timing belt issue - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > SVT Performance (2002-2004)
Old 11-29-2013, 04:53 PM   #11
jwgstang
Fan#: 116398
What I Drive: 04 Sonic Blue Focus SVT
FF Reputation: 1 jwgstang Good Standing Member
I tried to loosen the tension and I took the crank pulley off and nothing everything looks fine maybe its a defective pulley?
jwgstang is offline
Old 11-29-2013, 05:27 PM   #12
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Too much belt tension.
Back the tensioner off a just a bit.
Rotate the engine clockwise by hand a few times.
Retension the belt.
It should come back around.
iminhell is online now
Old 11-29-2013, 05:57 PM   #13
amc49
Fan#: 96610
FF Reputation: 23 amc49 Great Standing Member
It may not once belt frays, the extra lump there will stop it from re-aligning.
Again no magic there, probably too much tension at the start. You are at the end of a long stream of hundreds who do that. You just can't get your head around how loose they are supposed to be. The more tension you add the more friction you have to walk sideways up or down a pulley. They minimize physical guides because the edge bumping again produces the fraying that makes belt fail.
A worn pulley bearing can let pulley lean slightly to move belt.
amc49 is offline
Old 11-29-2013, 07:45 PM   #14
jwgstang
Fan#: 116398
I guess I tigtend it too much hm. new belt kit I guess
jwgstang is offline
Old 11-29-2013, 07:45 PM   #15
jwgstang
Fan#: 116398
i already adjusted the tension it did nothing
jwgstang is offline
Old 11-29-2013, 09:46 PM   #16
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
On the tensioner there is a tab that goes into a opening on the plate it's mounted to, is the tab located in the opening?
If so I would pull the motor mount and belt side cover and see what's going on.
MannKind Corp. (MNKD)
NJSVTGUY is offline
Old 11-29-2013, 09:51 PM   #17
jwgstang
Fan#: 116398
I did pulle the motor mount and took everything off down to the crank I didn't see anything... and the tab us in the plate located behind the cam gears
jwgstang is offline
Old 11-29-2013, 10:59 PM   #18
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
Did you pull the engine front cover plate that the motor mounts bolts to?
The accessory idler mounts to it. It's not that bad to pull.
I thnk a straight line of sight down the belt is needed.
Sounds like you may have already.
Crank pulley was not flipped? Is the key in the crank aligned with the pulley? Perhaps the key bound up the pulley from going all the way on?
NJSVTGUY is offline
Old 11-30-2013, 12:04 AM   #19
amc49
Fan#: 96610
The belts walk with too much tension, whether on standard zetec or SVT, common issue and hundreds of posts about it. If the belt is visibly frayed in any way whatsoever you must have a new belt. Appears to be from the difference in belt polish on the top side in the pic. The pulley edge frays the belt bottom to fail early.
A misworn to lose the crown pulley, or loose pulley bearing can do it, the tilt allows belt to ride off end of sprocket.
You do NOT need any physical side guides on belts AT ALL to keep them running true. I ran them for 30 years in the printing industry at high rates of speed and no guides at all, the pulley is either low in middle of the OD surface or high depending on design, as long as not worn the belt will stay in place forever like that. On these the plastic pulleys are low, take two parts and butt the outsides together to see it. Thinking the metal sprockets may be straight but you only need a few 'director' pulleys in a system to track a belt straight-they do not all have to be crowned one way or the other.
amc49 is offline
Old 12-02-2013, 10:56 PM   #20
jwgstang
Fan#: 116398
yes I took everything off and loosened the belt ALOT it didn't change anything... I think something is wore and they belt hasn't frayed on the bottom or anything its just riding to the side
jwgstang is offline
