
Level Up 86% Completed
Forum Activity 99%
FF Reputation: 2 MineTwine45 Good Standing Member
You're lucky. Mine has 29,000 miles and the muffler is rusting apart at the welding seam. Isn't leaking yet, but I have a feeling it will be soon.
2003 Focus ZX5 "Ruth" Silver Frost - 33,000 Miles - Hatch Nation #98 - TakeOver #004
MineTwine45 is offline
Old 07-15-2014, 01:23 PM   #875
Tim_d33233
Fan#: 129762
What I Drive: 2000 Yellow Ford Focus ZX3
Points 171, Level 3
Points: 171, Level: 3 Points: 171, Level: 3 Points: 171, Level: 3
Level Up 43% Completed
Forum Activity 2%
FF Reputation: 1 Tim_d33233 Good Standing Member
00 with 155xxx. Still kickin!
Tim_d33233 is offline
Old 07-19-2014, 06:28 PM   #876
eckertd
Fan#: 117288
Update: Found (and stopped) the rattling. The fuel/return and brake lines that go the length of the car on the passenger side are held in place with little black plastic separators/holders. The fuel line had popped out of 2 of them and was banging on the underside of the floorboard, just under the front passenger seat. It snapped right back into place. Aaaahhh!! That was driving me NUTS!
The driver door window has all the symptoms of one or more of the channel/regulator clips being broken. I may order a set before I open it up..I hate messing with door panels and interior trim/clips.
eckertd is offline
Old 07-29-2014, 11:06 AM   #877
gottaba5spd
Fan#: 169922
What I Drive: 2000 Black ZX2
Points 842, Level 15
Points: 842, Level: 15 Points: 842, Level: 15 Points: 842, Level: 15
FF Reputation: 1 gottaba5spd Good Standing Member
'00 ZX2 with 172k on the clock. the engine has been really reliable, but i've been dealing with neglect everywhere else since i got it.
gottaba5spd is online now
Old 07-29-2014, 05:17 PM   #878
ZetecHamster
Fan#: 179393
What I Drive: 2002 Darker Red ZX3
Points 30, Level 1
Points: 30, Level: 1 Points: 30, Level: 1 Points: 30, Level: 1
Level Up 60% Completed
FF Reputation: 1 ZetecHamster Good Standing Member
02 with about 173k on it a little rusty, but still scooting along
ZetecHamster is offline
