Well, my luck finally ran out. Sheared teeth off my timing belt. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-28-2013, 08:38 AM   #1
Kal-EL428
Kal-EL428's Avatar
Fan#: 47337
What I Drive: 2002 SVT Sonic Blue
FF Reputation: 33 Kal-EL428 Great Standing Member
I have been really on the fence for the past year or so about getting my timing belt done because of the cost and I was really hoping to get a new car soon. Well, yesterday my luck ran out, during a cold start up in the morning, I sheared several teeth off the timing belt.
That’s the back story, the reason for the post is a question.
Is the process of changing the timing belt on a SVT the same as on a non-SVT Zetec?
My wife’s uncle owns a shop and while talking with him he made it seem like it was so easy and there was really nothing to it. He followed by saying he has done multiple Focus (Non –SVT).
I know from reading on FF that special tools are needed for the SVT timing belt swap. Are the same tools needed for a non-SVT timing belt change too?
I have never taken my car to a shop for work.
I have always done what I can in the driveway myself and I am a bit hesitant even though he is a professional.
02 Sonic Blue SVT
#2064 of 4788
Born on: 5-14-02
Kal-EL428 is offline
Old 11-28-2013, 08:50 AM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,708, Level 94
Points: 23,708, Level: 94 Points: 23,708, Level: 94 Points: 23,708, Level: 94
Level Up 36% Completed
Forum Activity 14%
In all fairness, never replaced a stripped belt on a VCT engine. usually I would just mark everything and make sure it goes back together. Not in your case.
Also, big mistake. I would put a belt on it anyway to see if it runs, but the SVT has very tight piston to valve clearances so you may have had some contact. Not exactly cost effective...
mikebontoft is online now
Old 11-28-2013, 08:59 AM   #3
Kal-EL428
Kal-EL428's Avatar
Fan#: 47337
I don't follow what you are saying?
Don't replace the damaged belt??
02 Sonic Blue SVT
#2064 of 4788
Born on: 5-14-02
Old 11-28-2013, 09:01 AM   #4
jwgstang
Fan#: 116398
What I Drive: 04 Sonic Blue Focus SVT
Points 1,757, Level 24
Points: 1,757, Level: 24 Points: 1,757, Level: 24 Points: 1,757, Level: 24
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 7%
FF Reputation: 1 jwgstang Good Standing Member
YES!!!!!!! it is totally different and a pain in the DO NOT LOOSEN THE CAM GEARS!!!!! just get the timing belt kit from gates if you need the pn I will get that for you and you will need the timing tools for the svt becase the zetec timing pin for the crank is just a bit smaller and just put everything back without loosening the cam gears. if you don't loosed them then theres no need to have a timing code unless you don't have the timing tools installed I made the mistake of taking the cam gears off when I rebuilt my svt and I took it apart more than 20 times to get it right!
jwgstang is offline
Old 11-28-2013, 11:30 AM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,915, Level 87
Points: 18,915, Level: 87 Points: 18,915, Level: 87 Points: 18,915, Level: 87
Level Up 13% Completed
Forum Activity 10%
Buy-Sell-Trade Rating: (4)
http://www.focusfanatics.com/forum/r...alldatapro.pdf
Just follow that guide and you'll be fine.
iminhell is offline
Old 11-28-2013, 02:02 PM   #6
BlueBronco1987
BlueBronco1987's Avatar
Fan#: 114133
What I Drive: 2002 CD Silver SVT ZX3
Points 725, Level 14
Points: 725, Level: 14 Points: 725, Level: 14 Points: 725, Level: 14
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 1 BlueBronco1987 Good Standing Member
You might get lucky. I've heard of a few people that had timing belts go in the driveway and didn't bend any valves.
BlueBronco1987 is offline
Old 11-28-2013, 03:06 PM   #7
Kal-EL428
Kal-EL428's Avatar
Fan#: 47337
Back to my original question, is the process for changing the belt on a SVT the same as a non-SVT??
Old 11-29-2013, 07:04 PM   #8
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
No, you have VCT on the intake. I would change belt without loosening the intake sprocket, it preserves the VCT phasing to the cam. But then I don't use the Ford procedure. When you do all that retiming you are actually doing it to simply get the cam-to-sprocket relationship right back to where it was before engine ever torn down and silly to me.
Other than that they are the same pretty much, but the VCT greatly complicates issues for the novice once that VCT sprocket gets loosened.
The link above explains how to time the cams but at page 14 step 12 is where the problems can begin. If the tool does not go back in the back of intake cam after turning engine two turns, the VCT may have moved away from it's 'zero stop position' (conveniently not mentioned AT ALL in the procedure and still a mistake years later) instead of the cam needing the sprocket re-adjusted. Normal since the oil pressure drops off with engine not running to let the VCT move around. If you simply loosen and move the sprocket again you may have messed up and engine will post a code for it. Why I say not to loosen intake sprocket but once you do that the entire Ford procedure given there is worthless and you must know how to do it other ways.
An extra step is needed for VCT engines, when you get ready to put the tool in back of cams you first have to make sure the intake cam is pulled up solid to its' stop inside the VCT sprocket assembly. THEN put the tool in back of cams, if the VCT has slipped rather than the cam not being correct to begin with then the tool will slide right in and correct.
So the difference?
Regular zetec cam timing by crank pin tool in place on #1 @ TDC and cam tool fitted in back of cams.
SVT zetec, cam timing by crank pin tool in place on #1 @ TDC and cam tool fitted in back of cams AFTER VCT is known to be on the end stop position.
FYI, the Ford procedure loosens sprockets to allow all slack to be taken up by tensioner but it ALSO allows the VCT to 'spring up' to its' end stop position since the sprocket has the cam internally loaded to spring one way based on the spring inside the VCT cylinder. It's just that sometimes when engine is turned around the two times, the VCT has leaked oil and the cylinder lets the cam drop back a little bit due to cam being held back by friction caused by valvespring tension. Hence the need to pull VCT back up to end stop again. In fact you have to guarantee VCT is on the stop every time you roll around to recheck cam timing.
Get it right and I guarantee starting up and no issues at all. Been doing it on Contour VCT and no issues ever.
amc49 is offline
Old 11-30-2013, 11:49 AM   #9
Kal-EL428
Kal-EL428's Avatar
Fan#: 47337
SVT #2064 lives on!!!!
The shop just called and told me everything went well and that there was no damage to the head and valves.
They replaced the belt, tensioners and water pump and it only cost me $430 for parts , labor and a 20 mile tow!
02 Sonic Blue SVT
#2064 of 4788
Born on: 5-14-02
Old 11-30-2013, 12:13 PM   #10
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,567, Level 100
Points: 52,567, Level: 100 Points: 52,567, Level: 100 Points: 52,567, Level: 100
Level Up 0% Completed
Forum Activity 58%
Activity: 58% Activity: 58% Activity: 58%
Buy-Sell-Trade Rating: (28)
Now drive about 50-100 miles and see if the light comes on for over or under adv
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
