please help new to obd2 diagnostics - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-26-2013, 05:05 PM   #1
nine!
Fan#: 125145
What I Drive: 76 f100 I6- 01 zx3 - 03 zx5
FF Reputation: 1 nine! Good Standing Member
hello everyone Im working on a friends 2003 zx5 vin3 2.0 zetec. the car has been here 6 months it started over a timing belt. when the timing belt broke it caused internal engine damage so she decided to go with a rebuilt long block. took her up till a few weeks ago to save for it. last week I got the lonblock from the shop, assembled it and installed it now I have a p2195 dtc "o2 sensor switch stuck lean''. im new to ob2 as I normally work on carburated vehicles, I was told to data stream first so I did. 02s1 seems to be switching a lot like I was told it should (.2-.9) but at idle (idles horiblly) reads .03- .07, I did not even pay attention to s2 at first but noticed on the freeze data it was .0 could this cause my problem? also at idle my maf was .6lb/m and timing was 28, does this seem right? ive tried searching for a reference to compare but couldn't find anything. she doesn't have much to spend on parts so I need to narrow this down before I buy smthn she might not need. I also sprayed the intake and vacume lines w starting fluid thinkin it could be a vacuum leak still came up with nothing. if anyone could help me with reference values it would be greatly appreciated. thanks
nine! is offline
Old 11-27-2013, 03:05 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,505, Level 100
Points: 52,505, Level: 100 Points: 52,505, Level: 100 Points: 52,505, Level: 100
Level Up 0% Completed
Forum Activity 51%
Activity: 51% Activity: 51% Activity: 51%
Buy-Sell-Trade Rating: (28)
Give me a call I will try to help 704-249-3745
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 11-27-2013, 05:57 PM   #3
nine!
Fan#: 125145
thanks tom I would deff appreciate the help, I tried a lil while ago Ill pm you my #
I did some more data logging and o2 #1 goes from .1-.9 and #2 was .0-.07 at cold start (1300rp) with the code erased, runs 3-5 mins drops to under 1000rpm and runs like crap, then 02 #1 goes .03-.07 and stays there from 800rpm to 2500rpm.
nine! is offline
Old 11-29-2013, 05:53 PM   #4
nine!
Fan#: 125145
thanks for the call tom, i went ahead and replaced the 02 sensor #1 because i didnt trust it and the car has 117k so it was about time to anyway. didnt help im still getting the same fuel system fault, same dtc and stft's in high 20's low 30's. i checked my fuel rail pressure with a inline gauge today and 36psi at idle.
nine! is offline
