2001 Focus blew a fuse and now major electrical issues - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-25-2013, 11:09 PM   #1
fbadam54
Fan#: 124937
What I Drive: 2001 Ford focus
FF Reputation: 1 fbadam54 Good Standing Member
Hello all,
So my buddy tried to run a hot wire into his fuse panel( the horn fuse 20amps) the wire melted and obviously got hot. When we turned on the car there was no instrument illumination but all the dummy lights lit up like normal. No daytime running lights, head or tail, however high beams work. Radio had no power, when you turn the lights on manually nothing happens. No brake lights, and the reading lamps don't work either. Cigarette lighter also doesn't work. No fuses are blown in the driver's panel or underneath the hood. At least the ones that you can visually inspect. We are both Army and are trying to fix this before the four day break for Turkey day. Any info out advice would help a lot. Thanks in advance.
fbadam54 is offline
Old 11-26-2013, 02:07 AM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
Ahead of the 20amp cigar lighter fuse, there is a 40amp fuse (listed as #7) near the battery box. That feeds the entire fusebox behind the dashboard and all the circuits you say are dead.
Figure out where you still have +volts on the fuseboxe(s), then we can backtrack the power distribution from there.
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 11-26-2013, 07:26 AM   #3
fbadam54
Fan#: 124937
Ok I'll look into that today, I have a tester so I'll start there and hopefully that is all that is, thank you for that quick response
fbadam54 is offline
Old 11-26-2013, 08:53 AM   #4
KCaudill
Fan#: 46826
What I Drive: 2006 Tredour Red ZX3 SE
Points 334, Level 6
Points: 334, Level: 6 Points: 334, Level: 6 Points: 334, Level: 6
Level Up 68% Completed
FF Reputation: 1 KCaudill Good Standing Member
And tell your buddy to never touch a wire again. The wire got hot and melted because there was no fuse to protect it. One end was grounded and other was to the battery +.
KCaudill is offline
Old 11-27-2013, 03:55 AM   #5
amc49
Fan#: 96610
Points 3,376, Level 36
Points: 3,376, Level: 36 Points: 3,376, Level: 36 Points: 3,376, Level: 36
Level Up 18% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Assuming wire got run, when it melted whatever other wiring it was in contact with or lying alongside of could easily be damaged now, until you find and fix the hot spots where other wires could've melted together you may possibly still have issues......................sometimes not though, luck of the draw there.
Hoping you guys don't work on tanks or choppers...............LOL
amc49 is offline
