Rear Sway bar Help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-26-2013, 09:46 PM   #1
falcon9du5w0
Fan#: 108860
What I Drive: 2013, tuxedo black, focus se
FF Reputation: 1 falcon9du5w0 Good Standing Member
Rear Sway bar Help
Hello all I purchased a used Whiteline rear sway bar and long story short while installing it I cross threaded the bottom left bolt. Ive already gone up to home depot and they didn't have a clue how to fix it. Thanks
falcon9du5w0 is offline
Old 11-26-2013, 11:18 PM   #2
Creative
Creative's Avatar
Fan#: 108024
What I Drive: 2013 Ford Focus
Points 3,615, Level 37
Points: 3,615, Level: 37 Points: 3,615, Level: 37 Points: 3,615, Level: 37
Level Up 77% Completed
FF Reputation: 3 Creative Good Standing Member
Go to autoparts store and get a tap and die set I think the one you need is a m12x1.5. If you are very careful you can re tap the hole witnout having to use a helicoil kit other wise you will have to use a helicoil kit.
If you try to retap it use a ratchet and crank it in and out of hole with wd40 or a good lubricant to keep metal shaving out of the hole. This is what I normally do when I have an issue. This take time and patients.
And you are referring to the bolt that attaches the busing and bracket to the frame right?
Originally Posted by Dialed View Post
Let's be honest guys, car modding is not synonymous with warranty-covered cars.
As the old saying goes, you have to pay to play.
Creative is offline
Old 11-26-2013, 11:21 PM   #3
falcon9du5w0
Fan#: 108860
Yes I am thanks for the info.
Old 11-27-2013, 01:19 AM   #4
ProjectCommuter
ProjectCommuter's Avatar
Fan#: 105046
What I Drive: 2012 Oxford White Focus SE 5MT
Points 602, Level 12
Points: 602, Level: 12 Points: 602, Level: 12 Points: 602, Level: 12
Level Up 4% Completed
FF Reputation: 2 ProjectCommuter Good Standing Member
Are you sure you cross threaded it? I'm just asking because they put a crap load of thread locker on those bolts and I had a hard time getting them back in when I installed my Steeda bar. I had to use a stick lighter to burn off the thread locker to get the bolt back in.
2012 Focus SE Hatch 5 MT - AEM Dry Drop-In, Snorkel Delete and custom AirBox Mod, eFocus RMM, FSWerks Stealth Exhaust, Steeda RSB, Mobil-1 0w-20, INJECTED 91 Tune
ProjectCommuter is offline
Old 11-27-2013, 01:21 AM   #5
falcon9du5w0
Fan#: 108860
Oh dang I didn't think about that I'll try it in the morning and see what happens thanks.
Old 11-28-2013, 01:35 AM   #6
falcon9du5w0
Fan#: 108860
Solved it was the thread lock stuff love the sway bar feels much better going into corners the only issue is under heavy breaking the car kind of sqeaks I guess everything needs to break in.
Old 11-28-2013, 01:02 PM   #7
ProjectCommuter
Fan#: 105046
Awesome. Good to hear. Did it come with grease for the poly bushings? My Steeda bar did and it doesn't squeak. But, the spare in the back does make noise. The arm on the jack pops up and hits the spare and the rubber of the tire squeaks on the metal of the frame. I stuffed some old socks in there and it fixed it.
Old 11-28-2013, 08:03 PM   #8
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,076, Level 50
Points: 6,076, Level: 50 Points: 6,076, Level: 50 Points: 6,076, Level: 50
Level Up 63% Completed
Forum Activity 2%
FF Reputation: 9 Deftmetal Good Standing Member
Moved to Brakes, Suspension & Chassis
He bought it used from me. Hopefully it's just some dirt or extra thread locker in the hole.
Rally Revolution #14
Josh
Originally Posted by dyn085 View Post
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is offline
Old 11-28-2013, 09:25 PM   #9
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,117, Level 34
Points: 3,117, Level: 34 Points: 3,117, Level: 34 Points: 3,117, Level: 34
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 4%
FF Reputation: 9 emsvitil Good Standing Member
Can you get a longer bolt, drill out the threads; then add a nut on the backside?
Ed
emsvitil is offline
