04 SVT Sway bar hitting / bang noise? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-27-2013, 05:38 PM   #1
PublicTimeGuy
Fan#: 119896
What I Drive: 2004 Screaming Yellow SVT
FF Reputation: 1 PublicTimeGuy Good Standing Member
I have been chasing a mysterious 'bang' from the front right when going over potholes/bridge seams, etc. Car has 97k, completely stock. I have replaced both front struts, top strut bearing, all end-links, tie-rod ends and it's still there. Finally I took a look when it was up on the lift and I can see the sway-bar is hitting a return vapor line next to the fire-wall (I could see a small area where it contacts). The mechanic tried to bend the line away (there's not much room!), but the bang is still there. I can't see anywhere else anything is contacting and yielding such a noise. Do you think new springs will solve the problem? Thanks in advance for your comments.
PublicTimeGuy is offline
Old 11-28-2013, 02:53 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Sway bar bushings. I'd replace them w/ poly ones. How 'bout putting it on a alignment rack & rocking it up & down to see if you can see if & where it hits something.
felixthecat is offline
Old 11-29-2013, 07:15 PM   #3
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,868, Level 25
Points: 1,868, Level: 25 Points: 1,868, Level: 25 Points: 1,868, Level: 25
Level Up 68% Completed
Forum Activity 2%
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
I doubt it is a spring issue. My '04 SVT has 75K, with original springs (36K mi.) new SVT struts/shocks and endlinks. Same issue. I would dearly love to solve this issue. Mine seems to do it more when the RF tire falls into a hole(extension vs. compression), rather than hitting an obstacle (like a speed bump or frost heave).
I have not yet changed sway bar bushings, but will do so once the temp gets up to 40F. Thanks, Felix!
mainest is online now
Old 04-29-2014, 05:32 PM   #4
PublicTimeGuy
Fan#: 119896
Front Suspension BANG Solved
OK Team...
Finally took the car in. Despite the mechanic saying the front sway bar bushings were fine, had them replaced anyway. Guess what - BANG (from the front passenger firewall area) is gone. I'm so relieved - it was incredibly annoying, especially when driving with The Wife who knows how much the car cost and continues costing! Thanks for all the input...
Despite appearances, the bushings must degrade with age....
Old 04-29-2014, 05:55 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,363, Level 75
Points: 13,363, Level: 75 Points: 13,363, Level: 75 Points: 13,363, Level: 75
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 99%
Tx for posting your solution!
Adds to the list of known "fixes" we can pass on.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 04-29-2014, 11:35 PM   #6
sandman503
Fan#: 111841
What I Drive: 93, green, jeep ZJ
Points 385, Level 7
Points: 385, Level: 7 Points: 385, Level: 7 Points: 385, Level: 7
Level Up 70% Completed
Forum Activity 3%
FF Reputation: 1 sandman503 Good Standing Member
I had a bang, it was because the sway bar had shifted to the drivers side.
sandman503 is offline
