timing belt issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-24-2013, 08:17 PM   #1
jwgstang
Fan#: 116398
What I Drive: 04 Sonic Blue Focus SVT
Points 1,754, Level 24
Points: 1,754, Level: 24 Points: 1,754, Level: 24 Points: 1,754, Level: 24
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 9%
FF Reputation: 1 jwgstang Good Standing Member
timing belt issue
hello guys I have an 04 svt and rebuilt it a while back im not having any problems with it I was just wondering if my timing belt position is normal its all the way towards the side of the cams here is the picture help!!? its kinda hanging off the gear a bit like 1/16-1/8 of an inch
jwgstang is offline
Old 11-24-2013, 11:47 PM   #2
BlueBronco1987
BlueBronco1987's Avatar
Fan#: 114133
What I Drive: 2002 CD Silver SVT ZX3
Points 725, Level 14
Points: 725, Level: 14 Points: 725, Level: 14 Points: 725, Level: 14
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 1 BlueBronco1987 Good Standing Member
You have a worn tensioner, idler or
water pump.
BlueBronco1987 is offline
Old 11-25-2013, 12:24 AM   #3
jwgstang
Fan#: 116398
Forum Activity 9%
bluebronco it has been like this ever since I bought the kit and installed it its a gates kit I was maybe thinking I have my belt guide on wrong
jwgstang is offline
Old 11-25-2013, 12:25 AM   #4
jwgstang
Fan#: 116398
Forum Activity 9%
and waterpump doesn't run off the timing belt, Hondas do
jwgstang is offline
Old 11-25-2013, 08:42 AM   #5
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
Probably too much tension at install, people continually have issue with how light the tension is needed on these motors. More=belt walk off pulley end. New pulleys have concave surfaces, the center is lower than the outside edges, when tension is too high belt edgerides to the high on pulley end.
No real 'guides' to speak of, only the crank pulley, the edgeriding will fray inside of belt on edge to break/shred belt way early. I'd be looking into that, SVTs bend valves when the belt breaks. You may already know that.........
amc49 is offline
Old 11-25-2013, 02:59 PM   #6
jwgstang
Fan#: 116398
Forum Activity 9%
yes i know its a interfearance motor and i put the stock about of tention on it lining the little tools up on the tensioner
jwgstang is offline
Old 11-25-2013, 11:44 PM   #7
jwgstang
Fan#: 116398
Forum Activity 9%
anyone else have an idea?
jwgstang is offline
Old 11-26-2013, 12:34 AM   #8
BlueBronco1987
Fan#: 114133
My bad.
Old 11-26-2013, 10:28 AM   #9
Wild Child
Fan#: 119206
What I Drive: 2003 Silver ZX5 SVT
Points 75, Level 1
Points: 75, Level: 1 Points: 75, Level: 1 Points: 75, Level: 1
Level Up 50% Completed
FF Reputation: 1 Wild Child Good Standing Member
Is it possible the crank pulley did not slide all the way back on or is loose? Is it the original pulley? Original crank? Key get wedged during install? Could something have changed how these two fit together? If the crank pulley is the only method used for guiding the belt, I would inspect it's alignment / position very carefully.
Wild Child is offline
Old 11-27-2013, 12:20 AM   #10
jwgstang
Fan#: 116398
Forum Activity 9%
Lol its okay blue bronco hahaha but okay il have to check it out
jwgstang is offline
