Brake Line Size - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-26-2013, 08:54 PM   #1
nomind
Fan#: 95234
What I Drive: 2000 Primer ZX3
FF Reputation: 3 nomind Good Standing Member
Brake Line Size
So...while doing a transmission swap, I managed to crush one of the hard lines on my 2000 ZX3. Does anyone know what size the brake lines is, and what size the fittings are? I'd like to have the necessary supplies before I start pulling the old line off.
nomind is offline
Old 11-26-2013, 09:16 PM   #2
rexazz2
rexazz2's Avatar
Fan#: 121761
What I Drive: 2014 HB SE
Points 1,928, Level 26
Points: 1,928, Level: 26 Points: 1,928, Level: 26 Points: 1,928, Level: 26
Level Up 28% Completed
Forum Activity 12%
FF Reputation: 1 rexazz2 Good Standing Member
I suggest removing the old line including the fittings and taking them with you so get the matching fittings and flare style
Another thing that sometimes makes life easier is using multiple pieces and using a union to join then back up
The brake lines are usually originaly installed when the engine bay is empty so it going back in in one pre bent piece is some times nearly impossible
rexazz2 is offline
Old 11-26-2013, 11:13 PM   #3
nomind
Fan#: 95234
I was considering running a whole new line, as its just to the front driver's side of the car, but I'm thinking that just using a compression fitting set, and just replacing that short run would be much easier. It would probably take less than 18" of line to get to a spot that I could use the compression fittings, and not have any issues. I'm just not sure if I have enough line in the wheel well to try and use a second compression fitting, and most of the short runs available at the part store already have the fittings on them, so it would just be the that small run. If I cannot find the info before hand, I will be cutting the line, and taking it to the parts store. Like I said, I'd just like to already have the supplies on hand.
Or I can dig out the double flare kit, and use an appropriate union, as apparently, not many compression fittings out there that are actually for brake line use.
nomind is offline
Old 11-27-2013, 02:01 AM   #4
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
3/16" hardline
10mm bubble flare
If you can find a ISO bubble flare tool, piece of cake.
If you already have a 45* IFF double flare tool:
You can cut and reflare the hardline with a traditional 3/8"-24 tube nut and 45* inverted double flare like all American cars have used for 40+ years, then use an adapter fitting to convert it to 10mm bubble flare at the end where the hose attaches. (Brake Quip part #BQ-49)
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 11-27-2013, 02:16 AM   #5
elsolo
elsolo's Avatar
Fan#: 96835
BrakeQuip part listing:
http://www.brakequip.com/mfthread.html
10mm ISO flare:
3/8-24 IFF flare:
Pair of BQ-49 adapter fittings on left (showing female and male ends), tube nuts for both styles on right:
another pic of those fittings, and a IFF flaring tool most mechanics have in their box.
If you can borrow a ISO bubble flare too, ignore the adapter nonsense and just reuse the old tube nuts and make a new hardline with 3/16" tubing found at every NAPA autoparts store.
elsolo is offline
Old 11-27-2013, 05:13 PM   #6
rexazz2
rexazz2's Avatar
Fan#: 121761
Forum Activity 12%
NO compression fitting is rated for brake issues
At best you could invert flare it and use a 3/16 inverted union
rexazz2 is offline
Old 11-27-2013, 07:28 PM   #7
Dgc333
Fan#: 85422
What I Drive: 2012, candy blue, SEL
Points 750, Level 14
Points: 750, Level: 14 Points: 750, Level: 14 Points: 750, Level: 14
Level Up 50% Completed
FF Reputation: 1 Dgc333 Good Standing Member
Typical 3/16 steel brake line is rated for around 9-10,000 psi. You can get compression fittings designed to operate at that pressure from most all fitting manufacturers like Swaglok or Parker-Hannifin.
Your brake system operates around 1,500 to 2,000 psi so you have over a 4x safety margin.
I would agree the brass compression fittings you get at the hardware store that are designed to be used with soft tubing such as copper or plastic are not up to the task but to categorically say compression fittings are not rated for brake use is wrong.
FWIW, the reason flare fittings are used in auto applications is because in a high volume manufacturing environment its cheaper.
Dgc333 is offline
Old 11-27-2013, 07:44 PM   #8
rexazz2
rexazz2's Avatar
Fan#: 121761
Forum Activity 12%
A mechanic doing a safety inspection would fail the vehicle if they spotted a compression fitting
I have seen shops that use copper line because they said it bends/flares easier
Again probably not the best route to take but some guys work that way
rexazz2 is offline
Old 11-27-2013, 07:57 PM   #9
elsolo
elsolo's Avatar
Fan#: 96835
Don't use a compression fitting.
Flare, tube nut, union
Or just remake/replace the entire hardline.
The tubing is very cheap, making brake lines is fun and easy
What's the difference in making a 12" hardline with a couple bends or a 40" harline with a few bends?
elsolo is offline
Old 11-27-2013, 08:55 PM   #10
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
... and?
And that the law states compression fittings are illegal. DOT, FMVSS, SAE and various foreign bodies are all on the same page for brake fittings and lines.
http://www.fmcsa.dot.gov/rules-regul...px?reg=571.106
Even for air brakes you can't use compression fittings.
iminhell is offline
