Ignition Lock Cylinder 2004 Focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-25-2013, 06:35 AM   #1
jkon21
Fan#: 85813
What I Drive: 2004 Silver Focus
FF Reputation: 1 jkon21 Good Standing Member
I know this has been talked about before. I had my ignition lock up on me. Couldn't turn key. Repair place replaced lock cylinder at the tune of $300. It worked for two starts then locked up again. Repair place now says that steering column has to be replaced because there is a part in the column that makes the lock cylinder go bad. He wants another $450 to now replace the steering column. This sounds like a bunch of balony to me. What do you all think? I think I got ripped in the first place. Thanks.
jkon21 is offline
Old 11-25-2013, 07:33 AM   #2
amc49
Fan#: 96610
Points 3,218, Level 35
Points: 3,218, Level: 35 Points: 3,218, Level: 35 Points: 3,218, Level: 35
Level Up 12% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
FF Reputation: 25 amc49 Great Standing Member
I tend to agree, I fixed mine using a Dremel and about 15 seconds of work and a good 3 years ago. Still using the old style 'bad' lock cylinder that everyone raves about.
amc49 is offline
Old 11-25-2013, 08:08 AM   #3
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
The first charge is reasonable.
Had this happen to two Ford Focus and one Dodge Neon
I bet you did not take your car down to a Ford Dealership but some other mechanic that did further damage
mikeeshaq is offline
Old 11-25-2013, 08:40 AM   #4
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,582, Level 75
Points: 13,582, Level: 75 Points: 13,582, Level: 75 Points: 13,582, Level: 75
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
Forum Activity 6%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (17)
did he have to drill out your old cly? if he did then $300 isnt bad, if not then you need to find a new locksmith. I was stranded when mine locked up, cost $200 for a lock smith to come out and rescue me.
And I deleted your other thread, 2 threads are not needed for your issue.
SkyPilot is offline
Old 11-25-2013, 09:28 AM   #5
TiIngot
Fan#: 110130
What I Drive: 1996 Corvette LT4 Convertible
Points 181, Level 3
Points: 181, Level: 3 Points: 181, Level: 3 Points: 181, Level: 3
Level Up 62% Completed
FF Reputation: 3 TiIngot Good Standing Member
First, I suggest not jumping to a conclusion yet. You will get some good answers from your post if you can wait a couple days.
Second, It seems a difficult pill to swollow to hear you need to now change the entire steering column. For example, you do not change the entire engine if you have a bad water pump. With that said I have been following these ignition switch posts for a year now and have never reviewed a response indicating the steering column needed replaced because of an ignition key switch failure.
Over the years I have removed the ignition switch on two Ford products. One on my '95 Thunderbird and one on my daughters '08 Focus. If you have the ability to remove the plastic cover surrounding the steering column yourself then you can change the lock cylinder IF YOU CAN GET IT TO TURN TO THE RUN POSITION. Others on this forum may be able to instruct you on to how to do this.
If you get the key to turn, remove the key cylinder assembly, inspect the hole in the cylinder came out of for scoring or damage. You may be able to insert something into the hole in the housing to try to turn the internals and engage the starter. If all looks good buy another ignotion switch and drive it a couple days before replacing the plastic steering column covers.
Going back to the steering column, I wonder if your mechanic somehow damaged the steering column as they forced the old ingition lock out? ?? If that is the case how do you prove it......................
I can describe how the steering column works on an '08 Focus SE with automatic transmission. Your '04 may be different. On the right side of the column is the ignition key cylinder (not the starter switch) that is mounted in a "lock housing assembly". This lock housing assembly is attached around the steering column, goes under it (inside the plastic steering column cover) to the left side of the column. On the left side of the column the lock housing assembly holds the starter switch. When you turn the key on the right side the lock housing assembly transfers that motion to rotate the starter switch on the left side that sends the signal to the starter relay.
In '08 Ford came out with a redesigned Focus. I do not know what the '04 internal design of the steering column assembly looks like. If the '04 is similiar to the '08 Focus and "if" the lock housing assembly was damaged while removing the first frozen key cylinder then the link below explains how to change only the lock housing assembly on an '08 Focus.
http://www.focusfanatics.com/forum/showthread.php?t=309714
Reading the link you will see the work can be completed without removing the steering column, without removing the steering wheel or messing with the airbags.
Keep us informed, good luck.
Ti Ingot
PS: Who did the first repair? Ford, a mechanic or your neighbor?
TiIngot is offline
Old 11-25-2013, 09:56 AM   #6
jkon21
Fan#: 85813
It was not a Ford garage that I took it to. I had a feeling that the "mechanic" damaged the steering column. I had sort of mentioned that to him and he didn't appreciate it. And you are correct...how do I prove it? Once I get the car back and I know it works fine, that place will then get another talking to. Thanks.
jkon21 is offline
Old 11-25-2013, 11:57 AM   #7
Fastnovice
Fan#: 120287
What I Drive: 2003 Black Focus SVT
Points 192, Level 3
Points: 192, Level: 3 Points: 192, Level: 3 Points: 192, Level: 3
Level Up 84% Completed
FF Reputation: 1 Fastnovice Good Standing Member
There are Videos on Youtube on how to replace the cylinder yourself. Especially if you can turn the key to the on position.
It doesn't require reprogramming the key either. You use your existing key.
Fastnovice is offline
Old 11-25-2013, 01:06 PM   #8
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,426, Level 86
Points: 18,426, Level: 86 Points: 18,426, Level: 86 Points: 18,426, Level: 86
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 7%
FF Reputation: 49 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
What's to say the key isn't wore and the problem? (I assume the new cylinder was coded to the old key)
What's to say the new lock cylinder isn't bad?
If the steering wheel locks and unlocks with then key, I highly doubt the column needs replacing.
iminhell is offline
