throttle body replacement? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-25-2013, 03:04 PM   #1
smokeytheape
Fan#: 124841
What I Drive: 2005 red focus zx5
FF Reputation: 1 smokeytheape Good Standing Member
Hi all,
I'm new to the focus forums and have an issue. Last winter I noticed that my accelerator was sticking a little bit, and looked into the issue. I found a few different threads in forums explaining that this was caused by my throttle body being (using someone else's words) poorly designed.
If I understood what I read correctly, the plastic throttle inside of the body expands and contracts based on weather, and this is causing it to stick. Also there is a chance of gunk build-up on the the flap.
I know next to nothing about car mechanics, and am not confident in starting to poke around my engine. I contacted my local dealer, and they said that a new stock throttle body would cost me ~$400 Canadian, plus installation. This brings me to my question; I've come to the decision that I would rather replace my throttle body than to clean, and potentially not fix my current TB.
What is a good upgrade/replacement for my focus? I heard CFM mentioned and briefly looked into that ($250 for a TB instead of 400). Is this a good product to go with? Is it even the correct size for my car? (link related, its the TB from CFM that I was looking at) http://www.c-f-m.com/performancepart...m#.UpOp6sTkt3g
Any and all help would be greatly appreciated,
Regards,
Adam
smokeytheape is offline
Old 11-25-2013, 03:08 PM   #2
Tdubbs1989
Fan#: 116903
What I Drive: 2002 CD Silver SVT #695
Points 115, Level 2
Points: 115, Level: 2 Points: 115, Level: 2 Points: 115, Level: 2
Level Up 30% Completed
FF Reputation: 2 Tdubbs1989 Good Standing Member
Yes the CFM throttle is a good product if you wish to go that route. You can either reuse your stock gasket or get a new one if you prefer too. If you have a stick it'll take a little getting used to, but if its auto no prob. It is a direct bolt on replacement and even comes with the bits you'll need to remove your old one. All you need to reuse is the factory tps sensor on the side of the throttle body.
2002 Focus SVT CD Silver/Blue Inserts
#695 of #4788
Tdubbs1989 is offline
Old 11-25-2013, 03:10 PM   #3
smokeytheape
Fan#: 124841
Is 67mm the proper replacement size? I also saw a 65mm in their inventory
Old 11-25-2013, 03:29 PM   #4
Tdubbs1989
Fan#: 116903
Points 115, Level 2
Yes, the 67mm is the one you want, the 65mm is for the older Zetec engine, just make sure when you order it get the one for the Duratec and not the SVT, its different.
#695 of #4788
Old 11-25-2013, 03:36 PM   #5
smokeytheape
Fan#: 124841
Awesome. Thanks a ton for the quick response to the thread. This helps a lot.
Old 11-25-2013, 06:01 PM   #6
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,910, Level 76
Points: 13,910, Level: 76 Points: 13,910, Level: 76 Points: 13,910, Level: 76
Level Up 65% Completed
Forum Activity 8%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
FYI, the C-F-M TB is more of an upgrade not a "replacement" its a larger diameter than stock, it will increase throttle response and you will have a lighter pedal feel. Having said that it is an amazing mod, it will really wake up the car and make it more fun to drive!
SkyPilot is online now
