looking for help zx3 running poorly - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-26-2013, 01:09 PM   #1
injen78
Fan#: 125081
What I Drive: 01 Black zx3
Points 73, Level 1
Points: 73, Level: 1 Points: 73, Level: 1 Points: 73, Level: 1
Level Up 46% Completed
FF Reputation: 1 injen78 Good Standing Member
have an 01 zx3 and it has been running very poorly the past couple months.
i brought it to have the CEL checked last week and it was throwing a code for the TPS sensor and IACV, so i replaced the IACV(second time in 2 months), and went back to have the codes run. now im only getting a CEL for o2 sensors and IACV. the car runs like garbage, at initial start up it idles high and has a sputter, then will idle down and act as if its going to die, then jump back up, bog out....etc. the whole time it sputters.
replaced- iacv(2x), plugs, wires, catalytic converter, egr, oil/filter, fuel filter, vc gasket, rear pcv hose(original had collapsed) and new pcv
cleaned- throttle body, MAF
looked at- vacuum hoses, had a smoke test run on it and its passing.
really looking for some pointers as to what to look at now. could possibly get a video of how its running later if someone would be interested in helping me put it up.
injen78 is offline
Old 11-26-2013, 08:45 PM   #2
Highball116
Fan#: 112564
What I Drive: 2005 Red ZX4
Points 654, Level 13
Points: 654, Level: 13 Points: 654, Level: 13 Points: 654, Level: 13
Level Up 8% Completed
Forum Activity 5%
FF Reputation: 3 Highball116 Good Standing Member
What are the exact codes for oxygen sensors? Depending what they are, it could be a failure of one or both of the sensors.
Toby
Highball116 is offline
Old 11-27-2013, 05:04 PM   #3
injen78
Fan#: 125081
Points 73, Level 1
i cant remember exactly but one of them was a malfunctioning heating switch i believe. i really doubt the o2 sensors being bad would be causing it to run the way it does. its acting as if theres a major sensor unplugged, but the scan tool shows otherwise.
injen78 is offline
Old 11-27-2013, 05:23 PM   #4
Highball116
Fan#: 112564
Forum Activity 5%
If the code was for an internal fault in the upstream heated oxygen sensor, then that's your problem right there. The upstream oxygen sensor contributes a lot to performance. The downstream oxygen sensor does not, and is only there to check for excessive emissions. Get the code checked again, but if it's the upstream heated oxygen sensor, that'll cause a lot of problems.
Toby
Old 11-27-2013, 05:51 PM   #5
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
You're looking at STFT/O2 Voltage, which is not the heater circuit.
Check the fuses.
If they are good look at the heater duty cycle.
iminhell is offline
Old 11-30-2013, 07:27 PM   #6
injen78
Fan#: 125081
Points 73, Level 1
Codes are as follows
p1506-Idle Air Contol Overspeed Error
p0136-Oxygen O2 Sensor Circuit Low Voltage (Bank 1, Sensor 2)
p0135-O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction
the tech also said something about p2271 and p2270 which are related to the o2 signals/heaters
so what im going to assume is that a vacuum leak causing too much unmetered air to be burned which is making the engine run lean(o2 incorrect reading) and making it run fast(iac incorrect)
but ive been messing with the vacuum lines and havent really come up with anything.
first o2 is $43.99
second o2 is $65.99
coil pack is $90
and then theres various vacuum hoses that could need replaced.
injen78 is offline
Old 11-30-2013, 10:31 PM   #7
Highball116
Fan#: 112564
Forum Activity 5%
One of the codes indicates a malfunction in the heater circuit of the upstream oxygen sensor. See my original post. Internal faults supersede abnormal readings, and are always the roots of poor performance; not mere symptoms.
Toby
Old 12-02-2013, 05:07 PM   #8
cheap sleeper
cheap sleeper's Avatar
Fan#: 59848
What I Drive: 2001 black zx3
Points 918, Level 16
Points: 918, Level: 16 Points: 918, Level: 16 Points: 918, Level: 16
Level Up 18% Completed
FF Reputation: 5 cheap sleeper Good Standing Member
coil pack, faulty battery cables, tps, dirty maf, fuel pump screen clogged or fuel pump failure. these all are common reasons why our cars will run like poo. i would check the coil pack first.
cheap sleeper is online now
Old 12-03-2013, 10:36 AM   #9
injen78
Fan#: 125081
Points 73, Level 1
Toby
So replace the upstream o2? Ill give it a shot but i really doubt a bad o2 r and o2 with abnormal readings will make the car sputter, lope, and die at idle. But i do appreciate the ideas.
Coil pack is one of the things id like to replace first, but money is the issue, im hoping that my buddy with a zx3 will let me test some parts before buying new.
injen78 is offline
Old 12-04-2013, 07:33 AM   #10
Highball116
Fan#: 112564
Forum Activity 5%
Just to reiterate, you have a code for a malfunctioning upstream oxygen sensor. The only recommended repairs are to replace the sensor, or repair the wiring: http://www.obd-codes.com/p0135. Also, the upstream oxygen sensor contributes a lot to performance, as it informs the air-fuel ratio. You're thinking of the downstream oxygen sensor, which is only there to track emissions.
Toby
