Winter wheels for st3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-25-2013, 01:20 PM   #1
vping
vping's Avatar
Fan#: 120443
What I Drive: 2014 PB ST3
FF Reputation: 1 vping Good Standing Member
will these fit over my calipers?
"Set of 4 VOLVO STEEL WHEELS - Perfect for Winter Snow Tires
KFZ STAHLRAD AR-0993 7J x 16
Lug Pattern 5 x 108.0 mm
Hub Opening Diameter 65 mm
Offset 49 mm
Max Load 1,320 lbs
Made in Switzerland
Fits following VOLVO models:
60 Series (2001-2009)
70 Series (2001-2007)
80 Series (1999-2005)
Very good condition, run true, no curb damage, valve stems included, ready for snow tires.
vping is offline
Old 11-25-2013, 05:09 PM   #2
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,097, Level 34
Points: 3,097, Level: 34 Points: 3,097, Level: 34 Points: 3,097, Level: 34
Level Up 32% Completed
FF Reputation: 11 hEaT Great Standing Member
Can you test fit one? It's a possible, but because they're 16" I wouldn't say yes, definitely.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 11-25-2013, 06:09 PM   #3
vping
vping's Avatar
Fan#: 120443
I cannot test fit at the moment. Just not sure if these two parameters are OK.
Offset 49 mm
I'd like to use these and get a good set of blizzaks for them.
vping is offline
Old 11-25-2013, 08:27 PM   #4
FocusontheZX
FocusontheZX's Avatar
Fan#: 64304
What I Drive: 2013 Focus ST II
Points 1,708, Level 24
Points: 1,708, Level: 24 Points: 1,708, Level: 24 Points: 1,708, Level: 24
Level Up 8% Completed
FF Reputation: 5 FocusontheZX Good Standing Member
Pretty sure stock offset is 50 mm, so you're pretty damn close there. I can't remember what the center bore is though..
Current: 2013 Focus ST II.
Past: 06 Explorer
Past: 03 Focus ZX3 Modded: Rims, SVT Bolt-Ons, Tons of audio stuff with Kenwood Headunit, MB Quart Components, and Subthump Stealth Hatch Enclosure and Amp Rack Loaded with Kicker Goodies!
FocusontheZX is offline
Old 11-26-2013, 01:53 AM   #5
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,243, Level 67
Points: 10,243, Level: 67 Points: 10,243, Level: 67 Points: 10,243, Level: 67
Level Up 49% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 26 suss6052 Great Standing Member
On the ST the stock offset is 55 mm, but it's also on an 8" wide wheel. The 49 mm offset is 6mm less than the stock wheels, and those wheels are 1" narrower. The hub bore being larger is an issue if you don't tighten down the lugs properly, but the biggest risk is clearance to the front calipers with balance weights, especially for alloy wheels in the 16" size.
16" is the minimum requirement, but 17" wheels fit better/ easier.
suss6052 is offline
Old 11-26-2013, 05:04 PM   #6
hEaT
Fan#: 20699
Hub is 63.35mm, but like said above that's okay as long as you tighten the lugs properly. The variance is too small to get centering rings.
I'm most concerned about caliper clearance.
ZETEC Crew #49
hEaT is offline
Old 11-26-2013, 05:26 PM   #7
vping
vping's Avatar
Fan#: 120443
I think I am going to look for a full set of SE wheels maybe in 17" in a junkyard. Hopefully there is a matching set of 4.
Sent from my SGH-T989 using FF Mobile
vping is offline
Old 12-18-2013, 11:05 AM   #8
CRP16
CRP16's Avatar
Fan#: 105951
What I Drive: 2013 SE hatch 5M
Points 222, Level 4
Points: 222, Level: 4 Points: 222, Level: 4 Points: 222, Level: 4
Level Up 44% Completed
Forum Activity 3%
FF Reputation: 1 CRP16 Good Standing Member
Look for some black pack wheels, I think they look really good on a blue ST.
2013 Focus SE Black Package 5M - Tuxedo Black - K&N drop in w/snorkel delete, custom axle back exhaust with resonator delete
CRP16 is offline
Old 12-18-2013, 10:07 PM   #9
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 33%
They look nice on the blue, and to my eyes even better match for my silver ST.
suss6052 is offline
Old 12-18-2013, 10:33 PM   #10
CRP16
CRP16's Avatar
Fan#: 105951
Points 222, Level 4
Forum Activity 3%
That does look good suss6052.
CRP16 is offline
